Mobile communications just got easier thanks to Kenwood's TM-261A (2m) and TM-461A (70cm) single banders -- fully equipped and supremely user-friendly.
Features at a glance:
High RF power output |
Rugged construction (MIL-STD) |
61 multi-function memory channels plus 1 call channel |
Memory Name (MN) function with 6-digit alphanumeric display |
DTSS selective calling |
Multi-scan capability |
Dual menu system |
Multi-function microphone with backlit keys |
TM-261A/461A in detail:
The TM-261A and TM-461A put out an impressive 50 watts and 35 watts, respectively. Both models also have mid- and low-power settings.
Meets MIL-STD requirements
Strict MIL-STD environmental standards for vibration (MIL-STD 810C) and physical shock (MIL-STD 810D) are fully complied with.
For quick access, essential data -- transmit and receive frequencies, frequency step, tone frequency, etc. -- can be stored in the 62 memory channels. All channels can store transmit and receive frequencies independently for odd split repeaters.
All 62 channels can be identified alphanumerically (max. 6 characters) instead of by frequency. This is particularly convenient for repeaters and club channels. It is also possible to switch to a channel number display.
Built-in DTSS (Dual-Tone Squelch System) allows DTMF access: the squelch is opened only when a specific 3-digit code has been received. Using the wildcard asterisk, group calling is also possible.
Choose from several scan modes: full band scan, programmable band scan, and memory scan with programmable memory channel lock-out. There are also 2 scan stop modes: TO (time-operated) and CO (carrier-operated).
Dual menu system
Two menu modes -- A and B -- offer full control over such settings as frequency step and the time-out timer, when required.
DTMF memory function
Up to ten 15-digit DTMF codes with ID can be stored for auto-dial and autopatch use. Redial is also provided.
Built-in CTCSS tone encoder and optional decoder
The optional decoder enables the setting of different tones for transmit and receive.
Optional backlit DTMF microphone (supplied with some versions)
This multi-function microphone has backlit keys to facilitate operation in low-light situations.
Other Features:
Tone scan |
Wireless cloning function |
Auto repeater offset (TM-261A) |
Repeater reverse switch |
Lock function |
Busy channel lockout |
Auto power-off |
Time-out timer |
Dimensions (W x H x D)
140 x 40 x 160.5 mm (5.51 x 1.57 x 6.31 in.) |
Operation of DTSS, Pager, DTMF, and CTCSS is subject to local regulations. |
