\ãëàâíàÿ\ò.õ. ðàäèîñòàíöèé\... |
Alinco DJV5T/TH/TDC/TDCH
VHF/UHF Dual Band FM
Handheld-Transceiver
Alinco combines high quality, great
performance, versatile features and compact size in an exciting new radio, the
DJ-V5T/E.
Power | Up to 5 watts output, 3 output settings |
Alphanumeric Display | Easy recall of repeaters or simplex channels, up to 6 characters |
Wide Receive Range | Expanded receive capability delivers coverage from 76 ~ 999.995 MHz!* |
Wide FM Receive | Experience quality audio when receiving wide FM signals |
200 Memory Channels | Plenty of memory to use any way you wish. Save band, frequency, offset, CTCSS, transmit output level, tuning step, DSQ and alphanumeric channel name. |
Enhanced Repeater Operations | CTCSS encode+decode, plus selectable tone bursts (1000, 1450, 1750, 2100 Hz) |
DTMF Tone Squelch (DSQ) | Allows creation of call groups free of distracting traffic. |
Temperature Protection | Reduces output power when internal temperatures are too high. |
Cable Cloning | Program multiple DJ-V5 units from a "master" unit. |
Multiple Scan Modes | Use the wide-range receive capabilities of the DJ-V5 to their full advantage. |
Model | Ni-Cd battery | Dry cell case | EDC-93 Charger |
DJ-V5T | EBP-45N black | none | Yes (Black body/standard Ni-cd) |
DJ-V5TH | EBP-46N black (high) | none | Yes (Black body/standard Ni-cd) |
DJ-V5TDC | none | EDH29C clear | none (Clear body/Clear dry cell case) |
DJ-V5TDCH | EBP-46N black (high) | EDH29C clear | Yes(Clear body/Hi NiCd+Clear D.C.case) |
* EDH29 black dry cell case is NOT a
standard accessory for any model. * Specifications of the unit are the same. * The following are standard for all "T" versions: Antenna, belt-clip,hand-strap, instruction manual, and warranty card. Sorry there has been a typographical error on the standard accessory list page of the instruction manual. Please disregard if you may find it (An Errata sheet is inserted for clarification now and it will be corrected from the next print). |
