\ãëàâíàÿ\ð.ë. êîíñòðóêöèè\...
HT220 Frequency Synthesizer
originally published 1976
by Dale Heatherington, WA4DSY
edited for webpage use by Michael Wright, KG6BFK
http://www.geocities.com/mikeht220/220synthesizer.html
Introduction
The following instructions pertain to the new board marked with the number 051776. There have been several improvements made over the old board. Most noteable is the reduction of receiver birdies and a 12 mA reduction of the power drain. Only 2 receiver birdies remain; 146.000 and 147.100 MHz. The transmitter spurious outputs are at least 5 dB better and the broad band white noise is down much more, The white noise reduction also resulted in improved receiver sensitivity. I still don’t recommend using a high power amplifier with the synthesized HT220 but if you feel the need to do so here is the formula to compute the 2 major spurs so you will at least know where your QRM is,
Upper spur =
F + ((F/9) - 15.5555) for simplex
F + ((F/9) - 15.4888) for -600 KHz
F + ((F/9) - 15.6888) for +600 KHz
Lower spur =
F - ((F/9) - 15.5555) for simplex
F - ((F/9) - 15.4888) for -600 KHz
F - ((F/9) - 15.6888) for +600 KHz
where F = operating frequency in MHz
example:
F = 146.520 MHz simplex
lower spur = 145.796
upper spur = 147.244
Another major improvement was the elimination of the two CD4011 ICs. Many people found it was hard to find CD4011s that would work right in the original circuit. That is no longer a problem since there are no CD4011s in the new circuit. Some people have ask why I used 9.10222 MHz for the reference frequency instead of 4.551111 MHz so the CD4020 reference divider would not be pushed to it’s limit. The answer is simple.... High accuracy crystals in the HC 18/U holder below 6 MHz are not available.
A word about IC sockets: You can use low profile sockets if you bond the leads that need to be soldered to the top side of the board out to the side so you can solder to them. Be careful that they don’t touch anything they should not.
Drawings
These jpeg images were scanned at 72 dpi. Print using your page setup or save and open with Photoshop.
  Parts List
Z1 CD4059AE Programmable divider
Z2 CD4046AE Phase look loop
Z3 CD4020AE 14 stage divider
Q1, Q2, Q3,
Q4, Q9, Q10, Q11
MPS3704 or 2N4401 NPN transistor
Q5, Q12 MPS3703 or 2N4403    PNP transistor
Q6, Q7, Q8 40673 RCA dual gate MOS-FET
D1 1N759 or any 12 volt 400mw zener diode
D2 MV2107 or MV2106 Motorola EPICAP tuning diode (22pF at 4V)
D3, D4, D5 1N914 or 1N4148 diode
S1 76A10 Grayhill 10 unit DIP switch
R1, R3, R10
R20, R35
1000 ohm 1/4 watt 5% resistor
R2 150 ohm 1/4 watt 5% resistor
R4, R12, R18,
R19, R21, R24,
R25, R26, R27,
R28, R29, R30,
R31, R32
100K ohm 1/4 watt 5% resistor
R5, R7, R18,
R21, R36, R38
10K ohm 1/4 watt 5% resistor
R6, R14 15K ohm 1/4 watt 5% resistor
R8, R9 2.2K ohm 1/4 watt 5% resistor
R11 180K ohm 1/4 watt 5% resistor
R13 22K ohm 1/4 watt 5% resistor
R15 100 ohm 1/4 watt 5% resistor
R16, R17 220 ohm 1/4 watt 5% resistor
R22 820 ohm 1/4 watt 5% resistor
R33 2.7K ohm 1/4 watt 5% resistor
R34 220K ohm 1/4 watt 5% resistor
R37 3.3K ohm 1/4 watt 5% resistor
R39, R40 470K ohm 1/4 watt 5% resistor
R41 47K ohm 1/4 watt 5% resistor
C1-C7 5-25 pF trimmer Erie 518-000-5-25 or equivalent
size: 0.220" dia. x 0.170" high
C8, C15, C27 10 uF at 20 VDC Sprague 183DR106X002D or equiv.
sub-miniature tantalum capacitor (radial leads)
C9, C16 0.01 uF at 100 VDC Disc ceramic capacitor (0.300" max dia.)
C10, C17, C21
C24, C25, C29
100 pF Disc ceramic capacitor (0.300" max dia.)
C11, C22 330 pF Disc ceramic capacitor (0.300" max dia.)
C20 10 pF Disc ceramic capacitor (0.300" max dia.)
C23 33 pF Disc ceramic capacitor (0.300" max dia.)
C30, C31, C32 22 pF Disc ceramic capacitor (0.300" max dia.)
C18, C28 0.001 uF Disc ceramic capacitor (0.300" max dia.)
C33 10 pF Disc ceramic capacitor (0.300" max dia.)
C12, C19 0.1 uF at 35 VDC Sprague 182DR104D4035H or equiv.
Sub-miniature tantalum capacitor (radial leads)
C13, C14, C26 1 uF at 25 VDC Sprague 16D105X9025BC2 or equiv.
Sub-miniature tantalum capacitor (axial leads)
L1 2.7 uH 2.7 micro henry choke or
40 turns of #36 magnet wire
wound on the body of a 1 meg ohm
1/2 watt carbon resistor.
X1 13.68888 MHz crystal
X2 15.62222 MHz crystal
X3 15.55555 MHz crystal
X4 15.48888 MHz crystal
X5 9.10222 MHz crystal
Crystals are 0.002%, 20 pF load cap. calibrated at room temp. HC 18/U holder. Order type HA-M1 from International Crystal Mfg Co. http://www.icm.com/
Specifications
Frequency range: 146.000 to 147.995 MHz transmit and receive
Channel spacing: 5 KHz
VCO frequency
Power requirements: 12 to 15 volts at at 29 mA
Spurious outputs: 45 dB below carrier
Transmitter offsets for repeaters: -600 KHz, +600 KHz, and simplex
Input/Output lead description
  1. to +600 KHz lug on transmit offset switch
  2. to simplex lug on transmit offset switch
  3. to -600 KHz lug on transmit offset switch
  4. to common lug on transmit offset switch
  5. Audio input. Connect to wiper of the IDC control in the HT 220.
  6. PTT (+14.6 transmit, gnd for receiver. Connect this lead to point M in the transmitter power distribution circuit of the HT 220.
  7. VCO drive for the receiver. Connect to emitter of receive 1st osc. transistor. *
  8. VCO drive for the transmitter. Connect to base of 1st tripler transistor. *
  9. Power input from battery.
     GND. Connect a wire between the synthesizer ground and the HT 220 ground.
     * See interface diagrams for details
Construction Hints
Because of the high parts density of this circuit, the procedures outlined below should be followed.
  1. Use a low wattage soldering iron with a small tip and #24 or smaller gauge solder.
  2. Since the holes in the circuit board are not plated thru, you must solder the narts on both the top and bottom of the board where necessary.
  3. The order in which the parts are installed is important because some parts overlap others. Install all the feed-thru wires first. Next install the dip-switch on the bottom of the board and solder it in place. Be sure it will be right side up when the board is installed in the radio. Put in all of the transistors next. Q1, 3, 4, 8, 9, 10 and 12 need one or more leads soldered to the top of the board. The remaining parts can be installed in any order but the three ICs should be put in last. IC sockets can NOT be used because some pins need to be soldered on top of the board.
  4. The VCO coil is a 2.7 uH inductor. You can wind it yourself if you prefer.
    1. Select 1/2 watt carbon resistor greater than 1 meg-ohm with a straight smooth body.
    2. Cut a shallow notch in each end with a triangle file as illustrated.
      2.7 uH inductor illustration
    3. Cut a 19 inch piece of #36 magnet wire and remove 1 inch of insulation from each end.
    4. Wind 40 turns close spaced in a single layer on the resistor body and solder both ends of the coil to the resistor leads.
    5. Coat the finished coil with lacquer to secure the windings.
    6. Install the coil on the circuit board as illustrated below.
    inductor installation illustration
  5. The transmit offset switch is a 3 position rotary switch that replaces the original "PL" switch. Some PL switches can be modified for 3 positions by removing a stop in the switch. Check the top of your switch for a pin which could be moved or removed.
  6. The synthesizer can only be installed in the long omni housing with the privateline board and all other accessories removed. The extention sleeve must be modified by cutting out the antenna sheath and all other mounting tabs around the edges. The antenna cannot be fully collapsed when the synthesizer is installed. A rectangular hole must be out in the back for the frequency select switch. These modifications can be done with an Xacto knife and a mototool.
  7. Wiring between the radio and the synthesizer should be done with #26 or #28 gauge stranded wire.
  8. The parts near the VCO coil should be glued down to prevent vibration from modulating the VCO.
synthesizer block diagram
Test and Alignment
Test equipment needed:
Note: It is better to do preliminary test and alignment before you connect the synthesizer to the radio. It can prevent trouble later on if you locate any "bugs" now.
Reference oscillator adjustment
  1. Connect 15 volts to the board. + to point I, - to the ground foil.
  2. Connect the frequency counter lead thru a 20 pF capacitor to pin 10 on Z3, the CD4020.
  3. Adjust C5 for 9.10222 MHz.
VCO and offset oscillator adjustments
  1. Connect the frequency counter lead to point H (xmit drive).
  2. Connect the VTVM to the + side of C14 (1 uF).
  3. Set S1 (freq. select switch) to 147.000 MHz.
  4. If the board is not in the radio, connect point F (ptt) to +15 volts. This puts the synthesizer in transmit mode. If the board is in the radio you must key the transmitter.
  5. Connect a temporary jumder wire from point D to point B. This puts the synthesizer in simplex mode.
  6. Turn on the power and adjust C7 for a 5 volt reading on the VTVM. If you get the 5 volt reading at this time all of the circuits are working ok.
  7. Adjust C3 for 16.33333 MHz VCO frequency.
  8. Remove the jumper from point b and connect it to point A. This puts the synthesizer in +600 KHz mode. Adjust C2 for a VCO frequency of 16.4000 MHz.
  9. Remove the jumper from point A and connect it to point C. This puts the synthesizer in -600 KHz mode. Adjust C4 for a VCO frequency of 16.26666 MHz,
  10. Remove the jumper from point P to + 15, Connect the jumper from point F to ground. This puts the synthesizer in receive mode.
  11. Adjust C6 for a 5 volt reading on the VTVM. Adjust C1 for a VCO frequency of 14.4666 MHz.
Alignment is now complete and the synthesizer can now be installed. In the radio, some of the trimmer capacitors may need to be touched up after it is in the radio. Below is a list of the trimmers and their function,
NOTE: If you have trouble with any of the test and alignment steps cheek for a 555.555 Hz square wave at pin 3 on Z3, CD4020. Some 4020s won’t work at 9.1022 MHz. If you have an input on pin 10 of this IC but no output on pin 3 you need to try another one.
How to use the binary frequency select switch
This switch consist of 10 spst switchs numbered 1 thru 10. In the following discussion an "ON" switch will be called 1 and an "OFF" switch will be called 0. The frequency is entered directly in BCD code.
Switch #1 is the MHz select switch: 0 = 146.XXX MHz, 1 = 147.XXX MHz
Switches #2, 3, 4, 5 are the 100 KHz select switches. They are BCD coded and can select any digit from 0 to 9.
Switches #6, 7, 8, 9 are the 10 KHz select switches. They are also BCD. coded and can select any digit from 0 to 9.
Switch #10 is the 5 KHz select switch. 0 = 14X.XX0, 1 = 14X.XX5
Note: The following is in courier font so the numbers should align in proper columns.
Caution, when operating above 147.400 MHz be sure the transmit offset switch is in simplex or -600 KHz. If not the transmitter will transmit at 148 MHz or above.
Photo of DIP switch in back of a HT220 (image from a eBay item)
Feedback is desired (suggestions, comments, errors, gripes, whatever) Michael Wright, KG6BFK, mfwright@batnet.com
© 2001 - YO5OFH, Csaba Gajdos
Âîçâðàò
