www.cqham.ru
CARRIER OSCILLATOR PORTION
Test equipment required:
Power Supply: 13,8 V
Oscilloscope
Dummy Load 50 ohm
Frequency Counter
Preparation alignment:
Channel:
40
Step
Condition
Adjustment
Procedure
1
MODE: TX FM
L702
Connect Oscilloscope to TP1 and adjust for 4,5V +/- 0.1V
2
MODE: RX FM
L701
3
MODE: RX FM
CHECK
Connect the Frequency Counter to Ant. jack an scheck frequency for 27.405 MHz /- 20 Hz
TRANSMITTER PORTION
RF Power Meter
Deviation Meter
Oscilloscope
Audio Oscillator
Dummy Load 50 ohm
Channel:
19
Step
Condition
Adjustment
Procedure
1
MODE: FM
No Mod.
L203
Adjust for maximum output reading on the RF Power meter
2
MODE: FM
No Mod.
RT201
Adjust so LED 4 lights
3
MODE: FM
Mod: 1 kHz, 30 mV
RT202
Adjust for +/- 2 kHz FM-Deviation
RECEIVER PORTION
RF Signal Generator
AF Signal Generator
Oscilloscope
Dummy Load 8 ohm
Channel:
19
Step
Condition
Adjustment
Procedure
1
MODE: AM
Mod: 1 kHz, 60%
SSG output: 0dB (0.5mV)
SQ: Min.
L1 L2
L3 L4
Adjust for maximum output reading on the Oscilloscope
2
MODE: AM
No Mod.
SSG output: 1000uV
SQ: Min
RT1
3
MODE: AM
Mod: 1 kHz, 60%
SSG output: 1000uV
SQ: Max.
RT2
Adjust RT2 so that the squelch just breaks.
4
MODE: FM
Mod: 1 kHz, +/- 1,5 kHz Dev.
SSG output: 1000uV
SQ: Min.
L6
Connect Oscilloscope to TP1 and adjust L1 for 4.5 V +/- 0.2 V reading on the Oscilloscope
