TRANSMITTER PORTION
Test equipment required:
Power Supply: 13,8 V
AF SSG
RF VTVM
DC AM-meter
AF VTVM
FM Linear Detector
Oscilloscope
RF Power Meter
Dummy Load, 50 ohm
Preparation alignment:
VR112
Clockwise
VR113
Counter Clockwise
VR103
Clockwise
SWR/CAL
Clockwise
RF Gain
Middle position
PA SW
Off
INDIC SW
RF
Mic Gain Sw
Off
RF Power
Max.
Frequency
28.000 MHz
Step
Condition
Adjustment
Procedure
1
USB
No Mod.
VR13
Remove the B002 (PB-100) from Main PCB. Connect a DC AM Meter to TP4 (+) and TP3 (-). Adjust VR13 for 50 mA reading on the DC AM Meter.
2
USB
No Mod.
VR14
Remove the B002 (PB-100) from Main PCB. Connect the DC AM Meter to TP4 (+) and TP2 (-). Adjust VR14 for 50 mA reading on the DC AM Meter
3
USB
1 mV Mod.
L25
Connect a RF Power Meter to Ant.jack. Connect a RF VTVM, an Oscilloscope and an RF Linear Dectector across an Dummy Load to the RF Power meter. Adjust L25 for maximum reading en the RF VTVM. During this step, set the AF Oscillator so that the output is less than 20 V. Repeat this step two times.
4
USB
30 mV Mod.
VR5
Adjust VR5 for 32.5 V reading on the RF VTVM.
5
USB
30 mV Mod.
VR7
Adjust VR7 so that the carrier leakage at USB and LSB become minimum and almost equal.
6
CW
No Mod.
VR4
Connect a SW between Pin 8 and 9 of ACC connector. When turn on the SW, adjust VR4 for 21 Watt reading on the RF Power Meter.
7
AM
No Mod.
VR8
Adjust VR8 for 10 Watt reading on the RF Power Meter
8
AM
No Mod.
VR12
Adjust VR12 so that "9" LCD just light on.
9
AM
1 kHz 30 mV Mod.
VR6
Adjust VR6 to obtain the 85% negative reading on the Oscilloscope.
10
AM
1 kHz 1 mV Mod.
VR9
INDIC: MOD. Adjust VR9 so that "9" LCD just light on.
11
FM
1 kHz 30 mV Mod.
VR3
Adjust VR3 for +/- 3 kHz deviation on the FM Linear Detector.
12
CW
No Mod.
Vol.: Max.
VR10
Connect an AF VTVM across a Dummy Load (8 ohm) between Pin 1 and Pin 2 of ACC connector. When turn on the SW, adjust VR10 for 0.4 V reading on the AF VTVM.
RECEIVER PORTION
Dummy Load 8 ohm
AF VTVM
Oscilloscope
HF SSG:
28.000 MHz
1 kHz
30% Mod.
NB SW
Off
PA SW
Off
Beep SW
Off
VOLUME
Max.
RIT
Middle position
Mode
AM
Squelch
Min.
DX/LOC
DX
Frequency
28.000 MHz
Step
Condition
Adjustment
Procedure
1
AM
SSG 40dB
1 kHz Mod.
L1 L2 L3 L4 L5 L6
Alignment of sensitivity. Adjust coils for maximum reading on the AF VTVM.
2
AM
SSG 66dB
1 kHz Mod.
VR2
Alignment of Squelch. Set Squelsch to maximum. Adjust VR2 so that the squelch just breaks.
3
AM
SSG 46dB
No Mod.
VR1
Alignment of S-meter. Adjust VR1 so that "9" LCD just lights on.
4
FM
SSG 1 mV
1.5 kHz Dev.
L401
Adjust L401 for maximum reading on the AF VTVM.
5
AM
SSG 1 mV
Noise Gen.
L203
Adjust L203 for maximum reading on the AF VTVM. Noise Generator output: 50 Hz SQ wave 2 V P-P.
Improved receive gain
Quieting of AM reception and improving gain of incoming signals is a common request from radio operators. In the first stages of the HF input 2SC1674 transistor can be found. This transistor is responsible for the amplification of a small detected signals. A problems exist if the transistor itself is noisy as is such the case of the 2SC1674 when compared to other low noise packages. Along with the amplification of the incoming signals is transistor noise. Replacement of this transistor with a higher gain, lower noise transistor greatly improves the signal to noise ratio of your receiver.
We will use an 2SC2999 transistor that has higher gain lower noise characteristic. Replace the
2SC1674 (Q1) with an 2SC2999 (or similar low noise and high gain transistor) to achieve this improved signal to noise ratio.
Re-Adjust L101
The gain will improved with more than 6dB with the same signal to noise ratio.
PLL and CARRIER OSCILLATOR PORTION
Oscilloscope
Frequency Counter
DC Voltmeter
PA SW
Off
RIT
Middle position
Mode
AM
Frequency
28.000 MHz
Step
Condition
Adjustment
Procedure
1
AM
RX
L315
Connect the Oscilloscope and Frequency Counter to TP306. Adjust for 6.200 MHz +/- 20 Hz
2
AM
RX
L318
Connect the Oscilloscope and Frequency Counter to TP304. Adjust for 38.6950 MHz +/- 20 Hz.
Check:
USB : 38.6975MHz
LSB : 38.6925MHz
3
AM
RX
L317
Connect the DC Voltmeter to TP 303. Adjust for 6.5 V +/- 0.1 V
4
CW
RX
L117
Connect the Oscilloscope and Frequency Counter to TP1. Adjust for 10.695 MHz +/- 20 Hz
5
LSB
RX
L118
Connect the Oscilloscope and Frequency Counter to TP1. Adjust for 10.6925 MHz -40 Hz to + 0 Hz
6
USB
RX
L116
Connect the Oscilloscope and Frequency Counter to TP1. Adjust for 10.6975 +/- 20 Hz
7
USB
RX
VR111
Connect the Oscilloscope and Frequency Counter to TP5. Adjust for 38.6975 +/- 20 Hz
Adjustment
Description
VR304
Amplifier Gain Adjustment
Only in President HR2600
Adjustment of Balanced Mixer`s
Adjustment
Description
VR301
DC Balance Adjustment for Balanced Mixer
L303
9-10MHz Signal Balance Adjustment to Mixer
L304
14-18MHz Signal Balance Adjustment to Mixer
Connect Oscilloscope to IC304 pin 2.
Adjust VR301 for correct DC-balance.
Adjust L303 for maximum signal.
Adjust L304 for maximum signal.
Adjustment
Description
VR302
L313
22MHz Signal Balance Adjustment to Mixer
L314
36-40MHz Signal Balance Adjustment to Mixer
Connect Oscilloscope to IC305 pin 2.
Adjust VR302 for correct DC-balance.
Adjust L313 for maximum signal.
Adjust L314 for maximum signal.
BandPassFilter Adjustment
Adjustment
Description
L310
High Band Adjustment
L319
Low Band Adjustment
Connect Oscilloscope to Output Terminal for VCO.
Adjust L310 for maximum at 29.000MHz.
Adjust L319 for maximum at 28.500MHz.
Band
Frequency Range (Without ChipSwitch or Frequency Modification)
A
28.000 to 28.4999 MHz
B
28.500 to 28.999 MHz
C
29.000 to 29.4999 MHz
D
29.5000 to 29.699 MHz
Output Frequency from PLL-PCB to Analog-PCB
Fvco = F + 10.6950MHz + a
F = Transmitting and Receiving frequency
Fvco = VCO Output frequency
a = 0kHz for CW/FM/AM
a = +2.5kHz for USB
a = -2.5kHz for LSB
