www.dxsoft.com
PLL and CARRIER OSCILLATOR PORTION
Test equipment required:
Power Supply: 13,8 V
Frequency Counter
Dummy Load 50 ohm
Oscilloscope
DC VTVM
Preparation alignment:
Clarifier
Mid.
SQ GAIN
Max.
AF GAIN
Max.
RF GAIN
Max.
MIC GAIN
Max.
MOD, S/RF
S/RF
NB/ANL
Off
RF SSG
Modulation: 30% AM 1000Hz
Step
Condition
Adjustment
Procedure
1
MODE: RX AM
Ch. 19 MID.
L17
Connect osciloscope on TP4. Adjust for maximum reading.
2
MODE: RX AM
Ch. 40 MID.
L18
Connect DC Voltmeter on TP2. Adjust to obtain 5,5Volt.
3
MODE: RX AM
Ch. 19 MID.
L19
Connect oscilloscope on TP3. Adjust for maximum reading.
4
MODE: RX AM
Ch. 19 MID.
L25
Connect Frequency Counter on TP3. Adjust to obtain 16.490MHz +/- 20Hz.
5
MODE: RX USB
Ch. 19 MID.
L26
Connect Frequency Counter on TP3. Adjust to obtain 16.4925MHz +/- 20Hz.
6
MODE: RX LSB
Ch. 19 MID.
L27
Connect Frequency Counter on TP3. Adjust to obtain 16.4875MHz +/- 20Hz.
7
MODE: TX LSB
Ch. 19 MID.
VR6
Connect Frequency Counter on TP3. Adjust to obtain 16.875MHz +/- 20Hz.
8
MODE: RX AM
Ch. 19 MID.
L22
Connect Frequency Counter on TP3. Adjust to obtain 16.040MHz +/- 20Hz.
9
MODE: RX USB
Ch. 19 MID.
L23
Connect Frequency Counter on TP3. Adjust to obtain 16.0425MHz +/- 20Hz.
10
MODE: RX LSB
Ch. 19 MID.
L24
Connect Frequency Counter on TP3. Adjust to obtain 16.0375MHz +/- 20Hz.
11
MODE: RX LSB
L30
Connect Frequency Counter on TP6. Adjust to obtain 16.6975MHz +/- 20Hz.
12
MODE: RX USB
L29
Connect Frequency Counter on TP6. Adjust to obtain 16.6925MHz +/- 20Hz.
13
MODE: TX AM
L28
Connect Frequency Counter on Base from TR43. Adjust to obtain 16.6950MHz +/- 20Hz.
TRANSMITTER PORTION
AF Signal Generator
RF Dummy Load 50 ohm
Oscilloscope
RF Power Meter
Frequency Counter
Clarifier
Mid.
SQ GAIN
Max.
AF GAIN
Max.
RF GAIN
Max.
MIC GAIN
Max.
MOD, S/RF
S/RF
NB/ANL
Off
Step
Condition
Adjustment
Procedure
1
Mode: TX USB
27.185MHz
S1 and S2 OFF
VR11
Disconnect PC834. Connect DC Current Meter on TP9(+) and TP8(-). Adjust for 50mA.
2
Mode: TX USB
27.185MHz
S1 and S2 OFF
VR9
Disconnect PC834. Connect DC Current Meter on TP9(+) and TP8(-). Adjust for 4mA.
3
Mode: TX USB
27.185MHz
S1 and S2 OFF
VR10
Disconnect PC834. Connect DC Current Meter on TP9(+) and TP8(-). Adjust for 80mA.
4
Mode: TX USB
27.185MHz
S1 and S2 ON
Modulation: 2,4kHz and 500Hz
L46
Set the core of L46 to the bottom, adjust VR12 to minimum.
5
Mode: TX USB
27.185MHz
S1 and S2 ON
L45 L48 L49
Adjust the cores to obtain max. deviation on RF VoltMeter. Repeat this operation with lower AF levelss on MIC input.
6
Mode: TX USB
27.185MHz
S1 and S2 ON
L46
Adjut to obtain max deviation on RF Voltmeter. Adjust to obtain a mimimum power difference between Ch.40 HIGH and Ch.1 LOW
7
Mode: TX AM
27.185MHz
S1 ON
Modulation: 1kHz
L37
Adjust to obtain max deviation on S/RF Meter
8
Mode: TX AM
27.185MHz
S1 ON
Modulation: 1kHz
VR12
Adjust to obtain 32,4 Volt on RF VoltMeter
9
Mode: TX USB
27.185MHz
S1 and S2 OFF
VR7
Adjust to obtain minimum difference between USB and LSB
10
Mode: TX AM
27.185MHz
S2 OFF
VR13
Adjust to obtain 10 Watt on RF Power meter
11
Mode: TX AM
27.185MHz
S2 OFF
VR8
Set Switch on S/RF. Adjust to set the S-meter between the Red and Green field
12
Mode: TX AM
27.185MHz
S1 ON
Modulation: 1kHz 30mV
VR14
Adjust to obtain 90 % AM-Modulation on Oscilloscope.
13
Mode: TX FM
27.185MHz
S1 ON
VR5
Adjust to obtain +/- 2 kHz deviation on DeviationMeter.
14
Mode: TX AM
27.185MHz
S1 ON
VR15
Set switch on MOD, AF SignalGenerator to obtain 50% modulation. Adjust levels of AF Signal Generator to 16dB. Adjust VR15 to obtain 100% modulation on S-Meter.
RECEIVER PORTION
RF Signal Generator
Dummy Load 8 ohm
Oscilloscope
AF VTVM
Clarifier
Mid.
SQ GAIN
Max.
AF GAIN
Max.
RF GAIN
Max.
MIC GAIN
Max.
MOD, S/RF
S/RF
NB/ANL
Off
RF SSG
Step
Condition
Adjustment
Procedure
1
Mode: RX AM
Band: Mid.
Channel: 19
L8
Set RF SSG on 27.185MHz, 1kHz 30% AM-mod. Adjust L8 for maximum reading on oscilloscope.
2
Same as STEP 1
L7 L9 L11 L12 L13 L52 L3 L4 L5
Adjust level of RF SSG to obtain 2V on AF VTVM then adjust coils for maximum reading on meter.
3
Same as STEP 1
L8
Adjust to obtain minimum difference between Ch. 40 and Ch. 1
4
Same as STEP 1
VR1
Set the level of RF SSG to 100mV. Adjust VR1 for "5-9" reading on tranceiver meter.
5
Same as STEP 1
VR4
Set SQ on max. Adjust level of RF SSG to 1000mV, adjust VR4 so that the radio signal will apper on tranceiver. Set SQ on minimum.
6
Same as STEP 1
Mode: USB
L14 L15
Set RF SSG on 27.186MHz. Adjust coils to obtain maximum reading on oscilloscope.
7
Same as STEP 1
VR2
Set level of RF SSG to 100uV. Adjust VR2 to obtain "S9" on transmitter meter.
8
Same as STEP 1
SQ: Max.
VR3
Set level of RF SSG to 1000mV. Adjust VR3 so that the audio signal will apper on tranceiver
9
Same as STEP 1
NB/ANL: ON
MID, Ch.18, USB
L1 L2
Set RF SSG on 27.185MHz, 0% Mod., 10uV Level. Connect oscilloscope on D2 and adjust the coils to obtain maximum deviation.
10
Same as STEP 1
L6
Set RF SSG on 27.185MHz with 1 kHz deviation, 1000mV Level. Adjust L6 to obtain maximum.
