1. |
2. |
3. |
4. |
5. |
With high power output, superb ergonomics and Yaesu's unique know-how in designing elite-class HF equipment, the MARK-V FT-1000MP will be utilized by DX and contest champions for years to come.
Coming Soon!
copyright YAESU U.S.A. 1997 ©
Jim Garland W8ZR
(Updated June 14, 2000)
Introduced at the Dayton 2000 Hamvention, the new Yaesu Mark V/FT-1000MP transceiver is squarely aimed at the high performance contest and DX crowd. Combining the best of the venerable FT-1000D with the DSP and computer glitz of the mid-priced FT-1000MP, the Mark V is Yaesu's attempt to dominate the "elite class" market for the next decade. After swearing that I would never get rid of my beloved FT-1000D, I finally succumbed to temptation and shelled out $3269 for the basic Mark V and another $305 for two optional filters. There's still room for four more filters; however, to "load" the radio fully with filters would cost an additional $600! Here are some first impressions. |
What first catches your eye about the new Mark V is the top heatsink, which is an integral part of the cabinet. Yaesu claims the heatsink has 250% greater cooling power than the rear-mounted heatsink on the FT-1000D. Like the FT-1000D, the Mark V runs 200 watts output. Whereas the FT-1000D used bipolar power transistors, the Mark V uses a pair of Phillips BLF147 power MOSFETS. A special "Class A" mode reduces power output to 75 watts, and is claimed to reduce IMD (distortion) to lower than -50db, which would best any ham transceiver ever made. |
There's good news and bad news about the FP-29 external switching power supply The good news is that the FP-29, which provides 30V @15A and 13.8V@3A is included at no additional charge. The bad news is that the FP-29 has an irritating bottom-mounted fan (see below) which runs all the time. Though much quieter than the fan on Icom switchers, it's still audible in a quiet room. On the plus side, Yaesu provides a 2 meter long interconnecting cable, so the supply can be hidden behind the desk. |
The unusual top-mounted heatsink (right) is cooled by a novel "paddle-wheel" internal fan (below). The fan is thermostatically controlled and doesn't run all the time. |
Plan on spending nearly $900 if you want to load up your Mark V with optional filters. The main receiver takes up to five optional filters for the 2nd and 3rd IF, and the sub-receiver holds one optional filter. The Mark V uses a combination of crystal and (Collins) mechanical filters. The three filters at the bottom of the photo are supplied (the blue one is a Collins 10 pole SSB filter --the FT1000MP uses an 8-pole filter.), while a 250 Hz optional filter is at the upper right. A nice new feature: the bandwidth of the DSP filtering is automatically interlocked to the bandwidth of the selected analog filters, even when using the "width" vernier. |
Out of the Box: My first challenge with the radio was installing two plug-in optional filters. I couldn't figure out how to take the cabinet off! The instructions in the manual were wrong (probably not updated from the FT-1000MP). In short, the cabinet is in four pieces, with 23 screws of three different types. Although it was easy to plug in the filters once I got the cabinet apart, it was then a challenge putting everything back together. Two tiny screws recess into the narrow space between the heatsink fins; nursing them back into their holes required a bright light and pair of curved tweezers. My advice: ask the dealer to install the filters for you. The blue Collins 500 Hz sub-receiver filter is shown in the below photo, to the right of the TCXO oscillator module. Initializing the software for the selected filters was also confusing. More about this problem, below. | |
How's the Quality? I was generally pleased with the radio's workmanship. Although not mil-spec construction, it seems nicely engineered and layed out. Circuit boards use a combination of surface-mount and through-hole components. The top-firing internal speaker is larger than normal (3.5 in.) and sounds very good. Curiously, the thin little AC line cord (left) seems underrated for a rig that draws nearly 500 watts. I also didn't care for the cheezy interconnecting cable between the FP-29 and the radio. It uses molex-type connectors on each end of individual wires (a black sleeve holds the bundle together), with no strain-relief on the wires. Seems like for nearly four grand, you would get a nice cable with molded connectors. |
How about new features? Look closely at the right photo and you'll see "VRF" and "IDBT" on each side of the tuning knob, underneath the TX and RX LEDs. The VRF "Variable RF" button activates a manually-tuned front-end preselector, which one tweaks for maximum signal, just like us old-timers used to do on radios from previous eras. I guess the more things change, the more they stay the same. |
IDBT stands for "interlocked digital bandwidth tracking system," which sets the radio's DSP bandwidth to that used by the cascaded crystal and mechanical filters. What's neat about this feature is that it automatically corrects for adjustments in the IF shift and IF width controls. The feature can be toggled on or off by a button to the right of the tuning knob. |
Rough
Edges: The Mark V isn't without blemishes,
many attributed to its being brand new on the market. Some of
these result from Operating Manual errors (such as the cabinet
removal instructions, noted above), some from inappropriate
default menu settings, and a few from quirky design choices.
Although frustrating, none of these in my opinion are
deal-breakers. |
On-the-Air at
Last! To get a feel
for the new rig, I tried it side-by-side (see photo below)
with an Icom IC-756PRO and a 15-year-old Signal/One Milspec
1030. First, let me dispell any notions you might have that
radios were better in the "good old days." The top-of-the-line
Signal/One just didn't cut it, receiver-wise. Compared to
either the Yaesu or Icom, the Signal/One sounded noisier on
the bands, the noise blanker didn't measure up to the others,
the selectivity wasn't as good, and it sure wasn't as
convenient to use. However, in the Signal/One's defense,
people liked its rf-processed transmit audio better than the
processed audio on the other rigs. | |
How does the Mark V stack up with
IC-756PRO?
Keep in mind that I wasn't pushing the radios to their limits,
as one might do in a pileup on 160m CW or a multi-multi
contest operation. These are impressions, not detailed
technical comparisons. |
But features don't tell the whole story!
Although the Mark V doesn't do as
much
as the 756PRO, what it does, it does brilliantly. For
instance, I checked the s-meter sensitivity on 160m, 20m, and
10m on both radios with my HP-8640 signal generator. An S-9
signal is supposed to be 50 uV. However, S-9 on the Icom
wandered between 72uV and 96uV on the three bands (no preamp).
An S-9 on the Mark V (no preamp) was exactly 50uV on all three
bands -- a minor accomplishment, admittedly, but a sign that
the designers paid close attention to
detail. |
The bottom line: We won't know for sure until QST checks out the dynamic range and 3rd order IP, but my first impressions suggest this radio will set a new standard for strong-signal performance. With filters galore (crystal, mechanical, audio, and DSP) and tuned preselectors, the Mark V ought to be the radio to beat for contesting and top-band dxing. Feature-wise, it's comparable to many other modern transceivers. The controls are intuitive and straightforward, and the DSP, NB, NR, etc., work well. (I do wish there was more flexibility in the AGC choices; it would be nice to have the time constants selectable by menu.) However, Yaesu is clearly not banking on glitz to sell this radio. The Mark V will sink or swim on the basis of its core receiver performance. If it truly is as crunch-proof as claimed, then I predict the "big gun" power users will jump on this radio as eagerly as they did on the FT-1000D, nearly ten years ago. |
