JEDEC* | EIAJ* | PHILIPS SIEMENS CENTS* MAXIM | ROHM | SANYO | HITACHI | MOTOROLA | TOSHIBA KEC | ТО-236 | SC-59 | SOT-346 | SMD/T3 | | MPAK2 | SC-59 | S-MINI | ТО-236АВ | | SOT/SOD-23 | SSDA3 | CP | | SOT-23 | | ТО-243АА | SC-62 | SOT-89A | MPT3 | | UPAK | | PW-MINI | ТО-243АВ | | SOT-89B | | | | | | ТО-252-3 | SC-63 | | CPT3 | | | | | ТО-253 | | SOT-143 | SMD/T4 | | | SOT-143 | | ТО-253 | | SOT-143R | | | | | | | | SOD-123 | | | | SOD-123 | | | | SOD-323 | UMD2 | | | | USC | | | SOT-343 | | | | | | | | SOT-343R | | | CMPAK4 | | | | | SOT-87 | | | | | | | SC-70 | SOT-323 | UMD/T3 | MCP | CMPAK | SOT-323 | USM | | SC-74 | | SMD/T6 | | | | SM6 | | SC-74A | | SMD/T5 | | | | SMV | | SC-75A | SOT-416 | EMD/T3 | | | | SSM | | SC-79 | SOD-523 | EMD2 | | | | | | SC-82 | | UМD/T4 | | | | | | SC-88 | SOT-363 | UMD/T6 | | | | US6 | | SC-88A | SOT-353 | UMD/T5 | | | | USV |
Тип корпуса | PHILIPS MURATA AVX* VISHAY | TDK MALLORY SYFER KEMET VITRAMON BOURNS SINCERA YAGEO | SGS-THOMSON | PANASONIC | CTC | ROHM | SAMSUNG | 0402 | 0402 | | | 10 | 06 | | 05 | 0603 | 0603 | 0603 | AN21 | 11 | 08 | 18 | 10 | 0805 | 0805 | 0805 | AN12 | 12 | 12 | 21 | 21 | 1206 | 1206 | 1206 | AN20 | 13 | | 31 | 31 | 1210 | 1210 | 1210 | | | | | | 1218 | 1218 | | | | | | | 1812 | 1812 | | | | | | 43 | 2220 | 2220 | | | | | | |
Тип корпуса | ST* NOVER AVX* S+M* | FUJITSU | HITACHI | NEC MATSUO SAMSUNG ELNA KEMET NACC MALLORY | PANAS* | МОT* CS* | VISHAY | PHILIPS | ROHM | 1608 | | | | | E | | | | | 2012 | | | Р | | D | | | | | 3216 | А | А | А | A | Y | | A | | A | 3216L | | | UA | | | | | | | 3528 | В | BI | В | В | X | | 8 | | В | 3528L | | В2 | UB | | | | | | | 5832 | | | UC | | | | | | | 5845 | | | D | | V | | | | | 6032 | С | С | С | С | с | | С | | | 7343 | D | Е | Е | D | D | | D | | | 7343Н | Е | | G | X | | | | | | DO-214AA | | | | | | SMB | SMB | | | DO-214AB | | | | | | SMC | SMC | | | DO-214AC | | | | | | SMA | SMA | SOD-106 | PMDS | DO-214BA | | | | | | | | | |
* Расшифровку аббревиатур см. далее.
** Наметилась тенденция, когда рядом с внутрифирменным
обозначением корпуса указывается название этого корпуса по одному из
стандартов — JEDEC или EIAJ.
*** У разных фирм под одним и тем же названием могут быть корпуса с
отличающимися размерами; не указаны корпуса, которые внешне похожи на
представленные, но имеют габаритные размеры, отличающиеся от стандартных,
например SOD15 фирмы SGS-Thomson.
