CARRIER OSCILLATOR PORTION
Test equipment required:
Power Supply: 13,8 V
Oscilloscope
Dummy Load 50 ohm
Frequency Counter
Preparation alignment:
Channel:
40
Step
Condition
Adjustment
Procedure
1
RX Band C
Channel 20
L701
Connect DC-Voltmeter to TP1. Adjust for 2,4Volt +/-0,1Volt
2
TX Band C
Channel 20
L702
3
RX Band C
Channel 20
CT701
Connect Frequency Counter to TP 3. Adjust for 37.900MHz
TRANSMITTER PORTION
RF Power Meter
Deviation Meter
Oscilloscope
Audio Oscillator
Dummy Load 50 ohm
Channel:
19
Step
Condition
Adjustment
Procedure
1
TX FM Band C
Channel 20
L16
Adjust for maximum RF Output
2
TX FM Band C
Channel 20
RT5
Adjust for 4 Watt RF Output
3
TX AM Band C
Channel 20
RT4
4
TX FM Band C
Channel 20
RT3
Adjust for LED "7" on RF Output Meter
5
TX FM Band C
Channel 20
RT6
Connect 100ohm Dummy Load to Ant. jack. Adjust for LED "4" on SWR-Meter
6
TX AM Band C
Channel 20
RT8
Adjust for 90% Modulation
4
TX FM Band C
Channel 20
RT7
Adjust for +/- 2kHz FM-Deviation
RECEIVER PORTION
RF Signal Generator
AF Signal Generator
Oscilloscope
Dummy Load 8 ohm
Channel:
19
Step
Condition
Adjustment
Procedure
1
RX AM Band C
Channel 20
L1, L4, L5, L6, L7
Connect RRF SSG with 6%mod., -107dBm to ant. jack. Adjust for maximum signal utput at speaker.
2
RX FM Band C
Channel 20
L9
Connetc RF SSG with -47dBm, no mod. to ant. jack. Connect DC-Voltmeter to TP2. Adjust for 3,5Volt +/- 0,1Volt.
3
RX FM Band C
Channel 20
RT2
Connetc RF SSG with -73dBm, no mod. to ant. jack. Adjust for LED "7" on RF S-Meter.
4
RX AM Band C
Channel 20
RT1
Connetc RF SSG with -47dBm, 60% 1kHz mod. to ant. jack. Adjust SQ.
