Once the boards have been assembled, it is suggested you connect all parts of the system together in the manner of the breadboard shown in the previous page. If you are using the Gunn supply voltage to adjust frequency, you will find that optimum speech quality occurs over a limited range. Ideally you should arrange to have TWO Gunn systems (your friend's and your own) on the bench at the same time so that both can be made compatible with each other. You should then set the coarse frequency adjustment using the adjusting screw already fitted to each doppler module, with the Gunn volts set at mid-range. This will give you a small, but effective variable tuning range.
Initial checks:
The milliameter should now give some indication of the mixer diode current. Don't worry about the amount at this stage, although you can adjust the matching screw near the mixer diode for around 0.5 to 1mA if you wish.
The loudspeaker should by now be giving a healthy hiss!
Next, you have to find the 10GHz amateur band!
One of the simplest ways to do this is to use a 2m, 70cm or 23cm low power signal to drive a microwave diode so that a whole string of harmonics is produced, at least one falling into the 10GHz band. The higher the original signal the more likely you are to find the correct harmonic. Only a few hundred milliwatts drive (say up to 500mW) will be needed to produce a few, easily-heard microwatts on 10GHz. The easiest way to do this is to simply connect a microwave mixer diode (eg a 1N23 or similar, or even a more modern type such as one taken from a surplus X band Satellite LNB) across a BNC socket. Solder it from the spiggot to the body of the connector. Then feed 2m, 70cm etc in via a length of coax. Poke the diode end of the assembly near to the mouth of the doppler module's waveguide and coarse tune the module until you hear the signal. This is made much easier if you switch on the TONE OSCILLATOR which is part of the simple circuitry described in this article.
The following table shows some useful harmonic relationships:
Input Frequency |
Multiplication Factor | Output Frequency |
144.000MHz |
x71 |
10.224GHz |
144.000MHz |
x72 |
10.368GHz |
432.000MHz |
x24 |
10.368GHz |
1296.000MHz |
x8 |
10.368GHz |
Using a 144MHz drive source can lead to some errors, since more than one harmonic will fall within the 10GHz amateur band. Hence it is recommended that you use 432MHz or 1296MHz source.
You
might have access to an accurate frequency counter..use it! You may also be
able to obtain an X Band wavemeter at hamfests or radio rallies. The one pictured
here was bought for only Ј10 UK (about $16 US) and was indispensible to writer
in his "early days". This type of wavemeter, with waveguide ports
is easy to use. Tuning the micrometer dial will cause a "suck out"
or dip in mixer diode current when the frequency of the Gunn coincides
with that of the micrometer cavity. Ideally you should have a microwave detector
diode mounted in a waveguide cavity and place this after the wavemeter. In other
words, the wavemeter should be put between the Gunn oscillator and the diode
receiver. Sometimes the flanges may not match the ones on your Gunn transceiver.
You will then need a short length (say 6cm) of waveguide with a round
flange at one end and a rectangular one at the other for use as an adapter.
Note that the frequency 10.368GHz is also the narrowband operating frequency. If you have a narrowbander near to you, he might put out a CW signal for you to listen for and use as a calibration point. You may be fortunate enough to have a 10GHz beacon near to you. By taking your wideband gear out to an easy line-of-sight path between you and the beacon you should be able to find it and establish another calibration point.
This simple equipment is broadband and relatively unstable so a calibration point of 10.368GHz and one of say 10.365GHz will not show up as being very different on your tuning dial. However you should try to get a wide range of calibration points so that your Gunn Volts ten-turn potentiometer can be fitted with a vernier dial. A calibration chart can then be drawn.
If you are aligning two or more Gunn tranceivers, it is wise to set them up so that they can hear each other. Set up one first and then adjust the coarse frequency screw on the other, with the Gunn volts set at mid way, until you hear the tone from the first set. If and only if, the Intermediate Frequencies of each transceiver are identical (eg 30MHz) you will hear each transceiver in the other simultaneously..... in otherwords you will have duplex operation like a telephone! Using the tone oscillators will give an unmistakable beat note! In this situation the Gunn oscillator one of transceiver will be + or - 30MHz from the other transceiver, thus producing an IF of 30MHz. You cannot operate duplex if the receiver IFs are not the same.
Once the frequency range is established you should repeak each adjustable component in the transceiver to optimise the equipment around the 10.3 to 10.4GHz section of the amateur band.
It is common practice to have a VHF radio at each end of the proposed microwave path. 144MHz or 432MHz, ssb or FM, are commonly used in Europe and the USA This VHF link is the "talkback" and it is on this that both parties discuss microwave frequencies, bearings and confirm that the microwave signal is being heard. Of course you can use any talkback frequency you like but in the UK we use 144.175MHz ssb, moving off that spot frequency once talkback has been established.
When trying to establish contact under portable conditions I suggest one transceiver is set to a fixed frequency (say mid travel on the Gunn volts tuning control) and the transceiver at the other end is used to tune around until the tone is heard.
Once on site you will need to establish an accurate heading for your antenna. Horns are easier to point than dishes! For your first contact, over a few metres or so, anything will work but once you put dozens of kilometres between you and your pal you will need to point your antenna accurately. Obviously you must use a good compass to establish the direction. The bearing should be worked out in advance either by using maps or one of the excellent computer programs available.
Always work in degrees TRUE, not magnetic. Bearings derived from a map will be near enough to True Bearings. Of course when using your compass you will need to add (or subtract depending on which part of the world you live in) . In the UK the magnetic variation is around + 5 degrees in the UK at the present time (1998). However this varies around the country. Your map should have the figure printed somewhere in the margin.
The photograph on the right shows G3PHO/P,
in the summer of 1985, working over a 160km path on 10GHz wideband.
The Gunn transceiver is split into two separate units.... on the short mast
is the Gunn oscillator and diode mixer "head", feeding a small 20
inch diameter dish. On the rock below you can see the power supply/modulator/tone
oscillator and 30MHz receiver unit. The modulated Gunn voltage is fed
up to the microwave head via a short cable while a length of 50 ohm coaxial
line brings the 30MHz IF signal back to the unit below. A 30MHz preamplifier
is fitted into the head unit to provide a good match and sufficient signal to
the IF unit below. The measured Noise Figure of this system was around
8dB, quite good for a diode mixer! (Modern, narrowband 10GHz equipment is now
commonly found with Noise Figures around 1 to 2dB). To the immediate right of
G3PHO is an IC202S ssb/cw handheld transceiver for 144MHz. This was used to
established talkback. The 3 watts p.e.p and quarter wave whip antenna of the
IC202S was generally adequate over line of sight paths such as these.
This type of simple microwave and talkback gear was easy to carry up to the top of Britain's highest mountains. As narrowband has taken over from wideband as the preferred mode of operation in Europe and the UK, higher and higher power levels plus bigger and bigger antennas have become the norm for the 144MHz talkback. G3PHO/P now has to use nearly 100 watts p.e.p to an 8 element DL6WU design yagi. The 5 amp dryfit, gel battery has given way to a couple of 80 amperehour lead acid types...hardly backpack portable any more! If you build the simple wideband gear of the "old days" you can really enjoy yourself in the Great Outdoors..provided you have a like-minded friend or group of friends.
Your antenna must also, initially at least, be accurately levelled. A small bubble level on top of the equipment is all that is required. If you use a tripod to mount your 10GHz gear it may already have such a level built in.
Provided you have set your antenna direction accurately and are confident that each transceiver is compatible in terms of frequency range, there is no reason why you should not have almost immediate results over a short, line-of-sight path (say 10km). Once you have had a few contacts of this kind you can then embark on increasing the distance..... who knows, you might eventually have the thrill of breaking the 100km, then the 200km "barriers"..or even more!
The rest is now up to you! You have a fascinating time ahead.... trying out bigger and better antennas, new paths, better receivers and so on. Above all, you will have joined that happy group of amateurs who build their own equipment and who are always ready and willing to share their enthusiasm and expertise with others. The thrill you will get when you make your first 10GHz QSO is like nothing else on earth!
Return to the 10GHz transceiver page
