1.2-30V/1.5A variable regulated power supply
Parts List
BR1 = Bridge Rectifier, 100V - 3A C1 = 2200 µF, 63V IC1 = LM317, adjustable regulator C2 = 0.1 µF V = Meter, 30V, Ri = 85 ohm C3 = 1µF, 40V TR1 = Transformer, 25V, 2A Plug = 3-wire plug & cord R1 = 18K, 5% S1 = On-Off toggle switch R2 = 220 ohm, 5% D1 = 1N4001 R3 = 27K, 5% Fuse = 110V, 500mA, slow-blow P1 = 5K, potentiometer FuseHolder, wire, solder, case, knob for P1 P2 = 10K, 10-turn trim-pot Red & Black Banana Jacks
Some Notes: This is a simple, but low-ripple powersupply, and an excellent
project if you're starting out in electronics. It will suit your needs for most
of your bench testing and prototype applications. The output is adjustable from
1.2 volts to about 30 volts. Maximum current is about 1.5 amps which is also
sufficient for most of your tinkering. It is relatively easy to build and can
be pretty cheap if you have some or all the required parts. A printed circuit
board is not included and I'm not planning on adding one since the whole thing
can easily be build on perferated or vero board. Or buy one of Radio Shack/Tandy's
experimentors boards (#276-150). Suit yourself. The meter and the transformer
are the money suckers, but if you can scrounge them up from somewhere it will
reduce the cost significantly. BR1 is a full-wave bridge rectifier. The two
'~' denotes 'AC' and are connected to the 25vac output coming from the transformer.
IC1 is a 3-pin, TO-220 model. Be sure to put a cooling rib on IC1, at it's max
1.5 A current it quickly becomes very hot...
All the parts can be obtained from your local Radio Shack or Tandy store. The
physical size of the power supply case depends largely on the size of the meter
& transformer. But almost anything will do. Go wild.
Circuit Description: The 110V-AC coming from the powercord is fed to
the transformer TR1 via the on-off switch and the 500mA fuse. The 30vac output
(approximately) from the transformer is presented to the BR1, the bridge-rectifier,
and here rectified from AC (Alternating Current) to DC (Direct Current). If
you don't want to spend the money for a Bridge Rectifier, you can easily use
four general purpose 1N4004 diodes. The pulsating DC output is filtered via
the 2200µF capacitor (to make it more manageable for the regulator) and
fed to 'IN'-put of the adjustable LM317 regulator (IC1). The output of this
regulator is your adjustable voltage of 1.2 to 30volts varied via the 'Adj'
pin and the 5K potmeter P1. The large value of C1 makes for a good, low ripple
output voltage.
Why exactly 1.2V and not 0-volt? Very basic, the job of the regulator is two-fold;
first, it compares the output voltage to an internal reference and controls
the output voltage so that it remains constant, and second, it provides a method
for adjusting the output voltage to the level you want by using a potentriometer.
Internally the regulator uses a zener diode to provide a fixed reference voltage
of 1.2 volt across the external resistor R2. (This resistor is usually around
240 ohms, but 220 ohms will work fine without any problems). Because of this
the voltage at the output can never decrease below 1.2 volts, but as the potentiometer
(P1) increases in resistance the voltage accross it, due to current from the
regulator plus current from R2, its voltage increases. This increases the output
voltage.
D1 is a general purpose 1N4001 diode, used as a feedback blocker. It steers
any current that might be coming from the device under power around the regulator
to prevent the regulator from being damaged. Such reverse currents usually occur
when devices are powered down.
The 'ON' Led will be lit via the 18K resistor R1. The current through the led
will be between 12 - 20mA @ 2V depending on the type and color Led you are using.
C2 is a 0.1µF (100nF) decoupler capacitor to filter out the transient
noise which can be induced into the supply by stray magnetic fields. Under normal
conditions this capacitor is only required if the regulator is far away from
the filter cap, but I added it anyway. C3 improves transient response. This
means that while the regulator may perform perfectly at DC and at low frequencies,
(regulating the voltage regardless of the load current), at higher frequencies
it may be less effective. Adding this 1 µF capacitor should improve the
response at those frequencies.
R3 and the trimmer pot (P2) alows you to 'zero' your meter to a set voltage.
The meter is a 30Volt type with an internal resistance of 85 ohms. I you have
or obtained a meter with a different Ri (internal resistance) you will have
to adjust R3 to keep the current of meter to 1mA. Just another note in regards
this meter, use the reading as a guideline. The reading may or may not be off
by about 0.75volts at full scale, meaning if your meter indicates 30 volts it
may be in reality almost 31 volts or 29 volts. If you need a more precies voltage,
then use your multimeter.
Construction: Because of the few components you can use a small case
but use whatever you have available.
I used a power cord from a computer and cut the computer end off. All computer
power cords are three-prong. The ground wire, which is connected to the middle
pin of the power plug is connected to the chassis. The color of the ground-wire
is either green or green/yellow. It is there for your protection if the 110vac
accidentally comes in contact with the supply housing (case). BE CAREFUL always
to disconnect the powerplug when you working inside the chassis. If you choose
to use an in-line, or clip-type fuseholder be sure to isolate it with heat shrink
or something to minimize accidental touching.
I use perf-board (or Vero board) as a circuit board. This stuff is widely available
and comes relatively cheap. It is either made of some sort of fiber material
or Phenolic or Bakelite pcb. They all work great. Some Phenolic boards come
with copper tracks already on them which will make soldering the project together
easier.
I mounted the LM317(T) regulator on a heatsink. If you use a metal/aluminum
case you can mount it right to the metal case, insulated with the mica insulator
and the nylon washer around the mounting screw. Note that the metal tab of the
LM317 is connected internally to the 'Output' pin. So it has to be insulated
when mounting directly to the case. Use heat sink compound (comes in transparent
or white color) on the metal tab and mica insulator to maximize proper heat
transfer between LM317 and case/ or heatsink.
Drill the holes for the banana jacks, on/off switch, and LED and make the cut-out
for the meter. It is best to mount everything in such a way that you are able
to trouble-shoot your circuit board with ease if needed. One more note about
the on-off switch S1, this switch has 110VAC power to it. After soldering, insulate
the bare spots with a bit of silicon gel. Works great and prevents electrical
shock through accidental touching.
If all is well, and you are finished assembling and soldering everything, check
all connections. Check capacitors C1 & C3 for proper polarity (especially for
C1, polarity reversal may cause explosion). Hookup a multimeter to the power
supply output jacks. Set the meter for DC volts. Switch on S1 (led will light,
no smoke or sparks?) and watch the meter movement. Adjust the potentiometer
until it reads on your multimeter 15Volts. Adjust trimpot P2 until the meter
also reads 15volts. When done, note any discrepancies between your multimeter
and the power supply meter at full scale (max output). Maybe there is none,
maybe there is a little, but you will be aware of it. Good luck and have fun
building!
