PLL CARIER OSCILLATOR PORTION
Test equipment required:
Power Supply: 13,2 V
DC Volt Meter
Oscilloscope
Frequency Counter
Preparation alignment:
Clarifier
Center
RF Power
Clockwise
VR205 and VR206
Center
Remove
PB 201
Step
Condition
Adjustment
Procedure
1
RX AM
27.405 MHz
L405
Connect the DC Voltmeter to TP2
Adjust for 2.5 +/- 0.1 V
2
RX AM
26.965 MHz
Same as Step 1
More than 2.0 V
3
TX AM
27.205 MHz
L401
Connect oscilloscope to TP1
Adjust for 37.900 MHz +/- 20 Hz
4
RX AM
27.205 MHz
Check
Same as Step 3
5
TX FM
27.205 MHz
Check
Same as Step 3
37.900 MHz +/- 20 Hz Reading
6
RX FM
27.205 MHz
Check
Same as Step 3
7
TX USB
27.205 MHz
VR211
Adjust for 37.9025 MHz +/- 20 Hz
8
RX USB
27.205 MHz
Check
Same as Step 3
9
TX LSB
27.205 MHz
L402
Adjust for 37.8975 MHz +/- 20 Hz
10
RX LSB
27.205 MHz
Check
Same as Step 3
11
TX AM
27.205 MHz
L406
Connect oscilloscope to TP 3
Adjust for10.695 MHz +/- 20 Hz
12
TX FM
27.205 MHz
Check
Same as Step 11
10.695 MHz +/- 20 Hz Reading
13
TX USB
27.205 MHz
L408
Adjust for10.6975 MHz +/- 20 Hz
14
RX USB
27.205 MHz
Check
Same as Step 13
10.6975 MHz +/- 20 Hz Reading
15
TX LSB
27.205 MHz
L402
Adjust for10.6925 MHz +/- 20 Hz
16
RX LSB
27.205 MHz
Check
Same as Step 15
10.6925 MHz +/- 20 Hz Reading
17
RX FM
28.755 MHz
Check
Same as Step 1
Less than 4.2 V
18
RX USB
26.065 MHz
Check
Same as Step 1
More than 1.2 V
Oscillator-frequency at 27.205MHz
VFO OSC- TP1
Adjust
X-tal OSC - TP3
Adjust
Mod.
37.9000MHz
L401
10.6950MHz
RX - AM
37.9000MHz
10.6950MHz
RX - FM
37.9025MHz
10.6975MHz
L408
RX - USB
37.8975MHz
L402
10.6925MHz
L407
RX - LSB
37.9000MHz
10.6950MHz
L406
TX - AM
37.9000MHz
10.6950MHz
TX - FM
37.9025MHz
VR211
10.6975MHz
TX - USB
37.8975MHz
10.6925MHz
TX - LSB
TRANSMITTER PORTION
DC Current Meter
Oscilloscope
RF Power meter
RF VTVM
AF Oscillator
FM Linear Detector
Dummy Load (50 ohm)
AF VTVM
VR208
Clockwise
VR205 and VR 206
Middle position
VR207, VR201, VR202, and VR 203
Counterclockwise
Mic gain
Clockwise
Meter SW
RF
SWR/CAL Volume
Middle position
RF Power
Clockwise
Test frequency
27.185 MHz
Step
Condition
Adjustment
Procedure
1
LSB 27.185 MHz
No Mod.
VR203
Remove the PB201
Connect a DC current meter to TP202 (+) and TP203 (-)
Adjust for 330 mA
2
Same as Step 1
VR201
Connect a DC current meter to TP202 (+) and TP201 (-)
Adjust for 85 mA
3
Same as Step 1
VR202
Adjust for 170 mA
4
LSB 27.185 MHz
Two-Tone
400 Hz and 2.500 Hz
1 mV Mod.
L221
Re-install the PB201
Adjust for maximum on the RF VTVM
Set the AF-oscillator, so that the output is less than 32 V
5
LSB 27.185 MHz
Two-Tone
400 Hz and 2.500 Hz
30 mV Mod.
VR208
Adjust for 25 V on the RF VTVM
6
SSB 27.185 MHz
No Mod.
VR209
Adjust the carrier leakade at LSB and USB become minimum and almost equal
7
AM 27.185 MHz
No Mod.
VR205
Adjust for 3.9 Watt on the WattMeter
8
AM 27.185 MHz
No Mod.
VR204
Adjust for RF Meter at "9" just light on
9
AM 27.185 MHz
1 kHz 30 mV Mod.
VR207
Adjust 90% negative
10
AM 27.185 MHz
1 kHz 3 mV Mod.
VR213
Adjust for Modulation Meter at "9" just light on
11
FM 27.185 MHz
No Mod.
VR206
Adjust for 3,9 Watt on the WattMeter
12
FM 27.185 MHz
1 kHz 30 mV Mod.
VR212
Adjust for +/- 1.9 kHz Deviation
RECEIVER PORTION
SINAD Meter
Oscilloscope
AM/FM SSG
(AM: 1 kHz 60% Mod.)
(FM: 1 kHz 1.2 kHz Deviation)
NB/ANL
Off
HI CUT
Off
SQUELCH
Counter clockwise
Volume
Clockwise
RF Gain
Clockwise
Clarifier
Center
Frequency
27.185 MHz
Step
Condition
Adjustment
Procedure
1
AM
60% Mod.
L17 L2 L6 L7 L11 L12 L13
Adjust for maximum reading on the AF VTVM
2
FM
1.2 kHz Dev.
L16
3
AM
No Mod.
VR4
SSG: 40dB (50uV) Adjust "9" just light on
4
AM
No Mod.
VR2
SSG: 66dB (1mV) Just apper AF level
5
USB
No Mod.
L15 and L14
6
USB
No Mod.
VR3
7
USB
No Mod.
VR1
SSG: 66dB (1 mV) Just apper AF level
8
USB
No Mod.
L1
Connect Oscilloscope to TP4. Set Oscilloscope to DC range and adjust to reach max. reading.
9
AM
26.065 MHz
60% Mod.
Check
SSG: 10dB
More than 20 dB SINAD
10
AM
28.755 MHz
60% Mod.
Check
SSG: 10dB
Improved receive gain
Quieting of AM reception and improving gain of incoming signals is a common request from radio operators. In the first stages of the HF input 2SC1674 (Q8) transistor can be found. This transistor is responsible for the amplification of a small detected signals. A problems exist if the transistor itself is noisy as is such the case of the 2SC1674 when compared to other low noise packages. Along with the amplification of the incoming signals is transistor noise. Replacement of this transistor with a higher gain, lower noise transistor greatly improves the signal to noise ratio of your receiver.
The transistor Q8 operates at VCE= 6Volt and IE= 2,5mA. We will use an 2SC2999 transistor that has higher gain and lower noise characteristic. Replace
2SC1674 (Q8) with 2SC2999 (or similar low noise and high gain transistor) to achieve this improved signal to noise ratio.
Re-adjust L2.
The gain will improved with more than 6dB with the same signal to noise ratio.
