IC-T81A
6 Meter/2 Meter/440 MHz/1.2 GHz, All in One Hand
Worlds First Quad Band HT. Easy to Use!
The IC-T81A is water resistant to JIS 4 standards
Add the wide-open microwaves to your fun. The 1.2 GHz band is very popular in metro areas.
- Compact size: 2.3 (W), 4.2 (H), 1.1 (D), 9.9 oz
- Transmit on 6 meters, 2 meters, 440 MHz, and 1.2 GHz ham bands
- Up to 5 watts of power @13.5 V DC (1 watt on 1.2 GHz)
4.5 watts out of the box with supplied BP-200 battery
- Wide band receive:
- 50-54 MHz (6 meters), 74 - 174 MHz (2 meters), 400 - 470 MHz (440 MHz band) and 1240 - 1300 MHz (1.2 GHz band)
- Broadcast FM receive (some TV stations, too)
- Airband receive
- Reception guaranteed on US ham bands only
- Ni-MH powered:
- Longer operating times than with Ni-Cd cells
- Compact size keeps the weight down, and provides slim profile
- Back mounting offers good radio balance -- feels comfortable in the hand
- Excellent audio output:
- Broadcast FM and AM receive (most TV stations, too)
- Airband receive
- RIT/XIT (/VXO) for 1.2 GHz:
- Tunable range of ±5 kHz in 1 kHz steps
- Multi-function "joystick" switch:
- change bands
- cruise menu options
- set modes
- Rugged ICOM construction:
- Die-cast aluminum chassis
- JIS grade 4 water resistance
- 124 memory channels with 10 scan edges and 1 call for each band
- Tone squelch (CTCSS encode) with pocket beep
- Tone scan (CTCSS Decode)
- DTMF encoder, 9 memories
- Backlit display with timer
- Battery voltage indicator
- Built in guide function
- Wall charger included
- Handheld to handheld cloning capability (opt. OPC-474 cloning cable)
or PC programming capability (opt. CS-T81 cloning software and OPC-478 cloning cable)- Optional battery case available -- BP-197
©1997-1999 ICOM America, Inc. The ICOM logo is a registered trademark of ICOM, Inc. All specifications are subject to change without notice or obligation. All ICOM radios significantly exceed FCC regulations limiting spurious emissions.
