DJ-280T
SPECIFICATIONS 222.000 ~ 224.995MHz Hand-Held Transceiver | ||
GENERAL | |
Frequency Coverage MHz | (RX) 220.000 ~ 224.995 MHz (TX) 222.000 ~ 224.995 MHz | |
Channel Spacing | 5, 10, 12.5, 15, 20, 25KHz steps | |
Memory Channels | 10 channels standard, expandable to 50 or 200 | |
Antenna Impedance | BNC connector 50 Ohms Unbalance | |
Frequency Stability | +/-10 ppm | |
Microphone Input Impedance | 2K Ohms Nominal | |
Signal Type | F3E (NFM) | |
Power Supply Requirements | 6.0 ~ 13.8 VDC | |
Operating Tempature | -10 to +60 Degrees Celsius 14 to 140 Degrees Fahrenheit | |
Ground | Negative | |
Dimensions | 5.2in X 2.2in X 1.3in | |
Weight | Approx. 12.35 oz | |
Sub Audible Tones | Encoder / Decoder Installed (38Tones) 67 ~ 250.3 Hz | |
TRANSMITTER | ||
Output Power | High: 4 watts (12VDC input) Low: 1 watt (7.2VDC input) | |
Emission Mode | F3E (NFM) | |
Modulation System | Variable Reactance FM | |
Max. Freq. Deviation | +/- 5KHz | |
Spurious Emission | -60dB Or Under Below Carrier Level | |
Microphone | Electret Condenser | |
Operating Mode | Simplex/Semi Duplex 5KHz Steps Minimum Between 0-15.995MHz | |
CTCSS Encoder / Decoder | Built-In And Included As Standard | |
RECEIVER | ||
Receiver System | Super Heterodyne Dual Conversion | |
Sensitivity | 12dB SINAD : Less Than -10dBu ( 220.000 ~ 224.995 MHz ) | |
Squelch Sensitivity | Less Than -10dBu | |
Intermediate Frequency | 1st IF: 30.850 MHz; 2nd IF: 455 KHz | |
Selectivity | More Than +/- 7.5KHz at -6dB | |
Audio Output | More Than 250mW @ 10% THD | |
Speaker Impedance | 8 Ohms | |
*All specifications and features are subjected without notice or
obligation.
*Specifications are guaranteed for the amateur band
only.
*Permits required for MARS/CAP use.
DJ-280T ACCESSORIES | |
EBP-24N | 7.2VDC 1200mAH NiCad |
EBP-26N | 7.2VDC 700mAH NiCad |
EBP-28N | 12VDC 700mAH NiCad |
EDH-11 | Dry cell case (6 AA cell) |
EDH-12 | 12VDC car lighter power adapter |
EDC-49 | 117VAC wall charger |
EDC-45 | 117VAC quick charger |
EME-04 | Earphone Mic |
EME-12 | Headset with VOX Mic (Earpad Type) |
EME-13 | Headset with VOX Mic (Earphone Type) |
EME-15 | Tie-Pin VOX Mic and Earphone |
EMS-9Z | Speaker Mic |
ESC-18 | Softcase for use with EBP-26N |
ESC-19 | Softcase for use with EBP-28N |
EJ-14U | 50 channel memory unit |
EJ-15U | 200 channel memory unit |
EBC-06 | Mobile Bracket |
