A Universal Programming Cable for Radios
The programming cable is intended to be used with a computer RS-232 port for programming radios and other devices. The main goal of this cable schematics is the invertion of signal levels. That is because the COM port's logic one is a low voltage level, logic zero is a high voltage level. Another goal is the correct voltage level transformation with regard to the real radio programming circuits. And nothing must get burnt...
Schematic diagram
Programmer schematics
Connection circuits (jacks for mobile radios are shown as they are plugged into sockets)
KENWOOD connectors
VERTEX/YAESU connectors
MOTOROLA connectors
MAG ONE connector MAG ONE jack
ICOM connectors
MAXON connector TAIT connector
TAIT connector
STANDARD connector VECTOR connector DRAGON connector
GRANIT1 connector GRANIT2 connector
ALTAVIA connector HYT connector ALAN HM-200 connector
SRM-9000 connector
Phone connector
GP-340 connector (draft by K. Bokhanov)
GP-340 connector
VT1, VT3, VT4 transistors may be BC847 or similar (i.e. BC547B, etc.), VT2 may be BC857 or similar (i.e. BC557B, etc.). Fast silicon diodes of any type will do, for example 1N4148 or LL4148 in MiniMELF case. LP2950 is replaceable with LM2951 with appropriate resistors, 78L05 is the worst choice due to it's own high current consumption. It may fail to work in some cases. Use 78L05 with an external power source.
Cable for RRxD and RTxD connections should be shielded. Multiwire cable with low mutual capacitance among wires is also applicable. Otherwise TxD to RxD interference will result in programming failure. It is important for some KENWOOD radios.
It is convenient to use an additional connector to attach particular radio jacks to the programming cable. DB9 is recommended as a highly reliable one.
Cable connection to KENWOOD portable radios has a specific feature. Radio sockets have prominent rubber rings, thus standard stereo jacks cannot be plugged in firmly. The jack flanges should be ground off till 5 mm in diameter. The jack cases should be cut accordingly.
TK-353 radios are put in the program mode by holding the side button below PTT and C button while powering the radio on. Hold the buttons until "--PC--" appears on its display. TK-250 enters programming mode by pressing Lamp and Lo buttons while turning the radio on.
In MOTOROLA GP300 connector use 2 Ampere diode if you intend to transmit with the cable connected or 1 Ampere diode otherwise. In MOTOROLA P040-P080 connector grind off the jack flange until the jack can be seated firmly. This connector does not need an external power supply if it is provided from the port by a programming software.
MOTOROLA mobile CM series radios are programmed through the rear accessory connector. The programming cable is not powered from the port. The power supply can be taken from the radio power supply or the accessory connector if available. The corresponding programming cable connector was designed by Vadim UA9MIR
MOTOROLA mobile CM series radios may be also programmed through the front mic socket. The programming cable is powered from the radio socket. The corresponding programming cable connector was designed and tested by Belu Daniel (Romania).
In MOTOROLA GP-340 connector the output voltage is limited to approximately 3 Volts. The specific jack is used, it is shown on the figure.
MOTOROLA MAG ONE radios are programmed with the specific connector with different transmit and receive data lines. To be firmly inserted in the socket, the 2.5 mm stereo jack tip should be ground off as shown in the photo. Jacks before and after the modification are shown. The photo is provided by Alexander 'Gulliver'.
VERTEX VXR-5000 and VXR-7000 programming software works improperly on modern computers with fast processors. Computers with i80486 are recommended by VERTEX, iCeleron 433 MHz processor may be also applicable.
An unusual connector is needed for KENWOOD TK-690/790/890 radios. The common data transmission and reception line is used.
The cable can be used as a CAT interface for tranceiver control. This cable connector includes separate Tx and Rx data lines and a power supply from the radio.
Alexander Nesterov has designed the TAIT T2000 series radio connector. The main idea is the additional level invertion using a CMOS logic IC. CD4093 is recommended because it has Schmitt trigger inputs. However, any CMOS invertor can be used. Unused IC inputs (not outputs !) should be grounded.
Alexander Nesterov has also designed the programmer schematics enhancements (VD8 and R13) and a specific connector to program MAXON SL500 radios. The programmer is used as a non-inverting buffer. In SL500 connector VD1 and VD2 diodes provide an extra protection of the radio. They can be omitted if desired.
Oleg EX8MLT has proposed HYT TC-500 radios connector. It is different from KENWOOD portables connector which is used for other HYT radios. Both jacks should be plugged in simultaneously.
Alexander Ivanov has designed a connector to ALTAVIA radios. These radios are designed and manufactured in Russia. The connector is similar to MOTOROLA P040/P080 portables connector but needs no external power supply.
Alexander UA9CEE has designed a connector to STANDARD GX-2000 radios. The radio should be programmed with slow computers (recommended processor rate 166 MHz or less) under MS DOS.
Valery UA6LPG has designed a connector to Russian Granit-202 radios. Programmer schematics is classic. The radio is put into programming mode by holding 'Phi' button while powering on.
Yuri US5IVZ has designed a connector to DRAGON SY-5430 programmable radios. It should be linked to the microphone connector.
Federico Menthe (Argentina) has modified the TAIT radios connector. Now it is capable to program T3000 series handheld radios.
Vladimir Vashchenko has designed a connector schematics for VERTEX VX-800, VX-4000, VX-6000, etc. These radios have a specific accessory connector.
Vladislav Bashaev has designed a connector schematics for ICOM IC-31G/41G.
Alexander 'Gulliver' has proposed the connector for the VECTOR VT-44 MILITARY portable LPD radio.
Roman RN3ADR with the author's participance has designed the connector for SIMOCO SRM-9000 series radios. Before programming the radio must be turned on. To do so push and hold SW1 button until HL1 LED switches on. After programming turn the radio off by holding the button until the LED switches off. Now you may disconnect the programming cable from the radio.
Valery UA9MRQ has proposed the connector for the russian GRANIT 2P-21 mobile radio.
Yury US5IVZ has proposed the connector for ALAN HM-200 radio.
Georgy RN3ZNL and Dmitry RN3ZQL have tested the programming cable attached to a computer via a COM - USB2.0 converter with the appropriate driver under Windows XP. In this case a DOS programming software seems to work correctly with the emulated serial port (various DOS softwares for MOTOROLA mobile radios were tested). Also the data exchange speed for DOS programs via the emulated port is notably higher then via the standard serial port under Windows XP. Modern high speed computers vere used in those tests.
A connection to devices with a non-standard processor supply voltage (cordless and cellular phones) requiers a special connector. A TxD key power is taken from the phone, so the input logic levels cannot exceed the processor supply voltage. For example SENAO SN-258 is attached by its test connector in this way: TxD - cont. 1, RxD - cont. 2, GND - cont. 3, Vbat - cont. 5. R1 resistor may be omitted because the phone RxD circuit has an inner 47 kOhm resistor to the ground.
The cellular phones connector can be used for applying AT-commands or firmware replacement. There are no hardware flow control circuits in the connector. The Siemens specific connector is shown. Use it for AT-commands with the switch turned off, for firmware downloading with the switch turned on. The Siemens phone socket pinout is from www.pinouts.ru. For more information please search specific cell phone sites.
The programming cable printed circuit board (97.2 kB) was designed by Valery UA6LPG with non-chip components. In order to print it save the GIF image to disk. Then open the GIF file with Adobe Photoshop (or any other editor) and change the image resolution to 600 dpi (look for at Image/Image size). Print it, it will be of the right size.
Please note that Rind resistor and a LED are used just to indicate the power supply voltage. You can omit R12, Rind and a LED, the circuit will work. Some words are in Russian, the most significant words are translated. The recommended value of Rind is 4.3 kOhm to minimize the current consumption, the LED will glow slightly.
The programming cable was tested with 336 device types, i.e.
Device (radio) type
Checked by
Recommended software Connector
KENWOOD
TM-V7 Igor RA0FMF MCP-V7 ver 1.01 KEN-1A
TK-250 Valery UA6LPG, Belu Daniel (Romania), Norman Miller CX1ANM (Uruguay), Victoria Chernigovskaya KPG-23D KEN-2
TK-259 Robert PE1CWU KPG-32D KEN-2
TK-260G Valery UA6LPG, Vladimir Fiodorov KPG-56D KEN-2
TK-270 Alexander UA4LOR, Belu Daniel (Romania), Nikolay aka 'KOKA', Norman Miller CX1ANM (Uruguay), Yevgueny UR5LIS, Alexander UR5TID KPG-27D KEN-2
TK-270G Serguey RU3VV, Gorodnov, Nikolay Novakov, Albina Luchaninova, Vladimir Fiodorov, Norman Miller CX1ANM (Uruguay), Yevgueny Novik, Igor Saprykin, Ramil Yunusov, Zinnur Nigmatulin KPG-56D KEN-2
TM-271 Marat (Dushanbe), Victor from Alma-Ata, Zinnur Nigmatulin MCP-1A KEN-1B
TK-272 Norman Miller CX1ANM (Uruguay) KPG-27D KEN-2
TK-272G Norman Miller CX1ANM (Uruguay) KPG-56D KEN-2
TK-278 Yevgueny RA9MHL, Igor Marzaganov, Alexander Nesterov, Lahodni Stefan (Romania), Denis Alafinov, Nikolay UT5VF, Yury RA9SVD, Nikolay aka 'KOKA', Ramil Yunusov, Serguey Olar, Oleg RN3AUM, Boris Martynov, Alexey EW7AT KPG-27D KEN-2
TK-350 Alexander UA9CEE, Serguey UA0CIC, Norman Miller CX1ANM (Uruguay) KPG-23D KEN-2
TK-353 the author KPG-26D KEN-2
TK-360 the author KPG-27D KEN-2
TK-360G the author, Ramunas Majauskas KPG-56D KEN-2
TK-370 Alexander 'Gulliver', Igor UU8JA, Norman Miller CX1ANM (Uruguay) KPG-27D KEN-2
TK-370G Serguey UA9UDQ, Norman Miller CX1ANM (Uruguay), Ramil Yunusov KPG-56D KEN-2
TK-372 Norman Miller CX1ANM (Uruguay) KPG-27D KEN-2
TK-372G Norman Miller CX1ANM (Uruguay) KPG-56D KEN-2
TK-378 the author, Denis Alafinov, Yury RA9SVD, Ramil Yunusov, Oleg RA9JM, Alexander UR5TID, Oleg RN3AUM, Mikhail aka Neptun KPG-27D KEN-2
TM-471 Marat (Dushanbe) MCP-1A KEN-1B
TK-480 Alexander UA9CEE KPG-35D KEN-4
TKR-750 Ramil Yunusov, Serguey Olar KPG-66D, KPG-91D KEN-1B
TK-752E Belu Daniel (Romania) KPG-28D KEN-1A
TK-759 Alexander 'Gulliver' KPG-28D KEN-1A
TK-760 Alexander UA9CEE, Andrey Kolennikov, Viktor UN1EAE, Belu Daniel (Romania), Ramil Yunusov, Serguey Olar KPG-29D KEN-1A
TK-760G Andrey Kolennikov, Vladimir UA9FIA, Yevgueny Novik, Alexander UR5TID, Roman RV3SBQ, Roman RN3ADR, Serguey Olar, Zinnur Nigmatulin KPG-56D KEN-1B
TK-760G 5-tone Belu Daniel (Romania) KPG-67D KEN-1B
TK-760H Alexander Nesterov, Roman RV3SBQ KPG-29D KEN-1A
TK-760HG-1 Serguey UA9UDQ, Vladimir Vashchenko, ALEKSEY30, Alexey Gordeyko, Alexander UA9CEW, Viktor UN1EAE, Alexander UR5TID KPG-56D KEN-1B
TK-762G 5-tone Belu Daniel (Romania) KPG-67D KEN-1B
TK-768 Ramil Yunusov, Serguey Olar KPG-29D KEN-1A
TK-768G Albina Luchaninova KPG-56D KEN-1B
TK-768H Ramunas Majauskas, Mikhail aka Neptun, Boris Martynov KPG-29D KEN-1A
TK-809 Alexander 'Gulliver' KPG-20D KEN-1A
TK-840 the author, Alexey RZ3AIQ, Roman RN3ADR, Scott Zimmerman N3XCC KPG-25D KEN-1A
TKR-850 the author, Ramil Yunusov KPG-66D, KPG-91D KEN-1B
TK-860 MALE aka Dmitry, Ramil Yunusov, Oleg RA9JM, Alexander Nesterov KPG-29D KEN-1A
TK-860G-1 the author, MALE aka Dmitry KPG-56D KEN-1B
TK-860H the author KPG-29D KEN-1A
TK-862G-1 5-tone Ramunas Majauskas KPG-67D KEN-1B
TK-868 Ramil Yunusov, Alexander Nesterov KPG-29D KEN-1A
TK-880 Serguey Bunin KPG-49D KEN-1B
TK-880-3 (MT) the author KPG-60D KEN-1B
TK-890 Alexander 'Gulliver' KPG-44D KEN-3
TK-2102 Norman Miller CX1ANM (Uruguay), Ramil Yunusov KPG-55D KEN-2
TK-2106Z Alexander Ivanov KPG-55D KEN-2
TK-2107 Vladimir Yasakov, the author, Serguey UA9UDQ, Ivan UX7MX, Igor Marzaganov, Alexander UA4LOR, Serguey EW6GC, Vladimir Vashchenko, Andrey RV4HV, ALEKSEY30, MALE aka Dmitry, Alexander Nesterov, Dmitry EW3BX, Igor UU8JA, Denis Alafinov, Igor UR5YEI, Nikolay UT5VF, Vladislav Bashaev, Yevgueny UR5LIS, Roman RN3ADR, Ramil Yunusov, Serguey Olar, Serguey Cherkasov, Zinnur Nigmatulin, Oleg RN3AUM, Alexey EW7AT, Victoria Chernigovskaya KPG-55D KEN-2
TK-2118 Alexander 'Gulliver' KPG-69D KEN-2
TK-2160 Nikolay Novakov, Alexander Nesterov, Lahodni Stefan (Romania), Belu Daniel (Romania) KPG-82D KEN-2
TK-2170 Ramil Yunusov, the author KPG-101D KEN-2
TK-2200 Serguey Bunin KPG-88D KEN-2
TK-2202 Norman Miller CX1ANM (Uruguay) KPG-87D KEN-2
TK-2202L Norman Miller CX1ANM (Uruguay) KPG-87D v.2.3 KEN-2
TK-2206 Serguey Bunin, Alexander Nesterov, Nikolay Strokinov, Serguey Cherkasov, Andrey Shunko, Victoria Chernigovskaya KPG-87D KEN-2
TK-2207 Serguey Bunin, Denis Alafinov, Jaco Le Roux (South Africa), Paolo IW3SQM, Zinnur Nigmatulin, Victoria Chernigovskaya KPG-87D KEN-2
TK-2212 Norman Miller CX1ANM (Uruguay) KPG-100D KEN-2
TK-3101 Alexander 'Gulliver' KPG-48D KEN-2
TK-3102 Norman Miller CX1ANM (Uruguay), Ramil Yunusov KPG-55D KEN-2
TK-3107 Loay Jawad (Iraq), Roman RN3ADR, Igor Popov, Ramil Yunusov, Zinnur Nigmatulin, Oleg RN3AUM, Doychin LZ3DA, Alexey EW7AT, Andrey Shunko, Alexander Nesterov KPG-55D KEN-2
TK-3118 Alexander 'Gulliver' KPG-69D KEN-2
TK-3160 Serguey Bunin, the author KPG-82D KEN-2
TK-3168 Serguey Bunin KPG-82D KEN-2
TK-3170 the author, Ramil Yunusov KPG-101D KEN-2
TK-3200 Serguey Bunin KPG-88D KEN-2
TK-3202 Nikolay aka 'KOKA', Norman Miller CX1ANM (Uruguay), Alexander 'Gulliver' KPG-87D KEN-2
TK-3202L Norman Miller CX1ANM (Uruguay) KPG-87D v.2.3 KEN-2
TK-3206 Serguey Bunin, the author, Nikolay aka 'KOKA', Igor Saprykin, Serguey Olar, Andrey Shunko, Alexander Nesterov KPG-87D KEN-2
TK-3207 Serguey Bunin, Alexander 'Gulliver' KPG-87D KEN-2
TK-3212 Norman Miller CX1ANM (Uruguay) KPG-100D KEN-2
TK-3217 Alexander Nesterov KPG-100D KEN-2
TK-7100 Serguey Olar, Andrey Shunko KPG-80D KEN-1B
TK-7102 Zinnur Nigmatulin KPG-70D KEN-1B
TK-7108 Serguey Bunin, Viktor UN1EAE, Igor Saprykin, Ramil Yunusov, Serguey Olar, Zinnur Nigmatulin KPG-70D KEN-1B
TK-7160 Serguey Bunin, Belu Daniel (Romania), Boris Martynov KPG-99D KEN-1B
TK-8102 the author, Oleg RA9JM KPG-70D KEN-1B
TK-8108 the author, Ramil Yunusov, Zinnur Nigmatulin KPG-70D KEN-1B
TK-8160 the author, Serguey Bunin KPG-99D KEN-1B
TK-8160H the author KPG-99D KEN-1B
TK-8162E Zoheir Ammar (Algeria) KPG-99D(E) KEN-1B
TK-8180 Serguey Bunin, the author KPG-89D KEN-1B
Ukrainian KENWOOD
TK-2170 (the same as TK-2107) Roman UT5ERP KPG-55D KEN-2
TK-2260 (the same as TK-2206) Alexander Nesterov, Serguey Olar, Andrey Shunko KPG-87D KEN-2
TK-7020 (the same as TK-7100) Alexander Nesterov, Andrey Shunko KPG-80D KEN-1B
TK-7020 (the same as TK-7108) Yury US5IVZ, Alexander Nesterov, Nikolay UT5VF KPG-70D KEN-1B
TK-7060 (the same as TK-760G) Alexander Nesterov KPG-56D KEN-1B
TK-7060 (the same as TK-7160) Alexander Nesterov KPG-99D KEN-1B
KIRISUN
PT-2208S Vladimir Vashchenko, Nikolay aka 'KOKA' KSP-11 KEN-2
PT-3208S Vladimir Vashchenko, ALEKSEY30, Nikolay aka 'KOKA' KSP-11 KEN-2
PT-3209 Vladimir Vashchenko, ALEKSEY30 KSP-11 KEN-2
PT-3288S Vladimir Vashchenko   KEN-2
HYT
TA-240 Viacheslav UR5ROZ, Alexander Nesterov   KEN-2
TC-268 (Eclipse) Jaco Le Roux (South Africa), Norman Miller CX1ANM (Uruguay)   KEN-2
TC-268S (Eclipse) Jaco Le Roux (South Africa)   KEN-2
TC-270 Norman Miller CX1ANM (Uruguay)   KEN-2
TC-368 (Eclipse) Jaco Le Roux (South Africa), Norman Miller CX1ANM (Uruguay)   KEN-2
TC-368S (Eclipse) Jaco Le Roux (South Africa)   KEN-2
TC-370 Norman Miller CX1ANM (Uruguay)   KEN-2
TC-500 Oleg EX8MLT, Zinnur Nigmatulin HT500S, SW-500UA HYT-1
TC-700 Vladislav Bashaev HT700E HYT-1
TITAN
RN-102 MALE aka Dmitry, Alexander Nesterov, Victoria Chernigovskaya (reports itself as TK-2107) KPG-55D KEN-2
TWR
DJ-344KU Roman RN3ADR, Vladimir RV6AMF MCP-318 KEN-2
LINTON
LT-2188 Nikolay aka 'KOKA' MCP-318 KEN-2
SKY-COM
SC-R706 Serguey Bunin SCR706 KEN-2
SOONTONE
ST-518 Vladimir RV6AMF KPG-55D KEN-2
AJETRAYS
AJ-344V Valery UA9MRQ   KEN-2
YAESU / VERTEX
VX-1R Yevgueny RA9MHL, Alexander 'Gulliver' VX1 Y/V-1B
VX-2R Alexey RZ3AIQ, the author, Alexander 'Gulliver', RV9CT VX2, VX2 commander Y/V-1B
VX-5R Igor RA0FMF, the author VX5 Y/V-1B
VX-6R RV9CT VX6 Y/V-1B
VX-7R Serguey Bunin, Gyula HA7JCA (Hungary), RV9CT VX7 Y/V-1B
FT-10R Alexander 'Gulliver', Roman RV3SBQ, Roman RN3ADR WFT10 Y/V-1B
VX-10 Igor Marzaganov, the author, MALE aka Dmitry, Nikolay Strokinov, Dmitry EW3BX, Roman RV3SBQ, Andrey RN4ABL, Alexander 'Gulliver', Victoria Chernigovskaya CE14 Y/V-1B
FT-11R Igor Marzaganov WFT11 Y/V-1A
FT-40R Alexander 'Gulliver', the author WFT40 Y/V-1B
FT-41R the author WFT41 Y/V-1A
FT-50R the author, Roman RN3ADR WFT50 Y/V-1B
FT-51R Dmitry UA2FBB, MALE aka Dmitry WFT51 Y/V-1B
FT-60R Igor RA0FMF, Serguey Bunin, Andrey EW3DC FT-60 Commander Y/V-1B
VX-160 Veniamin Dolgikh, Pavel RA0SJB, Andrey RV4HV, Alexander Nesterov, Yury RA9SVD, Norman Miller CX1ANM (Uruguay), Serguey Cherkasov, Ramil Yunusov, Alexey EW7AT CE44 Y/V-1B
VX-160E Alexander Nesterov, Ramil Yunusov CE51 Y/V-1B
VX-180 Veniamin Dolgikh, Paolo IW3SQM, Ramil Yunusov CE44, CE51 Y/V-1B
VX-180E Ramil Yunusov CE51 Y/V-1B
VX-200 Yevgueny RA9MHL, Yevgueny RU6AI, Alexander Ivanov, RV9CT CE9 Y/V-1B
VX-210A the author, MALE aka Dmitry, RN3DD, Serguey Bunin CE45 Y/V-1B
VX-210 Vladimir Vashchenko, Alexander Ivanov, Serguey Bunin, the author, Igor RA0FMF CE29 Y/V-1B
VX-300 Igor RA0FMF, Alexander Kiseliov, Alexander Nesterov CE18 Y/V-1B
VX-400 Igor Marzaganov, Vladimir Vashchenko CE24 Y/V-1B
VX-414 Roman RN3ADR CE64 Y/V-1B
VX-417 Serguey Bunin CE64 Y/V-1B
VX-420 Igor RA0FMF CE64 Y/V-1B
VX-500 Yevgueny RA9MHL, Alexander 'Gulliver', Alexander Nesterov, Roman RV3SBQ, Andrey Andrianov CE6 Y/V-1B
VX-800 Vladimir Vashchenko CE49 Y/V-3
FT-857D Serguey UA0CIC, RV9CT (as the CAT interface)   Y/V-4
FT-897 RV9CT (as the CAT interface)   Y/V-4
VX-1000 Valery UA6LPG CE-7 (Windows 98) Y/V-2
FTL-1011 Nikolay Novakov, Alexander Kiseliov, Vladimir Vashchenko, Oleg RU6FB CE5, CE7 (99ch) Y/V-2
FTL-1014 Alexander 'Gulliver' CE5, CE7 (99ch) Y/V-2
VX-1700 Antonio José (Brazil) CE77 Y/V-4
VX-2000 Yevgueny RA3ZMB, EU7SS, Viacheslav UR5ROZ, Vladimir Vashchenko, Pavel RA0SJB, the author, Andrey Kolennikov, Alexander Nesterov, Roman RV3SBQ, Yevgueny UR5LIS, Ramil Yunusov, Alexey EW7AT, Victoria Chernigovskaya CE20 Y/V-2
FTH-2008 Nikolay Strokinov, Vladimir RW0JC CE2 Y/V-1C
FTH-2009 Victoria Chernigovskaya CE2 Y/V-1C
FTH-2010 Alexander Nesterov, Alexey UR8QM, Ramunas Majauskas, Gyula HA7JCA (Hungary) CE2 Y/V-1C
FTL-2011 Veniamin Dolgikh, Alain Seguin (Canada), Yury RA9SVD, Vlad RV6HG, Oleg RU6FB, Alexander UA9CEW, MALE aka Dmitry, Victor RK6MP (99ch), Valery UA6LPG, Alexander UR5TID, Roman RV3SBQ, Andrey Andrianov, Igor Saprykin CE5, CE7 (99ch) Y/V-2
VX-2100 Roman RV3SBQ, Ramil Yunusov CE82 Y/V-2
VX-2200 Ramil Yunusov, Victor from Alma-Ata CE82 Y/V-2
VX-2500 Paolo IW3SQM, Serguey Bunin CE63 Y/V-2
VX-3000 Serguey UA9UDQ, Vladimir Vashchenko (VHF and LB versions), Valery UA6LPG, Victoria Chernigovskaya CE19 Y/V-2
VX-3200 Vlad RV6HG, Vladimir Vashchenko, Alexey Gordeyko, Serguey Bunin, Serguey Cherkasov CE52 Y/V-2
VX-4000 Vladimir Vashchenko, Maxim Zorkaltsev (software versions 3.3.0.0 and 3.2.3.0 work fine, version 1.0.6.0 is dysfunctional) CE49 Y/V-3
VX-4107 Serguey Bunin, the author, Igor RA0FMF CE59 Y/V-2
VXR-5000 the author (a computer with the iCeleron 433 MHz processor), Andrey Andrianov CE8 Y/V-2
VX-6000 Vladimir Vashchenko CE49 Y/V-3
VXR-7000 Alexander Tataurov (a computer with the i80486 processor), Vladislav Bashaev CE27 Y/V-2
FTH-7008 Ramunas Majauskas CE2 Y/V-1C
FTL-7011 Alexander UA9CEW (99ch), Alexander Nesterov, the author CE5, CE7 (99ch) Y/V-2
FTL-7014 the author (reports itself as FTL-7011) CE5 Y/V-2
FT-8500 Alexander RA1AGA WFT8500 Y/V-2
FT-8800R Andrey UA3USQ, Igor RA0FMF FTB8800 Y/V-2
MOTOROLA
M10 Alexander Nesterov GM300 R04.00.00 MOT-3
P020 Yevgueny RA9MHL, Nikolay aka 'KOKA' Alpha Series Radios CPS R01.07 MOT-2
CP040 Andrey UA3USQ, Gyula HA7JCA (Hungary), Jaco Le Roux (South Africa), Alexander Nesterov, Roman RN3ADR R05.04 MOT-2
GP040 Valery UA6LPG R02.02.00 MOT-2
P040 Veniamin Dolgikh, Stan UN8GA, MALE aka Dmitry, Alexander Nesterov, Andrey Kolennikov, Jaco Le Roux (South Africa), Andrey UA3USQ, Nikolay aka 'KOKA', Roman RV3SBQ, Andrey Andrianov, Roman RN3ADR, Alexander RA3NY, Ramil Yunusov, Victor from Samara reg., Boris Martynov, Alexey EW7AT, Victoria Chernigovskaya R02.02.00 MOT-2
P080 Valery UA6LPG, Pavel UA1ZCC, MALE aka Dmitry, Alexander Nesterov, Jaco Le Roux (South Africa), Nikolay aka 'KOKA', Alexander RX6HT, Igor Saprykin, Ramil Yunusov, Boris Martynov, Alexey EW7AT R02.02.00 MOT-2
GP68 Alexander Nesterov, Igor UU8JA   MOT-1
GP88 Andrey Kolennikov, Ramil Yunusov GP300 R01.00.00 MOT-1
M100 RADIUS Belu Daniel (Romania) Radius Mobile R08.00.00 MOT-3
M110 MALE aka Dmitry, Alexander Nesterov, Jaco Le Roux (South Africa), Yury US5IVZ GM300 R04.00.00 MOT-3
P110 Igor Marzaganov, MALE aka Dmitry, Alexander Nesterov, Yury RA9SVD, Roman RV3SBQ, Lahodni Stefan (Romania), Alexey EW7AT GP300 R07.00.00 MOT-1
M120 Alexander Nesterov, Jaco Le Roux (South Africa), Belu Daniel (Romania), Norman Miller CX1ANM (Uruguay), Oleg RA9JM GM300 R04.00.00 MOT-3
M130 Norman Miller CX1ANM (Uruguay) GM300 R04.00.00 MOT-3
CM-140 ALEKSEY30, Valery UA6LPG, Veniamin Dolgikh, Yury RA9SVD, Belu Daniel (Romania), Nikolay aka 'KOKA', Alexander RX6HT, Ramil Yunusov, Alexander Nesterov, Oleg RA9JM, Albina Luchaninova, Zinnur Nigmatulin, Victoria Chernigovskaya, Alexander Nesterov R02.04, R05.00, R05.00.02, R05.04, R05.06, R05.07 MOT-5A, MOT-5B
GM-140 MALE aka Dmitry, Alexander UR5TID R05.00 MOT-3, MOT-5B
CP-140 Dmitry Shilo, Serguey Cherkasov, Roman RN3ADR, Ramil Yunusov, Victor from Samara reg., Doychin LZ3DA R05.01, R05.06, R05.07 MOT-2
CM-160 Vadim UA9MIR, ALEKSEY30, Valery UA6LPG, Belu Daniel (Romania), Ramil Yunusov, Alexey EW7AT R02.04, R05.00, R04.00, R05.04, R05.07 MOT-5A, MOT-5B
GM-160 Andrey Aladyin, Valery UA6LPG, Roman RN3ADR, Albina Luchaninova R04.00.00, R06.04 MOT-3
CP-160 Ramil Yunusov R05.01 MOT-2
CP-180 Valery UA6LPG, Albina Luchaninova R05.00 MOT-2
EM-200 Antonio José (Brazil) CPS V5.05 MOT-5B
M208 MALE aka Dmitry, Oleg Chugunov, Roman RV3SBQ, Andrey Shunko RADMBL MOT-3
M216 MALE aka Dmitry RADMBL MOT-3
GM-300 the author, Serguey RU3VV, Yevgueny RA9MHL, Valery UA6LPG, Igor Marzaganov, Oleg RU6FB, Andrey RV4HV, MALE aka Dmitry, Alexey Gordeyko, Alexander Nesterov, Andrey Kolennikov, Albina Luchaninova, Igor UU8JA, Nikolay UT5VF, Yury RA9SVD, Belu Daniel (Romania), Vladimir Fiodorov, Nikolay aka 'KOKA', Norman Miller CX1ANM (Uruguay), Roman RV3SBQ, Roman RN3ADR, Andrey Shunko, Igor Saprykin, Ramil Yunusov, Georgy RN3ZNL and Dmitry RN3ZQL, Oleg RA9JM, Serguey Olar, Alexander UR5TID, RV9CT, Victoria Chernigovskaya GM300 R01.00.00, R04.00.00, R05.00.00, Radius GM300 CPS for Win 2000 & XP(TM) ver.1.3, Radio Doctor for GM300 ver.1.12 MOT-3, MOT-5B
GP-300 the author, Yevgueny RA9MHL, Igor RA0FMF, Valery UA6LPG, Igor Marzaganov, Mikhail Gorokhov, Andrey RV4HV, Victor RA1TDC, Alexander UA1THR, MALE aka Dmitry, Alexey Gordeyko, Alexander Nesterov, Igor UU8JA, Igor UR5YEI, Jaco Le Roux (South Africa), Yury RA9SVD, Nikolay aka 'KOKA', Vladimir Yasakov, Roman RV3SBQ, Lahodni Stefan (Romania), Roman RN3ADR, Igor Saprykin, Alexander RA3NY, Oleg RA9JM, Serguey Olar, RV9CT, Victor from Samara reg., Alexey EW7AT, Victoria Chernigovskaya GP300 R07.00.00, GP-300IVG MOT-1
GP-300 Select 5 MALE aka Dmitry, Alexander Nesterov, Serguey Olar R02.04.00 MOT-1
MAG ONE MP300 Alexander 'Gulliver', Nikolay aka 'KOKA' MP300 MOT-6
GM-320 Andrey Shunko R03.07.04 MOT-3
GP-320 Roman RV3SBQ, Oleg RN3AUM, Victoria Chernigovskaya R03.03.00 rus + Tuner for Professional Radios (R02.00.03), R03.07.04 MOT-4
ZR320 interface Anton UA6JHM GM300 R05.00.00 MOT-3, MOT-5B
GP-340 Vadim UA9MIR, Serguey EW6GC, Serguey RX6LRE, Andrey RV4HV, Vladimir Vashchenko, Alexander Nesterov, Albina Luchaninova, Jaco Le Roux (South Africa), Andrey UA3USQ, Ramunas Majauskas, Nikolay aka 'KOKA', Roman RV3SBQ, Roman RN3ADR, Alexander RA3NY, Oleg RN3AUM, Victoria Chernigovskaya, Alexander 'Gulliver' R03.01.00, D03.02.01, R03.03.00 rus, R03.07.04 MOT-4
CM-340 Belu Daniel (Romania), Alexander Nesterov, Vladimir US5LVS, Victoria Chernigovskaya R04.00, R05.04, R05.06 MOT-5A, MOT-5B
GM-340 the author, MALE aka Dmitry, Andrey Kolennikov, Andrey UA3USQ, Yury RA9SVD, Belu Daniel (Romania), Ramunas Majauskas, Alexander RX6HT, Roman RN3ADR, Serguey Olar, Albina Luchaninova, RV9CT, Scott Zimmerman N3XCC, Andrey Shunko R03.01.00, D03.02.01, R03.03.00 rus, R03.00.01 MOT-3
GM-350 Serguey RU3VV, Yevgueny RA9MHL, Gorodnov, the author, Valery UA6LPG, Serguey UA0CIC, MALE aka Dmitry, Alexey Gordeyko, Alexander Nesterov, Nikolay UT5VF, Yury RA9SVD, Belu Daniel (Romania), Yevgueny Novik, Igor RA0FMF, Roman RV3SBQ, Andrey Andrianov, Igor Saprykin, Ramil Yunusov, Georgy RN3ZNL and Dmitry RN3ZQL, Albina Luchaninova, UR5GCD R03.00.08, R03.01.06, R03.01.09, R03.01.08 MOT-3
CM-360 Belu Daniel (Romania) R04.00, R05.04 MOT-5A, MOT-5B
GP-360 Roman RN3ADR, Victor from Samara reg., Oleg RN3AUM R03.01.02, R03.07.04 MOT-4
GM-360 Valery UA6LPG, Vladimir Vashchenko, Oleg Chugunov, Alexander RX6HT, Igor Saprykin, RV9CT, UR5GCD, Scott Zimmerman N3XCC, Andrey Shunko R03.01.02, R03.00.01 MOT-3
GP-380 Oleg RN3AUM R03.07.04 MOT-4
EM-400 Antonio José (Brazil) CPS V5.05 MOT-5B
EP-450 Norman Miller CX1ANM (Uruguay), Antonio José (Brazil) CPS V5.05 MOT-2
GM-600 Alexander 'Gulliver', Igor Saprykin R02.00.20 MOT-3
GP-600 Igor Saprykin R03.03.09, R02.00.20 MOT-1
GM-640 Oleg RN3AUM R00.07.04 MOT-3
GP-640 Oleg RN3AUM, Alexander 'Gulliver' R00.07.04 MOT-4
GM-660 Oleg RN3AUM R00.07.04 MOT-3
GP-660 Oleg RN3AUM R00.07.04 MOT-4
GM-680 Oleg RN3AUM R00.07.04 MOT-3
GP-680 Oleg RN3AUM, Roman RN3ADR R00.05.02 MOT-4
GM-950 Belu Daniel (Romania), Georgy RN3ZNL and Dmitry RN3ZQL R02.00.00 MOT-5B
GM-1200E Roman RN3ADR R00.01.05 MOT-5B
HT-1250 Oleg RN3AUM R06.08.05 MOT-4
GM-1280 Alexander 'Gulliver', Oleg RN3AUM R00.04.04, R00.07.04 MOT-3
GP-1280 Alexander 'Gulliver' R00.07.04 MOT-4
HT-1550 Oleg RN3AUM R06.08.05 MOT-4
HT-1550XS Oleg RN3AUM R06.08.05 MOT-4
LTS 2000 Alexander 'Gulliver', Roman RN3ADR R02.00.10 MOT-3
MAXTRAC Alexander 'Gulliver', Belu Daniel (Romania), Oleg RA9JM R07.02.00A MOT-3
MAXTRUNK (trunked MAXTRAC) Belu Daniel (Romania) MaxTrac Trunked Mobile R05.02.00 MOT-3
PRO3100 Norman Miller CX1ANM (Uruguay), Antonio José (Brazil) Professional Radio CPS R6.09.06 MOT-3
PRO3150 Norman Miller CX1ANM (Uruguay), Antonio José (Brazil) Entry Level v2.03 MOT-2
PRO5100 Norman Miller CX1ANM (Uruguay), Antonio José (Brazil) Professional Radio CPS R6.09.06 MOT-3
PRO5150 Norman Miller CX1ANM (Uruguay), Antonio José (Brazil) Professional Radio CPS R6.09.06 MOT-4
PRO7100 Antonio José (Brazil) Professional Radio CPS R6.09.06 MOT-3
PRO5150 Antonio José (Brazil) Professional Radio CPS R6.09.06 MOT-4
VOLNA
Volna-101 Valery UA6LPG (reports itself as MOTOROLA GM-160) MOTOROLA R06.05.03 MOT-3
Volna-201 Andrey Kolennikov, Valery UA6LPG (reports itself as MOTOROLA GM-360) MOTOROLA R03.01.00, D03.02.01 MOT-3
Volna-302 Andrey Kolennikov (reports itself as MOTOROLA CP-180) MOTOROLA R05.01 MOT-2
ALTAVIA
Altavia 301M Alexander UA4LOR ALTAVIA v2.01 ALT-1
GRANIT
Granit-202 Valery UA6LPG radios with serial numbers below 1200: P_R23M-014; above 1200: P_R23M2 GRA-1
2P-21 Valery UA9MRQ   GRA-2
2P-23 Igor Touryansky, Roman RV3SBQ P_R23M (for 2P-21,23,25) GRA-1
KLYON Alexey EW7AT R23M10 GRA-1
ICOM
IC-T2 Ramil Yunusov, Alexander Nesterov CST2 ICO-2
IC-F3 Valery UA6LPG, Alexander Kiseliov, Igor Marzaganov, Alexander UA4LOR, Alexey RA1TEZ, Alexander Nesterov, Nikolay aka 'KOKA', Ramil Yunusov, Zinnur Nigmatulin CSF3 ICO-2
IC-F3GS Igor RA0FMF, Valery UA6LPG, Igor Marzaganov, Ivan UX7MX, Andrey Shunko, Ramil Yunusov CSF3G ICO-2
IC-F3GT Ramil Yunusov, Albina Luchaninova CSF3G ICO-2
IC-F4 Alexander UA4LOR, Valery UA6LPG, Alexander Nesterov, Igor UU8JA, Ramil Yunusov CSF3 ICO-2
IC-F4GS MALE aka Dmitry, Alexander Nesterov, Ramil Yunusov, Igor RA0FMF, Victoria Chernigovskaya CSF3G ICO-2
IC-F4GT MALE aka Dmitry, Serguey Bunin, Ramil Yunusov CSF3G ICO-2
IC-R5 scanner UR5WKB CSR5 ICO-2
IC-T7 Ramil Yunusov CST7 ICO-2
IC-V8 Antonio José (Brazil) CSV8 ICO-2
IC-F10 Pavel UA1ZCC CSF10 ICO-2
IC-R10 scanner Alexander Nesterov CSR10 ICO-2
IC-F11 Valery UA6LPG, MALE aka Dmitry, Andrey Kolennikov, Ivan UX7MX, Nikolay aka 'KOKA', Alexander RA0CGP, Andrey Andrianov, Roman RN3ADR, Ramil Yunusov, Igor RA0FMF, Albina Luchaninova, Victoria Chernigovskaya CSF11 ICO-2
IC-F14 MALE aka Dmitry, Nikolay aka 'KOKA', Ramil Yunusov, Zinnur Nigmatulin CSF14 ICO-2
IC-F16 MALE aka Dmitry, Alexander RA0CGP, Serguey Cherkasov, Roman RN3ADR, Ramil Yunusov, Albina Luchaninova, Alexander Nesterov CSF14 ICO-2
IC-F21 Pavel RA0SJB, MALE aka Dmitry, Alexander Nesterov, Igor UU8JA, Ramil Yunusov CSF11 ICO-2
IC-F24 Ramil Yunusov CSF14 ICO-2
IC-F26 Pavel RA0SJB, MALE aka Dmitry, Ramil Yunusov, Victoria Chernigovskaya CSF14 ICO-2
IC-F30 Roman RN3ADR EX-1489 ICO-4
IC-F30LT MALE aka Dmitry EX-1489 ICO-4
IC-W31N Andrey UA3USQ software for IC-W32
IC-F40LT MALE aka Dmitry EX-1489 ICO-4
IC-F41GT Vladislav Bashaev CSF40G ICO-5
IC-M45EURO Igor UR5YEI CSM45 ICO-2
IC-F50 Ramil Yunusov CSF50 ICO-2
IC-F60 Ramil Yunusov CSF50 ICO-2
IC-A110 Valery UA9MRQ CSA110 ICO-2
IC-F110 MALE aka Dmitry, Alexander Nesterov, Vladimir Vashchenko, Alexander RA0CGP, Serguey Cherkasov, Ramil Yunusov, Alexander UR5TID, Albina Luchaninova, Victoria Chernigovskaya CSF100 ICO-3
IC-F110S Vladimir Vashchenko, Alexander Nesterov, Dmitry Kosolap, Nikolay UT5VF, Alexander UR5TID, Albina Luchaninova, Zinnur Nigmatulin, Victoria Chernigovskaya CSF100S ICO-3
IC-F111 Alexander UA4LOR, ALEKSEY30, MALE aka Dmitry, Andrey Kolennikov, Alexander Nesterov, Roman RV3SBQ, Alexander UA9CEW, Roman RN3ADR, Ramil Yunusov, Serguey Olar, Zinnur Nigmatulin, Alexander UR5TID, Albina Luchaninova, Serguey Cherkasov CSF100 ICO-3
IC-F111S Serguey RX6LRE, ALEKSEY30, Alexander Nesterov, Roman RV3SBQ, Albina Luchaninova, Mikhail aka Neptun CSF100S ICO-3
IC-F121 Antonio José (Brazil), Scott Zimmerman N3XCC CSF100, CSF121clo v1.7 ICO-3
IC-F121S Norman Miller CX1ANM (Uruguay), Scott Zimmerman N3XCC CSF100S ICO-3
IC-F210 Pavel RA0SJB, MALE aka Dmitry, Alexander Nesterov, Ramil Yunusov, Victoria Chernigovskaya CSF100 ver.1.5 ICO-3
IC-F210S Oleg RA9JM CSF100S ICO-3
IC-F211 the author, MALE aka Dmitry, Alexander Nesterov, Serguey Bunin, Ramil Yunusov, Serguey Olar CSF100 ICO-3
IC-F211S the author, Alexander Nesterov CSF100S ICO-3
IC-F310 MALE aka Dmitry, Belu Daniel (Romania), Valery UA6LPG CSF300 ICO-1
IC-F310S MALE aka Dmitry, Belu Daniel (Romania), Alexander UR5TID CSF300S ICO-1
IC-F320 MALE aka Dmitry, Alexander Nesterov, Roman RN3ADR, Ramil Yunusov, Albina Luchaninova, Zinnur Nigmatulin CSF300 ICO-1
IC-F320S Valery 4Z5PT, Alexander 'Gulliver', Veniamin Dolgikh, Serguey RX6LRE, Alexey RA1TEZ, MALE aka Dmitry, Nikolay aka 'KOKA', Albina Luchaninova CSF300S ICO-1
IC-F410 the author, Andrey RV4HV CSF300 ICO-1
IC-F410S Alexander Nesterov CSF300S ICO-1
IC-F420 Alexander Nesterov, Ramil Yunusov, Scott Zimmerman N3XCC, the author CSF300 ICO-1
IC-F420S Serguey Bunin, Alexander 'Gulliver' CSF300S ICO-1
IC-F520 Roman RN3ADR CSF500 ICO-3
IC-F521 Roman RV3SBQ CSF500 ICO-3
IC-F621 the author CSF500 ICO-3
IC-M710 Igor RA0FMF Ex1726 ICO-1
IC-F1010 MALE aka Dmitry, Alexey EW7AT EX1764 ICO-1
IC-F1020 MALE aka Dmitry EX1764 ICO-1
IC-F2010 Serguey Bunin EX1764 ICO-2
IC-F2020 Roman RN3ADR, Igor Saprykin EX1764 ICO-2
IC-FR3000 ALEKSEY30, Ramil Yunusov CSFR3000 ICO-1
IC-FR4000 Ramil Yunusov CSFR3000 ICO-1
IC-V8000 Igor RA0FMF CSV8000 ICO-2
ALINCO
DR-B1 Alexander Nesterov, Belu Daniel (Romania), Serguey Cherkasov, Ramil Yunusov DRB1 ICO-2
DR-130 Ramil Yunusov DR130 ICO-2
DR-135 Serguey UA9UDQ, Dmitry UA2FBB, Yury RA9SVD, Belu Daniel (Romania), Vladimir Vashchenko, Valery UA6LPG, Roman RV3SBQ (DR-135T), Roman RN3ADR, Ramil Yunusov, Zinnur Nigmatulin DR135 ICO-2
DR-135F Roman RV3SBQ (Schematics is different from the usual DR-135. The high zero effect is present.), Serguey Cherkasov, Igor Popov DR135 ICO-2
DR-140 Serguey UA9UDQ, Albina Luchaninova, Igor RA0FMF, Roman RV3SBQ, Ramil Yunusov DR140 ICO-2
DJ-190 Ramil Yunusov DJ190 ICO-2
DJ-191 Alexander 'Gulliver', Igor RA0FMF, Nikolay Strokinov, Alexander Nesterov, Igor UR5YEI, Albina Luchaninova, Igor UU8JA, Denis Alafinov, Nikolay aka 'KOKA', Roman RV3SBQ, Roman RN3ADR, Andrey Shunko, Ramil Yunusov, RV9CT, Mikhail aka Neptun DJ191 ICO-2
DJ-193 Alexander Nesterov DJ195 ICO-2
DJ-195 Serguey UA9UDQ, Pound, Igor RA0FMF, Alexander Nesterov, Yury RA9SVD, Vladimir Fiodorov, Nikolay aka 'KOKA', Alexander RA0CGP, Roman RV3SBQ, Serguey Cherkasov, Alexander UA9CEW, Ramil Yunusov DJ195 ICO-2
DR-235 Vladimir Vashchenko DR135 ICO-2
DR-430 Ramil Yunusov DR130 ICO-2
DR-435 Vladimir Vashchenko, Igor RA0FMF, Ramil Yunusov DR135 ICO-2
DR-440 Ramil Yunusov DR140 ICO-2
DJ-490 Ramil Yunusov DJ190 ICO-2
DJ-491 Alexander Nesterov, Igor UU8JA, Denis Alafinov, Roman RV3SBQ, Ramil Yunusov DJ191 ICO-2
DJ-495 Ramil Yunusov DJ195 ICO-2
DR-605 Ramil Yunusov DR605 ICO-2
TAIT
T2010 Alexander Nesterov T2000 Conventional Programming Application TAI-1, TAI-1A
MAXON
SL500 Alexander Nesterov SL500 MAX-1
STANDARD
HX-190 Alexander 'Gulliver'   STA-1
GX-2000U Alexander UA9CEE PPS2000 STA-1
DRAGON
SY-5430 (3 ch. programmable) Yury US5IVZ, Igor UR5YEI, UR5GCD, Victoria Chernigovskaya SYTCOM 38 DRA-1
VECTOR
VT-44H RV9CT VT-44H KEN-2
VT-44 MASTER Vladimir RV6AMF, Victor from Samara reg., Alexander 'Gulliver' KPG-55D, KSP-11 KEN-2
VT-44 Military Alexander 'Gulliver' WPG-46A VEC-1
VT-44 PRO Nikolay aka 'KOKA' (reports itself as KENWOOD TK-3107) KPG-55D KEN-2
SIMOCO
SRM-9030 Roman RN3ADR FPP v.5.32 SIM-1
ALAN
HM-200 Yury US5IVZ (software in italian, runs under DOS) H200 ALA-1
FAKE RADIOS
Pseudo-ICOM IC-F21 Alexander Nesterov (reports itself as KENWOOD TK-2107) KPG-55D KEN-2
Pseudo-KENWOOD TK-2107 Alexander Nesterov (a computer with the iCeleron 700 MHz processor), Serguey Olar, Alexander UR5TID KPG-55D KEN-2
Pseudo-KENWOOD TK-2107L Yury US5IVZ (Low Band radio) PGM_v1.0, PGM_v1.02 (Windows XP) KEN-2
Pseudo-KENWOOD TK-2170 MALE aka Dmitry KPG-101D KEN-2
Pseudo-KENWOOD YQ 3000(2) Victor from Alma-Ata, Albina Luchaninova (reports itself as KENWOOD TK-3107) KPG-55D KEN-2
Pseudo-KENWOOD TK-3107 Alexander RA0CGP KPG-55D KEN-2
Pseudo-KENWOOD TK-3108 Alexander Nesterov (reports itself as KIRISUN) KIRISUN KSP-11 KEN-2
Pseudo-KENWOOD TK-3207 Denis Alafinov, Alexander Nesterov, Nikolay aka 'KOKA' (reports itself as KENWOOD TK-3107) KPG-55D KEN-2
Pseudo-KENWOOD TK-3260 Valery Babiy KPG-87D KEN-2
Pseudo-MOTOROLA GP-327 Nikolay aka 'KOKA' (KENWOOD portables connector, reports itself as KENWOOD TK-3207 !) KPG-87D KEN-2
Pseudo-MOTOROLA GP-680 Valery UA9MRQ R00.05.02 MOT-4
Pseudo-MOTOROLA T5930 Alexander Nesterov, Alexander 'Gulliver' (KENWOOD portables connector, reports itself as KENWOOD TK-3107 !) KPG-55D KEN-2
Pseudo-KENWOOD TK-7020-1 Alexander UR5TID KPG-80D KEN-1B
CI-V interface
OPTOELECTRONICS DC440 decoder the author the author's Y/V-1A
SIEMENS cellular phones
A35 the author (firmware programming) Freia, etc. PHO-3
C35i the author (AT-commands, firmware programming) Hyper Terminal, c3i_xxxx, ... PHO-3
M35 the author (AT-commands, firmware programming) Hyper Terminal, c35i_xxxx, ... PHO-3
S35 the author (firmware programming, AT-commands), Andrey Kolennikov (firmware programming, unlocking, customizing) Hyper Terminal, Winswup32, ZeeSiemensG3, S35C35M35 Explorer PHO-3
ME45 the author (AT-commands), Yevgueny RA9MHL (firmware programming) Hyper Terminal, Freia... PHO-3
S45 the author (AT-commands) Hyper Terminal PHO-3
SL45i the author (AT-commands) Hyper Terminal PHO-3
C60 Serguey UA0CIC (AT-commands) Hyper Terminal PHO-3
The correctly assembled programming cable needs no adjustment. But... Let's see the troubleshooting technique if the cable does not work..
1. Check the assembly carefully. Check the component correspondence with the schematic diagram. Here are the most common errors in the programming cable assembly.
2. Make sure no wires are broken and all contacts are reliable, especially in a connection to the radio. Broken wires are the frequent reason of malfunction. Please note ! Connection to the radio must be reliable. Round stereo jacks must be plugged in firmly until stop. Their flanges may be ground off if needed. RJ-11 and RJ-45 connectors get oxidized easily. Socket contacts may be cleaned with an erasor scrap. Jack contacts may be cleaned with a thick needle.
3. Make sure the regulator output voltage is 5V +/- .1V. The wrong voltage may occur due to assembling defects or bad serial port extension pieces. Please note: the serial port may power up the circuit only while accessing the radio. Some software (especially made by Motorola) gives no power from the port, so external power is needed.
4. Make sure the software and operational system are correct. The most common mistake is running DOS programs under Windows. Port accessing technique under Windows is different, DOS programs access ports incorrectly. Use MS DOS or Windows'98 in DOS mode for such programs.
5. Make sure the radio is powered correctly, is turned on and functions properly. Uncareful trunking board removing or burning radio inner circuits with the bad programming cable makes the radio unprogrammable. The battery of a portable radio must be charged completely. A mobile radio must be powered with an appropriate power supply.
6. Consider the specific features of the radio being programmed. Most radios are put in programming (cloning) mode automatically. Some radios are put in programming (cloning) mode manually by pressing a specific set of buttons while turning on. Some radios need pressing specified buttons to start data upload or download. Some radios may be locked to prevent reading or writing data. Refer to radio manuals or search the web for information.
The author especially appreciates the active participance of Sergey UA9UDQ, Yevgueny RA9MHL, Valery UA6LPG, Alexander 'Gulliver', Vladimir Vashchenko, Sergey Bunin, Pavel RA0SJB, MALE aka Dmitry, Alexander Nesterov, Nikolay aka 'KOKA', Belu Daniel, Norman Miller, Roman RN3ADR, Roman RV3SBQ, Ramil Yunusov, Albina Luchaninova, Oleg EX8MLT, Alexander Ivanov, Alexander UA9CEE, Yuri US5IVZ, Valery UA9MRQ, Victoria Chernigovskaya. Special thanks to Valery UA6LPG for the updated PCB design. Special thanks to Gyula HA7JCA for the programming cable description in Hungarian.
The more detailed cable description is published at this site and here.
PLEASE NOTE ! The author does not collect and does not distribute radio programming or service software. Please do not ask the author for the software ! Visit www.cqham.ru/sch_eng.html.
PLEASE NOTE ! Reporting about your experience of testing the programming cable please give the following information:
1. your name and, if desired, your location;
2. the type (types) of the radios tested, the corresponding software, the connector used.
Yevgueny Andropov,
E-mail address is on the diagram.
10.01.2017 06:32 помогите найти инструкция эксплуатации радиостанции альтавия 101 ...  --
26.11.2016 16:00 yaesu ft60 rs232 pc kabel...  --  Laszlo Varosi...
23.10.2016 15:29 XRumer 12.0.19 is the BEST...  --  Melanietwelt...
22.10.2016 09:46 22 июля 2016 г. в 12:02 Павел Может выключить функцию субтонов...  --  UN7JC
22.10.2016 09:43 Ищу читаемую схему и фото платы на радиостанцию 27 Мгц Sunker Eli...  --  UN7JC
08.10.2016 14:27 baofeng uv-b6...  --  yu7vu
26.08.2016 12:02 Добрый день, подскажите пожалуйста, не могу перепрограмировать ра...  --  Александр
21.08.2016 16:28 ...  --
30.07.2016 01:06 tc 500...  --  tecnicofabiosil...
22.07.2016 12:02 Добрый день! Имеет место такая проблема. Приобрели 2шт кенвуд TH-...  --  Павел
19.07.2016 16:20 как перепрошить ммсs R 03...  --  николай
24.06.2016 07:07 Как и чем можно перепрограмировать радиостации МОТОРОЛА GP688 жел...  --  Николай
26.04.2016 12:59 Добрый день. Есть две радиостанции FT1900 FT2800 . Подскажите пож...  --  Владимир
23.04.2016 17:01 как можно мою радиостанцию зделать что бы об ней узнали везде и ...  --  ღṦ&...
21.02.2016 10:42 как вручную запрограммировать kenwood 270...  --  r6am
03.02.2016 20:19 ...  --  rv6amf
29.01.2016 15:41 Здравствуйте.Подскажите имею в наличии 15 канальную радиостанцию ...  --  us5vac
22.01.2016 20:34 Добрый вечер. Как запрограммировать рацию моторола сл 1600...  --  Сергей
20.01.2016 21:44 Нужна схема подключения к универсальному СОМ программатору возим...  --  Леон
19.01.2016 14:05 HELP!!! Помогите найти ПО для Tietong tt-690....  --  Владимир RA9YDF...
12.01.2016 14:25 Спасибо огромное! нашел у вас распайку провода! Кстати вместо ун...  --  Юрий
26.11.2015 22:51 Здравствуйте! Приобрёл носимую УКВ (вбит канал на 154.600) Midlan...  --  Николай RA1WJ...
07.10.2015 00:46 что делать с моторолой xts 3000 если надпись file01/82 ...  --  1978u
25.09.2015 09:18 О том, как убрать пароль с радиостанции motorola читайте здесь te...  --  радио73
15.09.2015 10:09 Подскажите,возможно ли как то снять пароль при программировании н...  --  Metan
30.04.2015 07:50 Здравствуйте.Р/ст кенвуд тк-2180.ПрограмматорKPG-36A,всё подключа...  --  Андрей
27.04.2015 12:44 подскажите где скачать софт программирования для Motorola DP4400,...  --  ануар
21.04.2015 11:33 не стыкуется комп с icom-a210 , что делать, может кто подключал х...  --  ulk
15.04.2015 19:52 SPASIBO...  --  ando
10.04.2015 17:47 Подскажите где скачать софт программирования для Kenwood TK-520...  --  hamra
31.03.2015 11:14 Здравствуйте ! подскажите пожалуйста у меня моторола ср 140 не ра...  --  XARI_1
28.03.2015 09:13 ели телевон саблакиравали гравическим кодам и он простит гугл тел...  --  Надежда
25.03.2015 08:32 Здравствуйте нужно ПО для радон 302 п45 где его можно найти??? ...  --
02.03.2015 15:04 Здравствуйте.Подскажите пожалуйста.У меня есть рация Альтавия-301...  --  sergei
26.02.2015 14:34 Здравствуйте. Ни где не могу найти программу wpg-46a дя программи...  --  Евгений
20.02.2015 03:30 samuel! Софт для программирования ТС-518 возьмите здесь - radio...  --
17.02.2015 16:59 люди помогите запрограммировать ХИТ ТС-518U1 нужен софт ...  --  samuel
13.02.2015 17:02 Дилшод! Программа для изменения частоты CM-140 находится здесь -...  --
13.02.2015 16:57 Stasek83! Рации Моторола CP 040 нельзя законектить с MegaJet 30...  --
12.02.2015 19:54 Здравствуйте! Подскажите пожалуйста. У меня есть две рации Моторо...  --  Stasek83
12.02.2015 10:06 программа изменения частоты см-140...  --  Дилшод
30.01.2015 10:26 Вот статью нашел, здесь tehnopage.ru/universalnyy_programmator_ra...  --  Radioham
24.01.2015 13:01 Доброго времени суток Всем.Заказал,купил с Е-Бейя софт вместе с к...  --  КК070
22.01.2015 18:10 Вот скажите мне,я один тут дурак или как? Или меня(пусть и не на...  --  Александр Алекс...
20.01.2015 16:39 Нужно считать софтом данные с р/ст и сохранить, а затем зайти в м...  --
19.01.2015 14:01 Спасибо за совет!как это сделать подробно,ещё несовсем понятно...  --
19.01.2015 09:10 Чтобы завязать одну с другой motorola gp680 используйте Универсал...  --
18.01.2015 00:47 Привет всем!подскажите как завязать одну с другой motorola gp680,...  --
14.01.2015 10:46 здрасте! слетели станции на vector 44 pro. где можно найти програ...  --  kirich
13.01.2015 17:13 Vladt! Вероятно Вы ошиблись, для прошивки Apollo GPX-210? Если та...  --
12.01.2015 16:35 Какой переходник применить для прошивки Apollo GPX-120...  --  Vladt
19.12.2014 20:44 marshal, Для TK-7108H Софт вроде только этот KPG-70D...  --  metan
06.12.2014 17:28 Проблема програмирования укр кенвуда KENWOOD TK-2260-5 с использо...  --  UR3ID
06.12.2014 15:53 Всем добрых суток. Нужна программа для программирования радиоста...  --  marshal
05.12.2014 01:15 я хочу КПГ для Kenwood TK-520s please help me ...  --  omar.libyan2014...
05.12.2014 01:14 hi all...  --  omar.libyan2014...
02.12.2014 14:02 kak napisat kanal, spasiba...  --  elshen
30.11.2014 14:26 Здравствуйте! Подскажите как сбросить пароль на Kenwood TK-7100H....  --  Sergey
13.11.2014 12:58 R9UAE! Снять пароль при программировании CP040 можно вот этим со...  --
11.11.2014 15:31 не могу найти software для радиостанции ICOM F-16. Версия 1.1 и 1...  --  dsal
09.11.2014 10:14 схема кабеля для прошивки базовых радиостанций Кенвуд КПГ-4...  --  boreckii-a
09.11.2014 08:45 Здрасте. Радиостанция motorola CP040 как снять пароль при програм...  --  R9UAE
07.11.2014 17:45 Вам нужен кредит, если да, Мы предлагаем все виды кредитов на 3%....  --  justine william...
21.10.2014 03:51 витали! Надо сделать сброс, чтобы вернуть станцию к заводским ус...  --
20.10.2014 15:03 у меня такая ситуация .мигает 9 волна. и не переключаться на др...  --  витали
11.10.2014 12:14 Почта на mail.ru есть: marmorgik@mail.ru. Спасибо еще раз за при...  --  Metan
11.10.2014 11:49 Metan! Заведите себе почту на mail.ru т.к. на эту не отправляется...  --
11.10.2014 10:26 Спасибо! Но почему то ни чего не пришло.Если есть возможность пов...  --  Metan
11.10.2014 05:02 Metan! Действия по снятию пароля направил Вам на почту....  --
10.10.2014 12:13 Доброе время суток! Есть Motorola GM-140,несколько штук,поставлен...  --  Metan
10.10.2014 00:03 ПрОсТо БоРеЦ-0001! Скачать программу для HYT TC-700 можно здесь -...  --
08.10.2014 13:02 скачать программу HYT TC-700...  --  ПрОсТо БоРеЦ-00...
08.10.2014 12:59 скачать программу HET TC-700...  --  ПрОсТо БоРеЦ-00...
03.10.2014 12:11 ...  --
26.09.2014 10:22 Р/ст Эрика 310- П23 перешивается но после перешивки нет приема на...  --  Кирилл
21.09.2014 19:32 mojnali pragramirovat telefon bez pragramatira ...  --  Elyor
14.08.2014 16:23 Ищу программу прошивки радиостанции Umbrella A100 и схему подключ...  --  Сергей UN7JC...
24.07.2014 22:41 programmer for standard c 112...  --
22.07.2014 15:31 Р/ст Эрика 310- П23 перешивается но после перешивки нет приема на...  --  VNG
22.07.2014 15:20 Р/ст Эртка 310- П23 перешивается но после перешивки нет приема на...  --  VNG
15.07.2014 10:13 добрый день, подарили рацию моторола ср040, в инструкции не напис...  --  Александр
12.07.2014 06:49 Ребят,помогите настроить субтоны на вектор вт43 р2 и восстановить...  --  Ветал
04.07.2014 16:03 Сергей RK6BAB......Насколько я знаю Такт 201 П23 это ICOM F-111 ...  --  Анатолий
02.07.2014 10:25 Здравствуйте! Необходима подсказка по программированию Такт 201 П...  --  Сергей RK6BAB...
02.07.2014 10:15 Здравствуйте, сразу извиняюсь за глупые вопросы, навчну с того чт...  --  Дима
19.06.2014 16:07 Здравствуйте!...кто нибудь помогите найти софт Alpha Series Radio...  --  2rist
14.06.2014 11:58 Добрый день. 599 Мне нужен кабель и программа для Alinco Dj-191...  --  EK6OAK
12.06.2014 12:03 подскажите как выключить звук на радиостанции tk 3118...  --  жека
11.06.2014 17:45 Как пролить рацию рута в домашних условиях...  --  саня 1983
11.05.2014 16:13 Спасибо Евгению за схемку. Заработало с первого раза. Прошивал Мо...  --  Андрей
08.05.2014 10:22 В статье softlink.ucoz.com/publ/28-1-0-73 подробное описание рабо...  --  Любитель
18.04.2014 17:28 Передаю благодарность Евгению за данный программатор, статью о нё...  --  filin
18.04.2014 12:40 Добрый день Связисты Помогите найти софт для Моторолам GM 338 BS...  --  Сансыз
14.04.2014 22:28 Как программировать MOTOROLA GM 338...  --  Cансыз
11.04.2014 07:51 Повторил универсальный программатор. Станция Yaesu VX-300 x1. П...  --  Алексей
02.04.2014 05:19 как узнать архив розговор билайна без пароля ...  --  Shalkar
24.03.2014 00:32 Получилось зашить HYT TC-700 с новой прошивкой. Нужна прога верс...  --  Моторола
20.03.2014 12:56 9.18 килоома, я уже подумал про это поменял с 12 на 9.18 набрал ...  --  Иван
20.03.2014 09:25 Бывает...у меня тоже так бывает,какой у тебя номинал резистора в ...  --  Анатоль
19.03.2014 17:24 kpg55d_3.12 самое главное я уже одну рацию и прочитал и зашил, до...  --  Иван
19.03.2014 17:16 А,каким софтом ппробовал?...  --  Анатоль
19.03.2014 17:00 Понял, но вроде как рация видит потому как лампочка передачи заго...  --  Иван
19.03.2014 11:33 Ивану...РАЗЬЁМ 2.5 ММ нужно удлинить,аккуратно сточи кромку ,чтоб...  --  Анатоль
19.03.2014 09:03 Здравствуйте, давно собрал данный программатор, много им программ...  --  Иван
17.03.2014 11:18 Обозначения по ГОСТу: те, что десятичной дробью - микрофарады, те...  --  Евгений Андропо...
13.03.2014 16:46 Люди, подскажите новичку - номиналы конденсаторов С1-С3, они в че...  --  filin
06.03.2014 20:38 Нужен софт на китайскую р.с TK-3107...  --  IigorS
03.03.2014 20:36 недавно программировал станцию gm660 не сохранил *RIB как быть? *...  --  boing 737
21.02.2014 17:01 Недавно рация глюканула. Нептун НМ-21. Светится всё табло, лампо...  --  ua6chi
14.02.2014 09:39 Может кто нить сталкивался с радиостанцией Tait MT8110 1. Что н...  --  Андрюха
13.02.2014 11:21 Добрый день подскажите кто может! Купил две рации моторола СР 040...  --  Анатоль
12.02.2014 08:57 рация моторола gp340 сам работает. передача есть. приема нету. ни...  --  погран
07.02.2014 06:54 Проверил программер с р/с Аргут (не помню точно модель, какая-то ...  --  Михаил Neptun...
03.02.2014 09:33 Не работает приемник на радиостанции IC F521. Может кто сталкивал...  --  sprut
03.02.2014 00:19 xfdght...  --  javoxir
02.02.2014 04:52 Ищу сервис мануал и программу прошивки на УКВ рацию Saracom BS-80...  --  UN7JC
28.01.2014 11:06 Нужна схема распайки ком порта для прошивки радиостанции,помогите...  --  просто парень)...
27.01.2014 08:54 Евгений, благодарю за сообщение! Собственно, перейти на USB несло...  --  Евгений Андропо...
24.01.2014 23:20 Добрый день! Недавно собрал предложенную схему программатора и ус...  --  Евгений
15.01.2014 19:11 Добрый день! Случайно нашел рацию TK-2260, решил ею "поиграть". П...  --  chester
08.01.2014 19:09 Для UN9GIH: TK-80 полностью перепрограммируется с передней панели...  --  UN7JC
26.12.2013 21:23 Здравствуйте уважаемые коллеги!Скажи пожалуйста у меня проблемы с...  --  un9gih
24.12.2013 10:36 Евгений Андропо! Перемаркированный Roger KP-112" - это р/ст ""Боц...  --
23.12.2013 11:55 Попалось в сети: ""Боцман-Б" это перемаркированный Roger KP-112"....  --  Евгений Андропо...
23.12.2013 09:11 Добрый день уважаемые коллеги! Кто сталкивался с радиостанцией Бо...  --  bk25
22.12.2013 00:25 Вова! Никаких кнопок на gp344 нажимать не надо. Выберите в софте...  --
21.12.2013 07:54 Вова! Попробуйте этот софт - radioscanner.ru/files/motorola/file1...  --
20.12.2013 14:23 Motorolla gp344 каким софтом шить? может процедура нажатия кнопок...  --  Вова
19.12.2013 19:52 Спасибо большое)) не где не мог найти софт)...  --  Александр
19.12.2013 14:08 Александр! Радиостанция HYT TK-434 (Soontone ST-518), подключени...  --
18.12.2013 16:18 Всем привет) подскажите пожалуйста, есть ли у кого нибудь прошивк...  --  Александр
17.12.2013 00:48 Ivan! Softvare for CP040 (Firmware - R03.04.02) (Part 1) - rad...  --
16.12.2013 20:43 softvare CP040 R03.04.02 SRBIJA 73!!!...  --  Ivan
15.12.2013 15:47 ...  --
15.12.2013 15:46 ...  --  мин кыяал
15.12.2013 14:44 Спасибо за помощь я смотрел на саите все как я думал нужно вмешат...  --  ex.UO5oen
14.12.2013 05:47 Василий ex;UO5OEN! Если не получается запрограммировать с помощьь...  --
12.12.2013 14:11 hyt tc 620...  --  omer
10.12.2013 20:17 Василий ex;UO5OEN!.Если уж пользуетесь осциллографом посмотрите ц...  --  Саша
27.11.2013 22:42 Все попытки бесполезны програматор с другими программами работает...  --  ex. UO5OEN
27.11.2013 01:47 Василий ex;UO5OEN! DOS-программы надо запускать из DOS! Об этом г...  --
25.11.2013 17:35 Кто нибуть програмировал TK-240 K Kenwood вчем может быть проблем...  --  ex.UO5OEN
24.11.2013 11:00 Успешно запрограммированы рации VX-2500v, VX-400, CM-140, GM-340...  --  Саша
23.11.2013 08:46 Василий ex;UO5OEN! Схема для р/ст Kenwood TK-340(соответствует TK...  --
20.11.2013 15:35 Нужна схема и инструкция на KENWOOD TK-240 K не отвечает на од...  --  Василий ex;UO5O...
16.11.2013 20:25 Сегодня разобрался с программатором. Первое что сделал разобрал п...  --  Саша
15.11.2013 18:04 помогите пожалуста нужна схема на Motorola GM GP 360 или кто подс...  --  sasha us8ido...
13.11.2013 15:38 Помогите пожалуйста. Собрал универсальный программатор. Использую...  --  Саша
12.11.2013 11:27 Подскажите пожалуйста, как можно запрограммировать станцию M-Tech...  --  Алексей
27.10.2013 05:01 Vector VT-43 R2 ...  --
11.10.2013 01:58 Любитель! А какой программатор Вы использовали?...  --
07.10.2013 16:29 программатор выручил в качестве переходника для соединения ПК(че...  --  anryab
07.10.2013 02:50 softlink.ucoz.com/publ/26-1-0-83 Автор предлагает способ исправит...  --  Любитель
03.10.2013 19:22 talgat_7274! Софт для программирования Icom IC-F5026H возьмите зд...  --
25.09.2013 11:55 Как менять частоту на радиостанции motorola GM Databox и какой ка...  --  Марат
23.09.2013 09:14 Помогите пожалуйста нужен софт для программирования Icom IC-F5026...  --  talgat_7274...
20.09.2013 04:52 Разобрался...  --  Parcour
18.09.2013 06:49 Помоги с программирование Vertex vx-2200. Программатор универсаль...  --  Parcour
09.09.2013 13:56 Вопрос с программированием Kenwood TK-8000S решил программа TK220...  --
09.09.2013 06:14 какой софт нужен для программирования радиостанции Kenwood TK-80...  --  Сергей
31.08.2013 06:04 Василий! Для программирования радиостанции Элодия 301М нужен про...  --
29.08.2013 08:09 какой софт и программатор нужны для программирования радиостанции...  --  Василий
28.08.2013 10:12 Большенство программ не даст даже и прошить.....  --  Анатолий
28.08.2013 05:41 Радиостанцию диапазона 136-174 МГц перепрошить на частоту - 44МГц...  --
28.08.2013 00:22 можно ли радиостанцию диапазона 136-174 МГц перепрошить на част...  --
27.08.2013 19:48 народ подскажите возможно ли увеличить зону покрытия за счет увел...  --  стнанислав
22.08.2013 09:45 Юрию...Раз р/ст пишет о программированиии,значит сом порт выбран ...  --  Анатолий RW4CFC...
21.08.2013 16:14 Помогите пожалуйста нужен софт для программирования Icom IC-F5026...  --  Федор
19.08.2013 09:02 Keenwood tk-7160. собрал программатор, переходник. подключаю к ра...  --  Юрий М.К.
29.07.2013 03:39 Помогите, кто может программой для провивки KENWOOD TK-80, и как ...  --  Сергей UN7JC...
26.07.2013 16:50 помогите с Kenwood TH-K2AT!!!!поменял ботарею на новаю стало на т...  --  артём
10.07.2013 23:42 вообщем,вкратце!нашел как-то на медни у себя в шеке рацейку vrtex...  --  ra3tty
04.07.2013 14:47 Проверил работоспособность программатора на радиостанциях AJETRAY...  --  бродяга
02.07.2013 04:29 Подскажите, где найти мануал, сервис мануал, программу прошивки р...  --  Сергей UN7JC...
22.06.2013 15:51 УМИДЖОН! Соберите сначала универсальный программатор и переходни...  --
21.06.2013 12:14 ПОМОГИТЕ ПОЖАЛУСТА КАК МОЖНО ПРОГРОМИРОВАТЬ КЕНВУД ТК 7108Н ХОТЕЛ...  --  УМИДЖОН
13.06.2013 18:42 Поборол. У меня Винда 7-я, на работе стоит XP, с нее все...  --  ra1ant Александ...
12.06.2013 23:39 Давно собран этот программатор, прошита не одна р.с , а вот ...  --  ra1ant Александ...
11.06.2013 22:23 Помогите с софтом на GM160 R05.10.02 софт Motorola GM140/160 ProS...  --  глостер
06.06.2013 13:01 Добрый день товарищи! Подскажите пожалуйста как переключать выход...  --  ИВАН
26.05.2013 01:25 Деду Мише- ваша модель ручная рация УКВ диапазона. В лес ходить ...  --  UN7JC Сергей...
26.05.2013 00:49 KENWOOD TK-7108H при попытке прочитать что записано загораются вс...  --  UN7JC Сергей...
19.05.2013 06:45 Подскажите пожалуйста что за аппарат Кенвуд TK 2200 VHF Можно ли ...  --  Миша
08.05.2013 13:05 здавствуйте подскажите пожалуйста, купил сегодня телефонSAMSUNG-G...  --  молодой 25
03.05.2013 11:55 Есть ли возможность перепрошить ALINCO DJ382 на 430мгц? Если да,с...  --  Владислав.UR5LG...
03.05.2013 11:15 помогите програмироват ICOM IC-U87 зарание блогадарю...  --  Sobir 22
30.04.2013 14:15 Проверил при программировании Кенвуда ТК 7108. Работает.Софт KPG ...  --  Андрей Коленник...
27.04.2013 20:06 Айжан! Софт для программирования возьмите здесь - radioscanner.ru...  --
26.04.2013 09:17 у кого есть программатор для GP640 ver. R02.04.00...  --  Айжан
17.04.2013 14:49 Ну, спасибо, что не успел напортачить. Кстати, по большому счету ...  --  Вячеслав
17.04.2013 14:24 Вячеслав! К сожалению, Kenwood ТК-2260 -5 имеет рабочий диапазон...  --
17.04.2013 14:17 Спасибо,Евгений! Ну, на данный момент программа позиционирует эти...  --  Вячеслав
17.04.2013 13:47 Вячеслав, возможности чисто программного изменения диапазона нет,...  --  Евгений Андропо...
17.04.2013 13:25 Здравствуйте! Прошу совета специалистов. Есть пара станций Kenwoo...  --  Вячеслав
15.04.2013 11:33 TAIT T2000 (T2017) Всем Доброго дня! С некоторыми трудностями уд...  --  Сергей (RK6BAB)...
04.04.2013 11:46 Все разобрался, программа битая, скачал вот эту CE86_Setup_3_02_f...  --  mityai30
03.04.2013 14:35 Диапазон совпадает, а вот насчет субтонов не могу разобраться. Не...  --  mityai30
01.04.2013 16:23 Спасибо, на странице gm0veq@hotmail.com я был, скачать без регис...  --  Сергей (RK6BAB)...
01.04.2013 15:41 Cергей RK6BAB! Вам нужен софт - Tait North American Conventional ...  --
01.04.2013 01:40 TAIT 2017 Зарегистривался, присоединился - нет там ничего по Т201...  --  Cергей RK6BAB...
30.03.2013 13:54 mityai30! Возможно не совпадает диапазон частот или разные субто...  --
30.03.2013 13:50 rk6bab! Зарегистрируйтесь и присоединитесь к группе на этом сайт...  --
29.03.2013 13:22 Уважаемые Коллеги! нужен софт чтоб запрограммировать Tait T2000II...  --  rk6bab
28.03.2013 09:19 Доброе утро! У меня проблема, принесли радиостанцию "Корсар КР-35...  --  mityai30
26.03.2013 10:27 Добавлю, что подключил через вышеупомянутый резистор 9 кОм к штек...  --  Nikola
26.03.2013 10:23 Все срослось, добавил недостающий резистор на 9 кОм в цепь RxD - ...  --  Nikola
25.03.2013 19:58 Nikola! Распиновка разъема есть здесь - forum.autoua.net/showflat...  --
25.03.2013 09:19 Nikola! В таком случае надо подать на универсальный программатор ...  --
24.03.2013 22:41 Пробовал - не идет!!! ...  --  Nikola
21.03.2013 16:50 Nikola! Попробуйте поменять местами провода Rx и Tx....  --
21.03.2013 11:57 Cобрал предложенную здесь cbradio.com.ua/showthread.php/452-Voyag...  --  Nikola
21.03.2013 11:54 Есть у кого cхема переходника под этот программатор для прошивки ...  --  Nikola
20.03.2013 22:43 rust,по своему опыту могу сказать,что подобные станции часто испо...  --  Анатолий
20.03.2013 11:54 rust, посмотрите комментарий от 23 декабря 2011 г. Похоже, дело ...  --  Евгений Андропо...
20.03.2013 11:51 Юрий ! Спасибо за сообщение, но комментарий был не мой, другого к...  --  Евгений Андропо...
20.03.2013 02:30 Радиостанция IC-F110 не видит прошивку СS-F100 1.7,пробовал и C...  --  rust
18.03.2013 15:17 Все заработало!!! Р/ст Радант-100(рт4200)шнур KEN-2 программа KSP...  --
18.03.2013 12:50 Надпись на бирке Радант-100 (РТ-100). Надписи на печатной плате в...  --  Юрий
17.03.2013 11:03 Юрий! Распиновка переходника для универсального программатора, в ...  --
17.03.2013 11:01 Получил,спасибо буду проверять!...  --  Юрий
16.03.2013 21:23 Почту проверил, кроме спама нет сообщений....  --  Юрий
16.03.2013 21:14 В понедельник проверю о результатах отпишусь, спасибо за наставле...  --  Юрий
16.03.2013 19:29 Юрий! Если это у Вас действительно KIRISUN PT4200 (внутри на плат...  --
16.03.2013 09:01 По s/manual kirisun 4200 шнуры для программирования: мини джек- ш...  --  Юрий
15.03.2013 22:45 Юрий! Универсальным программатором р/ст РАДАНТ 100 (РТ-100) про...  --
15.03.2013 17:38 Есть ли у кого нибудь положительный опыт программирования Р/ст РА...  --  Юрий
14.03.2013 19:59 Ну это уже только Ленивый не может обратить внимание на название ...  --  Ваадимир
14.03.2013 19:24 надо программатор с программой на кенвуд 2107 продайте. ...  --  Александр
14.03.2013 13:12 mityai30! В таком случае надо подать на универсальный программато...  --
14.03.2013 11:18 Да нет, станция родным шнурком и обычным софтом шьется, просто на...  --  mityai30
14.03.2013 09:35 помогите...  --
14.03.2013 09:34 Аеросани ехали 3 ч со скоростью 80 кл в ч а в следуйщие 2 ч их ск...  --  дима
13.03.2013 15:44 mityai30! На самом деле это HYT TM-628H. Если станция из автобуса...  --
13.03.2013 13:53 ни тот ни другой не идут, обидно придется родной шнурок искать...  --  mityai30
13.03.2013 10:57 mityai30! р/ст "Такт-201 П23--это тот же ICOM F-111 (переходник ...  --  Анатолий
13.03.2013 06:42 Спасибо! ...  --  mityai30
13.03.2013 03:14 mityai30! Переходник для универсального программатора, каким прош...  --
12.03.2013 21:53 Владимир! При замене EEPROM, ее надо прошить дампом, считанным с ...  --
12.03.2013 20:48 12.03.13. 02.53- при замене ее перезаливать ни чем не надо? или п...  --  Ваадимир
12.03.2013 13:10 Добрый день! Помогите пожалуйста, каким переходником прошить р/ст...  --  mityai30
12.03.2013 03:50 Владимир! Скорее всего, в р/ст TK-7020 есть проблемы с хранением ...  --
10.03.2013 18:20 ...  --  almjlaa
08.03.2013 11:42 Доброе утро! Всех ваших женщин с праздником! Теперь о деле! Ест...  --  Владимир
01.03.2013 10:50 Алексей, у меня была похожая ситуация...посмотри в подменю програ...  --  Анатолий RW4CFC...
28.02.2013 21:31 Частоты записываю в тех пределах которые определяет программа 400...  --  Алексей
22.02.2013 18:35 Алексей ! Если издает прерывистые звуки высокого тона, то это зн...  --
22.02.2013 15:44 Алексей ! Похоже, в одной из станций нет захвата ФАПЧ приёмника. ...  --  Евгений Андропо...
21.02.2013 16:17 Прошу помощи в следующем вопросе.Имеется пара ТК-3107 китаёзы пиш...  --  алексей
21.02.2013 15:23 можно ли запрграммировать Vertex VX-3200 каким либо другим пргра...  --  Юрий
20.02.2013 05:14 сергей ! Вы не можете общатся по рации Alan 42 с KENWOOD TK-3206,...  --
19.02.2013 09:59 могу ли я общатся по рации алан 42 с кенвод тк 3206...  --  сергей
16.02.2013 15:45 ...  --  gfdgsdfg
06.02.2013 19:23 Коллеги нужен софт чтоб запрограммировать Tait T2000II UHF T201...  --  Сергей RK6BAB...
06.02.2013 19:18 программатор проверен на радиостанции EF Johnson Challenger 7186 ...  --  Сергей RK6BAB...
26.01.2013 16:44 С помощью данного программатора прошил ROGER KP-45 (переходник KE...  --  Василий
18.01.2013 17:13 W3Sant, спасибо !...  --  Евгений Андропо...
18.01.2013 16:27 Доклад. Успешно прошил новый Нептун НМ-21с50 софтом СЕ82 версия 1...  --  W3Sant
17.01.2013 17:06 Анатолий RW4CFC! Надо использовать программатор как для F-111...  --
17.01.2013 15:07 Ещё может подскажешь,какой программатор использовать,как для F-11...  --  Анатолий RW4CFC...
17.01.2013 13:00 Все ошиблись) Ссылка на ic f-211 правильная, пробуй. Вроде прогр...  --  W3Sant
17.01.2013 12:41 Анатолий RW4CFC! Софт для программирования радиостанции Вихрь-211...  --
17.01.2013 10:51 Спасибо за ссылку,я ошибся в последнем сообщении,мне нужен софт д...  --  Анатолий RW4CFC...
17.01.2013 09:15 Анатолий RW4CFC! Софт для программирования радиостанции Вихрь-20...  --
16.01.2013 16:59 W3Sant Вихрь-201 автомобильная станция 25-ват,а F-11 носимая,та...  --  Анатолий RW4CFC...
16.01.2013 13:57 Вихрь-301 я шил ICOM-f16, попробуй по аналогии софт от f11...  --  W3Sant
16.01.2013 12:22 Подскажите каким софтом программировать Вихрь-211 (ICOM-???) и гд...  --  Анатолий RW4CF...
09.01.2013 10:38 Для UN7JC Сергей,у меня есть мануал для TK-760HG это примерно то ...  --  Анатолий RW4CFC...
09.01.2013 06:56 Спасибо за ответ! Но в документе по указанной сылке НЕТ принципиа...  --  Сергей UN7JC...
07.01.2013 21:25 Сергей UN7JC! Cервис мануал для TK-860H (TK-760H) возьмите здесь ...  --
07.01.2013 11:13 Прошу, пожалуйста помогите со схемой и сервис мануалом для TK-860...  --  Сергей UN7JC...
28.12.2012 16:26 Добрый день! Есть аппарат Heath SB-1400. Так понимаю, что аналог ...  --  Dmitry
28.12.2012 15:53 АСХАТ! Необходимо чтобы MOTOROLA GP328/ GP340 была одинакового ди...  --
28.12.2012 10:10 UA4AAE В программе прошивки станции (KPG55D) В меню Program в р...  --  Анатолий rw4cfc...
27.12.2012 17:42 Посоветуйте как сделать чтобы рация MOTOROLA GP-328/ GP340 ПРИНИМ...  --  АСХАТ
26.12.2012 10:33 Перепрошил ТК-2107 на144мгц.Все работает но сильно понизилась ч...  --  UA4AAE
21.12.2012 11:45 Владимир! Если в вашей р/ст IC-F211S стоит пароль на включение, ...  --
20.12.2012 13:12 Спасибо большое за ссылку....  --  Сергей
19.12.2012 21:17 Сергей! Софт R 02.02.00 - MD возьмите здесь - radioscanner.ru/fi...  --
19.12.2012 20:38 Парни,доброго времени суток всем. Если кто то может реально подск...  --  Владимир
19.12.2012 16:47 Уважаемые коллеги. Если у кого есть, скиньте пожалуйста софт для ...  --  Сергей
19.12.2012 06:14 bayron! Здесь обсуждается универсальный программатор и вопросы ...  --
18.12.2012 10:55 добрый день! могу ли я у вас попросить совета??? у напарника раци...  --  bayron
16.12.2012 16:22 tnx...  --  ahmet yılm...
11.12.2012 02:36 mityai30! Радиостанция Эрика 211 - это HYT TM-610. Переходник для...  --
10.12.2012 15:20 Помогите пожалуйста, нужен переходник для прошивки радиостанции "...  --  mityai30
08.12.2012 13:06 Пришла рация Vertex 160 v, глючная. Почему-то прошиваться не хот...  --  W3Sant
08.12.2012 13:02 Помогите прошивкой УКВ радиостанции АSELSAN 4021 Турецкого произв...  --  сансыз
04.12.2012 16:10 Универсальный программатор для радиостанций» ...  --  АЛЕКСАНДР RW6HK...
28.11.2012 17:09 В проге СЕ52Е В разделе СОМОN 2...  --
28.11.2012 14:57 как настроить радиостанция VERTEX 3200 уровень шума SQL...  --  JURABEK
25.11.2012 15:23 Мурат ! Я добавлю проверенные Вами станции в списки, пишите мне н...  --  Евгений Андропо...
24.11.2012 07:28 Для Icom IC-F521 чтобы сделать полный сброс, возьмите здесь - rad...  --
24.11.2012 06:49 Валерий ur5fmh! Если Вам нужно нужно запрограммировать р/ст Motor...  --
23.11.2012 22:22 пож. нужно запрограмировать рацию моторола gp328...  --  валерий ur5fmh...
23.11.2012 22:17 Мурат , твой программатор изменит программу в рации gp328 моторол...  --
23.11.2012 11:30 Добрый день! спасибо за программатор, успешно использую не первый...  --  Мурат
23.11.2012 04:25 Icom IC-F521 куда ковырять что бы сделать полный сброс настроек и...  --
16.11.2012 10:33 Спасибо, нашел. ...  --  RZ9YW
16.11.2012 06:52 Нужна программа для ALINCO DR135T, помогите!...  --  RZ9YW
16.11.2012 02:55 благодарствую, добрый человек! скачал, но жаль испытать теперь не...  --  Сашка
15.11.2012 20:36 Сашка! Для программирования р/ст icom ic f110s надо использовать...  --
15.11.2012 13:26 кабель использую экранированный, витая пара, выход с программато...  --  Сашка
15.11.2012 13:24 Здравствуйте! Не получается прошить icom ic f110s (ico 3), в то ж...  --  Сашка
13.11.2012 18:45 Для радиостанции ICOM IC-F521 сделать общий сброс настроек без п...  --
11.11.2012 10:39 Как снять с ключа или сделать общий сброс настроек без программат...  --
11.11.2012 06:49 Влад! Каким программатором и каким софтом шить р/ст ALAN HM-43 о...  --
10.11.2012 20:17 Помогите с программированием радиостанции ALAN43 ! Каким програм...  --  Влад
08.11.2012 09:10 Все, уже не надо нашли прогу которая подойдет - R 06.11.10. Всем ...  --  APTEMKA
07.11.2012 16:09 Уважаемый БУЦ, киньте на мыло пожалуйста. kor-buh@bk.ru...  --  Артемка
07.11.2012 15:02 Артёму.... есть R.06.10.06 НЕ УВЕРЕН,НО ДОЛЖНА ПОДОЙТИ.....  --  БУЦ
07.11.2012 13:00 Софт kpg56d тоже не подошел.Пробовал и Кенвудовским и универсальн...  --  Александр
07.11.2012 12:04 Доброго всем времени суток. Возникла проблемка с чем к Вам и пожа...  --  APTEMKA
05.11.2012 18:18 Александр! А Вы используете универсальный программатор + переходн...  --
05.11.2012 18:14 Александр! Софт может подойти этот - radioscanner.ru/files/kenwoo...  --
02.11.2012 15:33 Не могу найти софт для Моторолы GP-888. Кенвудовские коннектит но...  --  Александр
28.10.2012 11:53 Помогите с программатором на СМ-140 RKN4081B yt bltn...  --  айтжан
25.10.2012 14:44 ult vj;yj yfqnb cjan vjnjhjkf...  --  us8ido
17.10.2012 07:38 Большое спасибо. Буду рыть....  --  Pogonin
16.10.2012 19:50 Pogonin! Сервис-мануал на английском языке для р/ст Icom IC-F16/...  --
16.10.2012 10:51 Прошу помощи.Принесли 2 полностью убитые IC-F16.Если есть у кого ...  --  Pogonin
16.10.2012 09:50 спасибо,а софт не подошел,взял тот который от кенвуда TK 3107 и ...  --  Юрий
15.10.2012 22:24 Юрий! Используйте универсальный программатор + переходник - KEN-2...  --
15.10.2012 11:13 Подскажите чем можно прошить станцию kenwood tk 450 c 16 канальн...  --  Юрий
12.10.2012 23:39 Саша! Китай кенвуд тк-2207 у Вас видать с каким-то глюком и, кром...  --
12.10.2012 20:33 Не давно приобрел Китай кенвуд тк-2207 пришел по почте. Распакова...  --  Саша
10.10.2012 01:23 Вова! К процессору паять ничего не надо (угробите!). Возможно, чт...  --
03.10.2012 15:55 РУТА-Н 136-174мгц носимая. пробывал софт PG36D Программатор униве...  --  Вова
01.10.2012 06:03 Вова! Софт может подойти этот - radioscanner.ru/files/kenwood/fil...  --
30.09.2012 19:20 РУТА-Н 136-174МГц, носимая, не считывает и не програмирует! Прог...  --  Вова
28.09.2012 19:44 Сергей UN7JC! Программа для прошивки радиостанции Alinco DJ 191,...  --
28.09.2012 16:25 РУТА-Н 136-174мгц носимая. каким софтом шить???? шнурок ken-2 ???...  --  Вова
28.09.2012 13:54 Прошу , пожалуйста , помогите , пришлите программу ( DJ191 ) , п...  --  Сергей UN7JC...
21.09.2012 21:05 Ну что прозвонили? В принципе лорингофоны все совместимы. Или моя...  --  W3Sant
19.09.2012 07:11 Прошу помощи, О пресветлые интеллекты! Приобрел в интернет-магази...  --  Валентин
17.09.2012 14:58 Icom F3GS и Вихрь-301.П23 (Icom F16 то есть ) не прошиваются пере...  --  W3Sant
17.09.2012 11:51 Доброго времени суток! Благодарю за помощь в прошивке Icom IC-F50...  --  Игорь
15.09.2012 09:46 Виктор! Попробуйте этот софт - radioscanner.ru/files/motorola/fi...  --
14.09.2012 22:44 Доброго времени суток! Принесли две радиостанции Motorola GP340...  --  Виктор
07.09.2012 09:05 Всем привет. Нужна распиновка кабеля микрофона motorola gm660,вы...  --  Андрей
25.08.2012 12:14 Подскажите как прошить vertex 231, чтобы они работали между собой...  --  Роман
13.08.2012 17:01 Рация AJ 344, после ремонта не было дальности, сейчас не...  --  Прохор
11.08.2012 18:38 Кто знает как чем перепрошить VHF STR 8400 на любительские диапаз...  --  ALEX rv6br
11.08.2012 07:30 Рация "saracom bs-80" на приеме пищит, подскажите пожалуйста как...  --  Денис
31.07.2012 04:34 ra3ttn! Может Вы имели ввиду - Motorola GP340 ATEX ?...  --
30.07.2012 19:32 Программирует всё . , сегодня прошил китайские новинки Аргут А-2...  --  ra3ttn
28.07.2012 20:02 Михаил нужно открыть сохраненную прошивку и склонировать её...  --  7715
27.07.2012 08:37 Михаил! Возьмите софт и попробуйте вылечить - forum.cqham.ru/vie...  --
25.07.2012 12:36 Уважаемые соратники! Возникла проблема с радиостанцией Motorola ...  --  Михаил
22.07.2012 07:22 Всех приветствую ! скажите пожалуйста можно ли использовать рацию...  --  самсон
22.07.2012 07:09 Всех приветствую ! скажите пожалуйста можно ли использовать рацию...  --  safonov88@mail....
13.07.2012 19:17 Уважаемые коллеги ! Подскажите каким софтом прошить рацию " MOTO...  --  Вячеслав
08.07.2012 13:56 Проверил, работает на Anytone AT-5555, софт AT_5555 RADIO PROGRAM...  --  Андрей RN3QVG...
05.07.2012 23:38 Игорь! radioscanner.ru/files/icom/file13254/...  --
05.07.2012 10:53 Доброго времени суток! Помогите советом, В прошлом годе шил Icom...  --  Игорь
02.07.2012 12:41 Помогите с прошивкой УКВ р/ст Aselsan 4021...  --  Сансыз
28.06.2012 08:58 Адис ! Vector VT-47 Pilot программируется программой - "Soft_VT...  --
25.06.2012 05:58 всем привет! подскажитеюю у меня рацыя кенвуд тк-450а акумулятор ...  --  Ян
22.06.2012 00:15 Кто может подсказать как сменить серийный номер РЭС vertex vx 40...  --  Сергей
20.06.2012 14:09 Какой программой программируется Vectot VT-47 Pilot и какая схема...  --  Адис
15.06.2012 15:50 motorolacm140 soft...  --  sasha us8ido...
14.06.2012 23:43 Hola quiero saber si hay que cambiar algo para que funcione porqu...  --  margubom
05.06.2012 00:05 AnyTone AT-289 программируется с переходником для портативок Kenw...  --  Lifeless
28.05.2012 06:34 Aleksi! Да, если ваша радиостанция Motorola GP328. морская, то пе...  --
28.05.2012 06:27 Нет, радиостанцию vertex VX-2200 DO 50. невозможно прошить на кан...  --
25.05.2012 10:12 Добрый день. Ребята я в радиоделе чайник. Но есть проблема. У мен...  --  Aleksi
24.05.2012 14:05 Всем доброго времени суток!!! есть радиостанция vertex VX2200 DO ...  --  Ребяты!!! есть ...
09.05.2012 09:21 нужна прошивка ICOM IC-F310 на 144мгц...  --  Карим UA9WRT...
02.05.2012 12:10 BorisB! В инструкции написано, что необходимо использовать кабель...  --
25.04.2012 09:56 Программировал ли кто-то радиостанцию Anytone AT-289. Интересно к...  --  BorisB
20.04.2012 16:57 Нужна прошива на KENOOD TK_3107 ...  --  Z@H@R
20.04.2012 00:21 Есть ли у кого удачный опыт программирования р/ст KENWOOD TK-710...  --  zmey
17.04.2012 03:53 hello i want program senao sn258 ...  --  sobhe afana...
17.04.2012 02:51 necesito sofwera matorola maxtrac version R7.02.00a...  --  jose carranza...
16.04.2012 23:54 Есть ли у кого удачный опыт программирования р/ст KENWOOD TK-7100...  --
13.04.2012 21:55 Нэт ! Рабочий диапазон Радиостанции KENWOOD TK 3107 450 - 47...  --  Сансыз
13.04.2012 09:45 прошил р/с Связь R-44 KPG-87d...  --  Талга
12.04.2012 09:20 Добрый день. Подскажите вот по какому поводу. Приобрели беспровод...  --  Нэт
11.04.2012 08:43 Здравствуйте!Радиостанция IC-F110,прошивка CS-100,версия 1.7.Како...  --  Рустем
04.04.2012 03:45 schematic programming cable VPL-1..... at radio vertex, VX-2100-D...  --  Marcosbaldo...
02.04.2012 19:05 Всем доброго дня. Я приобрёл радиостанцию Vertex VXA -710 авиацио...  --  Юрий
02.04.2012 09:33 Спасибо за ссылку...  --  Иван
30.03.2012 15:02 Спасибо ребята с программой Motorola GM160 работает отлично вер...  --  Сансыз
30.03.2012 13:51 Программатор очень удобный собрал проверил в практике VERTEX VX-7...  --  Сансыз
30.03.2012 13:37 Помогите найти программу Моторола GM 160 ver. r.05.03.00...  --  Сансыз
30.03.2012 09:37 Иван, есть на этом сервере: cqham.ru/ftp/vertex.zip...  --  Евгений Андропо...
29.03.2012 14:52 Извиняюсь на FTH-2008 (в таблице прога числится как СЕ2)...  --  Иван
29.03.2012 14:46 Всем доброго дня. киньте пожалуйста кто-нибудь ссылку на прогу д...  --  Иван
28.03.2012 15:53 gp 328...  --  samantha
28.03.2012 04:28 Программирование Айком F-4...  --  Николай
27.03.2012 22:27 Здравствуйте! подскажите плз с проблеммой попала в руки рация YO...  --  valdis
25.03.2012 10:42 Всем доброго времени суток! Ребят, может кто сталкивался с програ...  --  Михаил [Neptun]...
25.03.2012 10:38 sansiz! Попробуйте этот софт radioscanner.ru/files/motorola/file1...  --
23.03.2012 08:06 Програма для радиостанции Моторола GM 160 ver.r.05.03.00...  --  sansiz
22.03.2012 10:13 как соединить провода к материнке уисви павер св и так далее? нар...  --  серега PAWER SW...
12.03.2012 23:49 где взять плату ctcss для 4p22b...  --  blondin
08.03.2012 11:55 Есть программы IC F-11 , Kenwood KPG-55 , нужна программа KPG-87...  --  Сергей un7jc...
07.03.2012 20:35 Спаял по печатной плате, согласно рекомендациям. когда прочитал в...  --  Qazbek
06.03.2012 18:45 а если рация постоянно пищит это значит что она чистая? тогда что...  --
06.03.2012 00:12 alinco dj191 на дисплее не полностью горит индикатор после точки...  --  александр, RU0A...
06.03.2012 00:05 alinco dj191 на дисплее не полностью горит индикатор ...  --  александр RU0AM...
04.03.2012 15:03 Виктор! В старых р/ст типа Roger KM-1618V применялся резервный ис...  --
02.03.2012 20:45 Канала записано два....  --  Виктор
02.03.2012 20:42 Евгеныч 1.Если рация непрерывно пещит Только при нажатии Txt ( п...  --  Олег
02.03.2012 20:07 Помогите вернуть радиостанцию Roger KM-1618V в заводские установк...  --  Виктор
01.03.2012 12:17 Доброго времени суток господа.... такое дело, имеется рация Ke...  --  Евгеныч
29.02.2012 18:56 Приобрел Yaesu FT-1900r к счастью оказалась раскрытая ! Появилась...  --  Дмитрий
27.02.2012 21:15 Кто нибудь раскрывал Yaesu FT-1900r на передачу ???Как ????...  --  Дмитрий
25.02.2012 23:52 Разобрался с программой FT60 Commander .Прога не работала из за т...  --  Дмитрий
18.02.2012 20:06 Кенвуд 2107 прошить удалось но другим софтом, KPG 55D напроч отка...  --  ОЛег
18.02.2012 20:05 Кенвуд 2107 прошить удалось но другим софтом, KPG 55D напроч отка...  --
15.02.2012 23:55 программатор исправен ! другие радиостанции программируются ! что...  --  Дмитрий
15.02.2012 23:50 FT60R не могу прошить универсальным программатором программа (FT6...  --  Дмитрий
15.02.2012 20:09 eh...  --  dth
15.02.2012 16:54 пикает рация kenwood TH-F2AT ,что надо сней делать? помогите ПЛИ...  --
15.02.2012 16:50 пикает рация kenwood TH-F2AT...  --
14.02.2012 18:12 Рация Kenwood TK-2260. Помогите с инструкцией на русском языке....  --  FOREST
14.02.2012 15:29 i need VER.NO:R05.09.06 help me plz...  --  ganee kh
14.02.2012 11:17 На Vertex VX-160EV какое должно быть напряжение между GND и (RX/T...  --  UA9WSJ
10.02.2012 15:39 Народ есть ли у кого инструкция на русском языке для kenwood tm-v...  --  tv-dima
10.02.2012 07:49 Добрый день!подскажите пожалуйста почему нет записи с Motorola GM...  --  Погонин Евгений...
10.02.2012 05:35 zif! usb преобразователь на FT232RS если желаете пробуйте на свой...  --
10.02.2012 05:28 Олег! Китайские ТК-2107 плохо читаются софтом KPG 55D из под Wind...  --
09.02.2012 20:13 Добрый день! Подскажите пожалуйста можно ли использовать за мест...  --  zif
07.02.2012 22:34 Здравствуйте, можете ли подсказать как можно поменять серийный но...  --  Александр,UB3RA...
07.02.2012 20:52 Подскажите кто знает, купил 2 рации Кенвуд 2107 попытался считать...  --  Олег
03.02.2012 22:31 Пока вопросов нет. Проверка ноутбука....  --  Валерий RK6ANW...
28.01.2012 01:54 Dima ! Полный Service manual есть здесь - mods.dk/downloadmanual....  --
27.01.2012 10:56 Здравствуйте! Ищется схема motorola GP 320. Заранее спасибо....  --  Dima
26.01.2012 19:08 mer30-mekhaham ba shoma ashna shavam.okhovatmehdi@yahoo.com...  --  onlineit
25.01.2012 10:35 Подскажите пожалуйста, есть Vertex VX 231. Не работает звук, то е...  --  Дмитрий
19.01.2012 09:31 Игорь! Вы можете скачать последнюю версию программного обеспечени...  --
19.01.2012 09:12 noshenko! В вашей р/стТитан TH-102 100% плохой аккумулятор и надо...  --
16.01.2012 20:24 Здраствуйте. я рацию Титан тн-102 диапазон 150-174 б/у. Но не мог...  --  noshenko
16.01.2012 12:11 Камрады.Помогите найти софт для Моторолы CP040 ver. R03.06.01....  --  Игорь
15.01.2012 11:55 hello...  --  ALI
15.01.2012 11:01 hello...  --  ali
15.01.2012 02:01 Спасибо! Kenwood-ы TK-2107 прошились на ура программой PG36D 1.05...  --  Роман Донсков...
14.01.2012 07:28 Ребят подскажите пож. подарили 4 рации hyt-500 но они не ловят др...  --  Баур
12.01.2012 16:58 Ребят подскожите купил рацию модели SoontoneST-518 не могу включи...  --  Дима
09.01.2012 23:11 Albrecht AE4400 можно перешить с FM на AM?...  --
08.01.2012 16:10 пришлите пожалуста программу для прошивки icom f-26,ольшое спосиб...  --
08.01.2012 15:35 пробовал перепрошить icom f-26,не видит программу подскажите.спос...  --
08.01.2012 15:14 подскажите как перепрошить icom f-26....  --  Максим
08.01.2012 02:43 Albrecht AE4400 можно перешить с FM на AM?...  --
08.01.2012 02:21 можно ли перешить рацию с fm на am...  --
05.01.2012 21:19 ...  --  колевид
27.12.2011 20:46 Всех с наступающим новым годом! Кто может на почту скинуть проши...  --  Сергей
25.12.2011 13:45 Алексей ! Rust ! Станция может быть запрограммирована версией по...  --  Andrejj
23.12.2011 12:46 Алексей ! Rust ! Станция может быть закрыта от чтения. В этом слу...  --  Евгений Андропо...
23.12.2011 11:35 Такая же проблема как и у Алексея,купили новую радиостанцию IC-F3...  --  Andrejj
23.12.2011 06:46 алексей! rust! radioscanner.ru/files/icom/file12188/...  --
23.12.2011 03:24 Такая же проблема как и у Алексея,купили новую радиостанцию IC-F...  --  rust
21.12.2011 14:35 приобрели радиостанцию IC-F3026T и программатор OPC-478UC и никак...  --  алексей
21.12.2011 00:09 Ребят, вопрос. Купил тк-2107, человечек забил частоту на нужные к...  --  Илья_я
20.12.2011 10:58 на Icom IC-F5026H - Попробуйте программу CS-F3160_F5060 Revision...  --  Andrejj
20.12.2011 10:45 И вас Валерий С наступающим Новым 2012 годом ! Як наши кажуть -ха...  --  Andrejj
20.12.2011 10:41 Радиостанция Icom IC-F5026H выводится на смену модели IC-F111 и к...  --  Andrejj
20.12.2011 08:39 Здравствуйте! Я купил радиостанцию ICOM IC-F5026H. У кого нибудь ...  --  Галымжан
20.12.2011 07:38 Народ у кого есть инструкций по радиостанций ICOM IC-F5026H? Спас...  --
20.12.2011 02:34 программист АТС! Изучайте - radioscanner.ru/files/icom/file9431/...  --
19.12.2011 07:13 Здравствуйте!!! Народ подскажите или у кого нибудь есть инструкци...  --  программист АТС...
18.12.2011 09:47 Андрей всё в норме- до Киева далече, нашел коллегу в Краснодаре п...  --  Валерий RK6ANW...
14.12.2011 16:41 ...  --  radar55719
14.12.2011 13:25 you it is necessary program R 05.07 , I have sent you on mail...  --  Andrejj
14.12.2011 10:14 any one who have codeplug lab tool for motorola cm series, or gm3...  --  DW2WBC
07.12.2011 22:04 Валерий у Вас все получилось или как ??? если нет то привозите в ...  --  Andrejj
07.12.2011 22:01 KEH-2.-главное проверь чтоб у тебя вся схема работала в станции )...  --  Andrejj
07.12.2011 12:06 Александр Вы правы схема подключения КЕН-2, а вот программа долж...  --  Andrejj
06.12.2011 18:49 andrejj Спасибо за ответ. Перепробовал всё пока не помогло.Будем ...  --  Александр
04.12.2011 17:20 test...  --  Николай
04.12.2011 16:16 Валерий: kpg29d.zip...  --  Andrejj
04.12.2011 15:56 Александр на Ваш вопрос :Подскажите как запрограмировать радиоста...  --  Andrejj
04.12.2011 15:47 Валерий отвечаю на ваш вопрос : Андрей спасибо за инфо. Есть еще ...  --  Andrejj
03.12.2011 14:47 Андрей спасибо за инфо. Есть еще один вопрос- можно ли перепрогра...  --  Валерий
02.12.2011 22:13 Подскажите как запрограмировать радиостанцию HYT TK-434. Какой ну...  --  Александр
02.12.2011 00:32 kpg21d.zip...  --  Andrejj
02.12.2011 00:06 1) Запускаем программу KPG21D . Прописываем нужные частоты TX/RX ...  --  Andrejj
02.12.2011 00:05 Уважаемый Валерий !!! на Ваш вопрос : Подскажите как перестроить ...  --  Andrejj
29.11.2011 20:15 Подскажите как перестроить ретранслятор KENWOOD TKR-720 на репитн...  --  Валерий RK6ANW...
29.11.2011 19:24 Как перестроить TKR-720 на репитерные каналы...  --  RK6ANW
29.11.2011 07:51 Дмитрий ! Ошибка #2436 Блок параметров поврежден - это проблема с...  --
25.11.2011 13:08 Михаил по Вашему вопросу :"Подскажите пожалуйста как подобрать ус...  --  Andrejj
25.11.2011 01:25 Подскажите пожалуйста как подобрать усилитель к рации? У меня Ico...  --  Миша
24.11.2011 18:45 на маийт кросог 2000 год...  --  деревенскиг...
24.11.2011 18:42 плагин нарадиол...  --  женя
22.11.2011 22:25 как перепрогрммировать рацию на другую частоту...  --  владимир
22.11.2011 13:47 «привет помогите у меня когда записываю диск ящик начинает трещат...  --  витя
21.11.2011 22:02 Здравствуйте! как можно опустить частоту на Kensung KG-6228 c 4...  --  viktor uu5jcp...
21.11.2011 18:02 Здравствуйте! как можно поднять частоту на Motorolla GM 300 c 146...  --
21.11.2011 16:36 Добрый день . Подскажите можно ли опустить нижнюю частоту у moto...  --  mikolasnn
20.11.2011 00:28 Всех я приветствую !!! Mогу одно сказать, по Вашем вопросам !!!! ...  --  Andrejj
18.11.2011 16:02 Здравствуйте. При чтении Motorola CP040 выскакивает ошибка #2436 ...  --  Дмитрий
17.11.2011 21:21 cофт для моторола gp-340...  --  ser0224
05.11.2011 16:59 Олег! Взять программу для ТК-7160Н можно здесь radioscanner.ru/fi...  --
05.11.2011 10:04 Добрый день. Подскажите где взять программу для ТК-7160Н...  --  Олег
27.10.2011 08:40 Доброго времени. Достались мне тут по случаю рация Icom ic-f110 Н...  --  андрей
27.10.2011 02:13 помогите пожалуйста настроить радиостанцию I-COM IC-V8000...  --  Виталий
24.10.2011 10:59 Уважаемые радиолюбители подскажите где можно взять софт на станци...  --  александр
22.10.2011 19:23 У кого есть софт для Motorola CP040 ver.03.00.01, скиньте пожалуй...  --  uk8gsa
20.10.2011 09:34 df...  --  booyo
17.10.2011 18:25 Ребят, подскажите схему коннектора и нужный софт для работы с ВЭБ...  --  Димас
16.10.2011 22:59 Уважаемые радиолюбители. Необходима Ваша помощь. Есть р.С Kenwood...  --  Юрий
14.10.2011 20:26 Alinco DR-605, некорректная работа кнопок UP и DOWN на тангенте, ...  --  Вадим
14.10.2011 14:15 Доброго времени. Достались мне тут по случаю 2 рации Icom f3 Но о...  --  Drogmoth
11.10.2011 12:04 Дмитрий! Чтобы запрограммировать радиостанцию Альтавия 301м нужен...  --
11.10.2011 00:09 купил но она молчит)) как настроить чтоб она работала??...  --  Дмитрий
11.10.2011 00:07 помогите натроить рацию альтавия 301м...  --  Дмитрий
07.10.2011 10:39 здравствуйте! приобрел станции motorolla gp340 firmware 03.13.0...  --  Anatoliy
04.10.2011 09:35 ...  --  121
01.10.2011 11:48 здравствуйте, помогите пожалуйста купил рации кенвуд 3107 две шту...  --  глеб
01.10.2011 05:39 Дмитрий8180! KENWOOD TK-280 нельзя прошить на канал дальнобойщико...  --
28.09.2011 19:18 привет всем. Подскажите плиз возможно ли прошить рацию KENWOOD TK...  --  Дмитрий8180...
20.09.2011 15:06 Motorola GM 340 не будет работать с контроллерами по скорости обм...  --
17.09.2011 21:20 Здравствуйте ! подскажите у нас Motorola GM 340 не хочет работать...  --
17.09.2011 18:36 Санька***! MOTOROLA GM360.нельзя прошить и сделать на волну даль...  --
17.09.2011 12:45 привет всем.купил MOTOROLA GM360.она запрограммирована на одну во...  --  Санька***
15.09.2011 19:01 Помогите найти прогу на ТК-3206 или 2206. Заранее спасибо....  --  Aitzhan
15.09.2011 18:49 frequeny 1575, 42MHZ BY-GPS-03.способы отключения приема сигнала....  --  стас
15.09.2011 18:44 frequeny 1575, 42MHZ BY-GPS-03 как заблокировать сигнал приема...  --  Стас
13.09.2011 10:10 ремонт радиостанций пропадает прием kenwood TH-F2...  --  us8ido
07.09.2011 12:24 подскажите пожалуйста как можно подключить запись разговоров с MO...  --  Погонин Евгений...
06.09.2011 19:54 Я так понимаю, этот программатор не работает с моторолами GP1200,...  --  Евгений
04.09.2011 23:08 подскажите пожалуйста каким программатором и какой нужен софт для...  --  александр
04.09.2011 08:59 Как снят ключ с радио станций?...  --  Арман Маргарян...
02.09.2011 07:57 Андрей! Отключите транкплату в рст. и проблема исчезнет....  --
02.09.2011 01:16 Господа.У меня проблемка с KENWOOD TK-278.При включении станции п...  --  Андрей
01.09.2011 16:15 можно ли подключить р-159 к машинному аккамулятору 6 ст-90?...  --  илюха
01.09.2011 04:55 I NNEED PROGRAMING FOR RADIO KENWOOD TK 2302 sem mais grdadecim...  --  KPG 119 FOR RAD...
01.09.2011 01:00 Обзавелся моторолой P180, при нажатии кнопок P1, P2 ничего не пр...  --  Dimon254
21.08.2011 17:04 как настроить 4се на alinco...  --  вова
19.08.2011 19:43 Добрый день! Помогите пожалуйста с программой. Аппарат ICOM IC-F-...  --  Виктор, RK6MP...
19.08.2011 10:29 Добрый день . Кто нибудь встречался с SIMOCO SRP8030. Софт ...  --  mikolasnn
17.08.2011 12:08 Добрый день! У меня есть рация ВОЛНА 301.01.П45 (аналог Motorola ...  --  Олег
16.08.2011 00:01 Всем привет! Повторил переходник-все проги для имеющихся рст- раб...  --
13.08.2011 12:41 как расчитать длинну наружной антены для рации кенвуд тк 180 а а...  --  сергей
12.08.2011 09:18 доброго времени суток. нужен софт для мото GP340 R03.16.00 -- R03...  --  Юрий
12.08.2011 02:38 Игорь! Софт для прошивки Icom IC-F110 и F111один и тот же(если об...  --
11.08.2011 16:53 Доброго времени суток ! Нужен софт для прошивки Icom IC-F111. Име...  --  Игорь
11.08.2011 16:23 Добрый день!!! ПОМОГИТЕ ПОЖАЛУЙСТА!!! купил рацию кенвуд ТК-2260-...  --  Иван
08.08.2011 09:41 Ал ! Попробуйте для начала установить ей нужный поддиапазон в про...  --  Евгений Андропо...
06.08.2011 05:27 Ал! KPG55D-LAB или KPG55D+ ремонтный переходник+ вторая точно т...  --
05.08.2011 22:35 Здравствуйте. Может поможите. Подскажите как исправить. Решил...  --  Ал
05.08.2011 17:19 Юрий ! Вдогонку. Порты 1 и 2 точно не ставьте. Поставьте номер пу...  --  Евгений Андропо...
05.08.2011 17:17 Юрий ! Полагаю, что игра с управлением потоков не поможет: програ...  --  Евгений Андропо...
04.08.2011 22:17 Подскажите где найти софт для Motorola GM360...  --  Анатолий, RA3TL...
04.08.2011 13:41 Сходил на комп, реанимировал icom, все пашет, собственно, что про...  --
04.08.2011 11:20 Снес драйвер, переустановил, в этот раз 24ый порт выделился. с3го...  --
03.08.2011 20:18 Юрий ! Про RIB коллега глубоко прав. Программа в своих сообщениях...  --  Евгений Андропо...
03.08.2011 15:30 Юрий ! Что такое RIB? - Radio Interface Box -->.batlabs.com/2wayr...  --
03.08.2011 13:06 в диспетчере устройств переходник определяется как silicon labs C...  --
03.08.2011 12:09 Юрий ! Для начала, воткнув переходник в ноутбук, пошарьте по дисп...  --  Евгений Андропо...
03.08.2011 11:02 подавал, конечно. Все равно рацию программа не читает. Пишет erro...  --
02.08.2011 11:47 Бабинский Юрий. Сызрань! Никто Вас судить строго не собирается, п...  --
02.08.2011 10:51 покупал готовый - интернетфирма masterKIT на нем 2 мс MB3243 и ...  --
30.07.2011 06:12 Бабинский Юрий. Сызрань! А переходник USB - COM у Вас какой(на ка...  --
28.07.2011 09:34 прошил Vertex VX-351 прог. CE-86win.Переходник YV-1B. На компе wi...  --  Бабинский Юрий....
20.07.2011 20:52 Помогите переключить kenwood TK-768H в режим индикации частоты а ...  --  RA9YON Виталий...
17.07.2011 18:21 да спасибо Евгений за ответ!!!...  --  Андрей
15.07.2011 09:02 Андрей ! Был у коллег некоторый опыт: kom-inform.euro.ru/programm...  --  Евгений Андропо...
14.07.2011 13:49 д день всем ! есть в наличии станция вертех VX-2500 и из компьюте...  --  Андрей
13.07.2011 22:22 Всем привет. помагите где можно купить универсальный програматор ...  --  Идият
13.07.2011 20:39 Богдан ! Да не за что. Если хотите, представьтесь мне на почту, я...  --  Евгений Андропо...
10.07.2011 22:54 Спасибо вам за труды!! Собрал программатор по вашей схеме - запро...  --  Богдан
08.07.2011 10:43 нашел рс РАДИЙ 301 хочу перепрошить...  --  vic
27.06.2011 08:04 Александр ! Перепроверьте цоколёвку разъёма, не перепутан ли поря...  --  Евгений Андропо...
25.06.2011 20:17 Добрый вечер! Возникла проблема при программировании Kenwood ЕЛ-7...  --  Александр
19.06.2011 15:21 хотелось б на него взглянуть...  --  rw6mip
18.06.2011 23:48 как найти подробный help по программированию IC-F521 на русском я...  --  EZ3AB
17.06.2011 12:42 помогите пожалуйста мне нужно прошить модем но я не могу найти пр...  --  катя
09.06.2011 16:52 Интересно......  --
09.06.2011 14:54 омогите найти софт для прошивки раций TK3200...  --  TK3200
06.06.2011 19:05 Помогите найти софт для прошивки раций icom ic-f210 оч. прошу!!!!...  --  brise89
02.06.2011 16:55 Здравствуйте!!!! Помогите зашить "радон-302 п23"...  --  vitaly
31.05.2011 15:02 Как скачат програмы Нужна программа для прошивки раций Айком Ф-1...  --  Сергій
23.05.2011 12:04 Помогите купить радиостанцию Волна-302. Спасибо. Можно б/у ...  --  Gastelo83
21.05.2011 05:39 goood......  --  bambang_lbs...
18.05.2011 16:13 Здравствуйте!!! Подскажите кто модет прошить китайскую рацию??? ...  --  Invzor
12.05.2011 07:31 Preciso do esquema do cabo para programar Motorola EP450 ...  --  Carlos
04.05.2011 16:37 Ищу софт под новую партию СР040 CPS R05.10 (R05.09 уже не по...  --  mikolasnn
03.05.2011 13:53 Вот и снова я! Схема работает безупречно, уже не один десяток рац...  --  Александр
01.05.2011 08:53 Помогите найти програмной обиспичени для Vertex standart 210 AU ...  --  hojisobir2011...
01.05.2011 08:49 Как скачат програмы vertex standart 210 au...  --  sobir
29.04.2011 15:34 otkuda skachat soft dlya kenwood k-4at ?...  --  mavr777
27.04.2011 14:56 Нужна программа для прошивки раций Айком Ф-11. Программатор есть ...  --  коря
24.04.2011 11:50 wbkb;nLQN ...  --  saleh
22.04.2011 15:44 g suis trГЁs ravir de rencontre. g suis a la recherche du pilote ...  --  Ayouba BARRY...
21.04.2011 04:08 ищу софт для -MOTOROLA- P-020 ...  --  ilia
12.04.2011 20:28 Николай RA1WJ ! А что Вы конкретно делаете (пишете, читаете), и к...  --  Евгений Андропо...
11.04.2011 20:43 SOFTWARE FTL2011...  --  TJONGTJITAMPUBO...
06.04.2011 00:49 где отыскать инструкцию - сервисный режим-инженерное меню на kenw...  --  ur5gan
04.04.2011 20:10 Доброго времени суток всем. Сделал универсальный программатор, у...  --  Николай RA1WJ...
31.03.2011 13:46 Здравствуйте! Удачно программировал радиостанции "Волна-201" разн...  --  UA3MKI
24.03.2011 15:35 извините, программу для перепрошивки ICOM -F5061....  --  metelay
24.03.2011 05:54 доброе время суток! подскажите ссылку программатора для ICOM IC-F...  --  Сергей
23.03.2011 14:13 дайте пожалуйста мануал на моторола ср 040...  --  леонид
22.03.2011 10:32 Программа professional radio cps версия R06.05.03 отлично сопряг...  --  ZagVity
21.03.2011 16:55 досталась пара раций титан ТН-102. скажите пожалуйста как ими пол...  --  Саша
17.03.2011 18:02 У кого есть софт или где можно найти KPG-60D для программирования...  --  RA9YDF
14.03.2011 11:01 Подскажите можно ли перепрошить частоты у FURUNO FM 55...  --  alex-s
11.03.2011 21:59 ZXCXCXCXC...  --  hhhhh
11.03.2011 21:37 kenwood 3107 softwear...  --  ihs
09.03.2011 22:37 Принципиальные схемы vertex vx 160 ev...  --
09.03.2011 21:23 kenwood tk-3107 какой адаптер для программирования рекомендован п...  --  andrey
06.03.2011 19:46 у меня моторола с350 когда я куда либо звоню у меня высвечивается...  --  оксана
06.03.2011 09:53 Добрый день. Подскажите как программировать Аргут-23,24 Где брат...  --  Андрей
04.03.2011 18:52 скачать сылки для обсуждении...  --  зинаида
03.03.2011 22:49 Помогите пожалуйста найти софт для Motorola CP040 ver.03.00.01 Н...  --  uk8gsa
01.03.2011 04:54 Hi, I need CPS R05.09 for Motorola GP3188, Thak-s a lot...  --  adi13mzb
27.02.2011 23:31 "ПОДСКАЖИТЕ , КАК ЗАПРОГРАМИРОВАТЬ GM300 И ПОЛНОЕ ИНФО ОБ ЭТОМ" П...  --
24.02.2011 11:34 m.x...  --  m.x@uol.com.br...
23.02.2011 17:53 Стала проблема перепрошивки каналов на радиостанциях Yaesu VX 200...  --  Спиридон
23.02.2011 16:58 ПОДСКАЖИТЕ , КАК ЗАПРОГРАМИРОВАТЬ GM300 И ПОЛНОЕ ИНФО ОБ ЭТОМ...  --  4X5204
22.02.2011 14:21 Подскажите пожалуйста, как и чем програмировать TWR DJ-300MU !!!...  --  ITotdelRIO
21.02.2011 06:31 Уважаемые господа!!! Нужна программа для программатора Р020...  --  Сергей, RA9MS...
20.02.2011 15:48 Чем можно заменить транзистор R4365...  --  nazy
17.02.2011 23:46 как настроить icom-r 20...  --  131313
16.02.2011 16:27 Подскажите пожалуйста, как подключить kenwood TK-760G к записываю...  --  armaz
13.02.2011 14:06 o sorft e o esquema do cabo e da rib do radio icom ic-f320-6 ag...  --  ricardo souza...
10.02.2011 21:37 как програмировать драгон 5430 3х канальный как ввести в режим пр...  --  евгений ур5гак...
08.02.2011 21:58 Мне нужно, чтобы программы Motorola Тип GP-380 № модели: azh25kdh...  --  ali ahmed
03.02.2011 12:02 КАК СНЯТЬ КЛЮЧ С РАЦИИ 7...  --  wezha
03.02.2011 03:43 vx150 service manual...  --  norberto
30.01.2011 23:10 koanoatbepxaehnr...  --  hhh
29.01.2011 17:53 cp140...  --  горинси
29.01.2011 14:55 Как собрать программатор на kenwood 2107 нужна схема...  --  василий
28.01.2011 17:37 как включить сканер на икоме...  --  wowa13
28.01.2011 10:41 Нужны прошивки на Моторолу GM300 VHF и UHF . Прошивки послетали ...  --  Storozh
27.01.2011 22:30 Ребят кто может поделиться софтом Kpd-100D или сылку рабочую где ...  --  Анатолии
27.01.2011 17:00 как найти программный софт на motorola gp340 r03 15.00 ...  --  rustem
24.01.2011 15:51 Нужна схема программатора для Alinco 130 . Лучше всего через сом ...  --  Анатолий
21.01.2011 10:59 граждане помогите пожалуйста ,как можно связать между собой motor...  --  Dmitry libya...
19.01.2011 14:08 добрый день ! подскажите пожалуйста распайку шнура для прошивки ...  --  виталий
16.01.2011 11:29 купил у таксистов Alinko-130 она зашита только на одну частоту и ...  --  RW4CGN
15.01.2011 19:01 радиостанция vx-2000v как перестроить на любительский диапазон?...  --  ua3eoi
14.01.2011 06:06 GM-360 зависла при апгрэйде и теперь не включается - кто сталкива...  --  Baya
13.01.2011 19:46 KENWOOD TK-3107 НЕ ПРОГРАММИРУЕТСЯ ПРОГРАММА KPG-55D И ПРОГРАММАТ...  --  VLAD UA4UCM...
13.01.2011 19:04 не програмируется TK-3107...  --  vlad,ua4ucm...
06.01.2011 17:39 скиньте пожалуйста инструкцию по применению для GP300 как и какие...  --  андрей
05.01.2011 18:13 Как перепрошить SIMOCO SRP8030/3?...  --  toxinz@mail.ru...
04.01.2011 19:48 jiny Точно такая же проблема обсуждалась вот здесь forum.cqham....  --
03.01.2011 14:21 В радиостанции Motorola CP-140 повреждён блок параметров,где найт...  --  jiny
02.01.2011 14:15 Подскажите пожалоста как прошить трубу SH-258 ...  --  panchenko_1962@...
01.01.2011 16:12 Доброго веремени суток Господа! помогите разобратся с программиро...  --  Игорь
27.12.2010 20:11 Как перепрошить SIMOCO SRP8030/3?...  --  Anton
27.12.2010 20:09 Кто подскажет где найти софт под радиостанцию SIMOCO SRP8030/31...  --  Fynjy
27.12.2010 13:24 Впаял EEPROM soic8 AT25160 в GM-600 ,каналов не добавилось. КАК ...  --  Alex
24.12.2010 01:11 Muy agradecido por esta buena informacion, gracias ...  --  eb2fyf
23.12.2010 10:15 не могу разобраться с моторолой жм350,пытаюсь перепрограммировать...  --  hitman
23.12.2010 06:49 hola...  --  jorge luis
20.12.2010 17:27 Расскажите чайнику о программированиии motorola cm 140, 160: чере...  --  Paulus11
20.12.2010 09:46 Помогите найти софт к Vertex-Standart VX-146....  --  mikolasnn
17.12.2010 12:26 вопрос-как этот программер применить для SENAO258 Евгений, доб...  --  yuri
16.12.2010 00:32 как узнать пароль на включение р/с icom ic F111...  --  серж
15.12.2010 06:12 GP680...  --  ivdmsr
13.12.2010 22:45 Товарищи! Мне достались Kenwood TK 3207(1). Кто подскажет где най...  --  Serg2009
08.12.2010 16:36 нужен софт для драгон су5430 sos...  --  UU4JCS
06.12.2010 16:58 soft ep 450...  --  soft ep 450...
02.12.2010 07:11 Просьба поделиться схемой и софтом для программирования радиостан...  --  Александр
01.12.2010 16:52 Николай ! Так это ж здорово ! Я добавлю Вас в списки. А если не с...  --  Евгений Андропо...
30.11.2010 21:17 Евгений! Теперь точно могу заявить, что Нептун НМ-22С25 - это VER...  --  Николай
30.11.2010 08:18 Николай ! У Вертекса много похожих мобилок, так что будьте внимат...  --  Евгений Андропо...
29.11.2010 21:33 Евгений доброго Вам времени суток! Действительно, станцию Нептун...  --  Николай
27.11.2010 21:36 Знаю, что станцию Joker tk-27 на си-би-Lpd (25-31 мГц) можно запр...  --  Алексей
27.11.2010 21:30 Здравствуйте, Joker tk-27 на си-би-Lpd (25-31 мГц) можно запрогра...  --  Алексей
26.11.2010 09:33 Николай ! Собственно не за что. Если удастся запрограммировать ст...  --  Евгений Андропо...
24.11.2010 08:55 Евгений большое спасибо. ...  --  Николай
24.11.2010 08:13 Николай ! По Нептун НР-41С смотрите сообщение от 30 марта 2010 г....  --  Евгений Андропо...
23.11.2010 23:50 Кто может помоч? Можно ли запрограммировать радиостанции Нептун Н...  --  Николай
20.11.2010 20:07 Ребята вышлете пожал. софт для р020...  --  ek6mk
20.11.2010 19:12 всегда приветствую помощ...  --  ek6mk
17.11.2010 09:42 пожалуйста помогите мне. Взял радиостанцию моторола GP340 и не м...  --  Барыкаас
16.11.2010 14:49 Игорь, большое спасибо за содержательное сообщение ! В ближайшее ...  --  Евгений Андропо...
16.11.2010 11:48 Евгений, здравствуйте!Примите благодарность за Ваш программатор. ...  --  Игорь/ RA0FMF...
16.11.2010 10:20 програматор gp320...  --  sasha
15.11.2010 13:12 вышлите пожалуйста kpg-87d версии выше 2 или выше.спасибо.romangp...  --  diez
15.11.2010 09:23 люди! Подскажите, как перевести TWR DJ-344KU в режим программиров...  --  Илья
11.11.2010 14:13 Господа подскажите можно ли использовать Носимые радиостанции Ken...  --  Дмитрий
11.11.2010 08:14 SOS!!! ПОМОГИТЕ!!! нужно программное обеспечение для Motorol...  --  AntAnta7119...
10.11.2010 09:27 Коллеги ! Ищу софт для MOTOROLA GP-380 ver. R03.13.00 !! Помоги...  --  Alex
03.11.2010 20:15 gp 340 не вклюяается...  --  ashot
03.11.2010 12:36 Serj ! Для начала точное сообщение программы про "не поддерживает...  --  Евгений Андропо...
03.11.2010 05:45 Мне нужна схема или схема для kpg46...  --  Javier Velez...
02.11.2010 19:10 Уважаемые коллеги! Подскажите чем можно прошить TK-7102H??? KPG-...  --  Serj
02.11.2010 14:38 перестройка частот icom ic-f21...  --  Toxa
02.11.2010 10:22 дайте программу на программатор с ком портом на гранит ...  --  боро22
29.10.2010 19:40 шил разные станции: Vertex, Motorola, Kenwood, а вот ICOM 6061 не...  --  vasay
28.10.2010 10:20 Гулливер. Про Аргут А-23 запрограммирована чем, универсальным про...  --  Vladimir
24.10.2010 16:40 p040 motorola soft chatím...  --  mrokár...
19.10.2010 23:13 To Dan!lkO Прошей себе мозг !!!...  --  vBuBen
19.10.2010 20:18 помогите найти программу для iCOM IC F-3...  --  UR5MHF
19.10.2010 13:01 Мне нужно схема от радио станцы айком F-26...  --  Muzaffar
16.10.2010 14:02 Всем привет помогите прошить ALINCO DR-M03 на базе DR-135 сейчас ...  --  Олег UA9SNW...
14.10.2010 22:06 Ув. Евгений, посмотрел по программе кпг-87д, в теst mode? там ест...  --  ur4ubq
14.10.2010 12:01 Евгений. Станция совершенно новая. Официальные Российские поставщ...  --
11.10.2010 13:03 CGV...  --  mrsimsima@YAHOO...
09.10.2010 12:21 Подскажите чем и как прошить рацию Midland Alan-42. Причина: треб...  --  Dan!lkO
07.10.2010 21:14 Добрый день . Помогите победить Motorola Radius ( судя по фото ко...  --  mikolasnn
07.10.2010 17:21 Сергей UH4HAC ! Было бы здорово получить подробности. Что конкрет...  --  Евгений Андропо...
05.10.2010 08:51 мне надо перепрашить рацию чтоб настраивать на все волны.рация V...  --  саша
04.10.2010 19:09 ОПИСАНИЕ KPG-87d Р/С TK2260 И ПРОГРАМАТОР...  --  ВАЛЕРА ФУРСЕНКО...
04.10.2010 15:41 Ищу софт на icom M-502....  --  Igor
04.10.2010 10:24 Нужна срочно схема на Гранит-203.01-25.Заранее СПАСИБО!...  --  михаил
04.10.2010 10:23 Нужна срочно схема на Гранит-203.01-25.Заранее СПАСИБО!...  --  михаил
01.10.2010 16:02 Евгений! Замечательный программатор, проблемма с программирование...  --  сергей UH4HAC...
28.09.2010 23:33 Евгений Андропов, радиостанция Кенвуд ТК2206 (2260 она же) имеет ...  --  Гость
23.09.2010 08:18 ur4ubq Vitalij, у Кенвудов есть две группы настроек. Первая: кана...  --  Евгений Андропо...
22.09.2010 22:12 да,принято,спасибо!схемку не меняли,это точно...но когда она была...  --  ur4ubq Vitalij...
20.09.2010 08:13 ur4ubq, спасибо Вам ! Докладываю Вам, что перепрограммированием к...  --  Евгений Андропо...
18.09.2010 22:26 Здравствуйте Евгений! Собрал программатор, но применил кт 3102,31...  --  ur4ubq
16.09.2010 14:49 Здравствуйте.Скинте схему распайки KENWOOD TK-3101 и схему програ...  --  Yurik-Z
15.09.2010 18:20 Уважаемые коллеги срочно нужен софт по программированию CP040 ски...  --  Ataman
15.09.2010 17:36 Ребята, подскажите распайку шнура для прошивки радиостанции iCOM ...  --
12.09.2010 17:12 Ребята где можно скачать программу на Icom IC-F33GT...  --  Руслан 18
09.09.2010 12:55 Запрограммировано 10 штук Vertex VX-231, софт CE99 ver. 2.02, тип...  --  RA3ICY
05.09.2010 08:17 Все для рации kenwood TK-450A (китай)...  --  Graf
05.09.2010 02:23 HI I AM DESPERATE FOR ICOM SOFTWARE CS-F310 FOR MY ICOM F310 US V...  --  m3ure
03.09.2010 12:11 Запрограммирована партия Аргутов А-23...  --  Гулливер
02.09.2010 13:04 подскажите как зашить моторолу GM300 под Вектор 25М...  --  Андрей
02.09.2010 12:27 Помогите! Как войти в режим дилера Kenwood TK 790...  --  Yesil
01.09.2010 14:45 помогите с софтом для программирования HYT TC-620 через кабель с...  --  Aseke
31.08.2010 13:00 cao...  --  igor x
30.08.2010 16:49 Прошу помощи! Как настраивается Kenwood TK-868G чтобы отображала ...  --  Alex
29.08.2010 19:11 Артур,переходник накенвуд тк-2107 такой же как и на тк 280 Если ...  --  RA0LHI
23.08.2010 16:21 sdfgsfg...  --  danial88
22.08.2010 20:05 для чайников как спаять колонки в один штекер обрезанный с под на...  --  mabust
22.08.2010 12:34 как перепрограмировать радиостанцию HX 180 на радиолюбительские ...  --  ua0lih
17.08.2010 10:43 Доброго времени суток! У меня после включения рация Motorolla CP-...  --  Роман
13.08.2010 17:15 Ak-117 Виктор ! В схеме все резисторы имеют допуск 5%, в этом слу...  --  Евгений Андропо...
12.08.2010 12:53 Выложите плиз рисунок печатной платы, либо фотки печатной платы п...  --  Ak-117 Виктор...
12.08.2010 12:23 Собираю программатор для GM300 и Kirisun PT3208 и PT3209/ Допуст...  --  Ak-117 Виктор...
10.08.2010 19:55 Вечер добрый.! У кого есть схема кабеля -переходника на KENWOOD ...  --  АРТУР
07.08.2010 16:02 Как прошить на частоту 152,700 радиостанцию KENWOOD TK-3107...  --  Artur Riegel...
06.08.2010 21:21 Добрый вечер! Не могу найти программатор KPG-60D. Если есть у ког...  --  remres
02.08.2010 22:18 Нужна инструкция по 86ручному программированию рации YAESU FTH-20...  --  Александр
30.07.2010 13:06 HELP!!! Купил с рук TK-7108 , но сейчас возникла необходимость пе...  --  Alex
23.07.2010 13:15 как программировать радиостанцию Эрика-211С...  --  waso
21.07.2010 09:56 добрый день народ у кого небуть есть схема програматора на радиос...  --  vit5alik
19.07.2010 06:13 hola , nesecito el software de programacion para el equipo motoro...  --  jose de venezue...
16.07.2010 23:25 Please, I need to know the programming software for portable r...  --  leon serantes...
13.07.2010 20:28 статья подробная ...  --  николай
11.07.2010 15:07 Где можно скачать програму прошывки для HYT TC-500...  --  Руслан 18
07.07.2010 20:26 Всем привет. Где можно найти инструкцию по эксплуатации Motorola...  --  СуХОЙ
05.07.2010 23:10 люди подскажите пожалуйста, как снять блокировку с канала на мото...  --  Sergey Driver...
02.07.2010 10:53 Александр ! Вполне возможно, конечно, что дело было в версии прог...  --  Евгений Андропо...
30.06.2010 21:07 Вот это лоханулся, решил поискать в инете другие версии KPG87D, н...  --  Александр
30.06.2010 14:39 Ну для чтения я выбираю read, вылетает окошко и там пока не нажме...  --  Александр
30.06.2010 13:28 Александр ! Нужно детально раскрыть, что значит "записывать не хо...  --  Евгений Андропо...
30.06.2010 10:19 Доброе время суток. Я Сташник Александр, из г. Снежное, Донецкой ...  --  Александр
30.06.2010 01:20 id software...  --  EFRE
26.06.2010 05:03 motorola...  --  ferreira
25.06.2010 17:47 Добавляйте в список, я не против. Я из г. РОСТОВА-НА-ДОНУ, ЕВГЕНИ...  --  ЕВГЕНИЙ
25.06.2010 08:01 ЕВГЕНИЙ ! Рад, что всё разъяснилось. Кстати о переходнике. Как по...  --  Евгений Андропо...
24.06.2010 15:33 как программировать радиостанцию AnyTone588...  --  Alik
24.06.2010 00:49 Проблема с motorola gm360 решена. Причина оказалась в раздолбаном...  --  ЕВГЕНИЙ
21.06.2010 17:45 Нужен soft для icom ic-f3023 если кто програмировал такую станцию...  --  RA9SPR
19.06.2010 22:55 Да,прога на русском, случайно наткнулся в интернете. Если нужна м...  --  ЕВГЕНИЙ
19.06.2010 22:38 Я так же произвел проверку схемы программатора. При открытом VT1 ...  --  ЕВГЕНИЙ
19.06.2010 22:19 ЕВГЕНИЙ ! У Вас есть русская версия программы, судя по надписям ?...  --  Евгений Андропо...
19.06.2010 15:09 подскажите кто-нибудь где найти прогу R03.05.00 ДЛЯ MOTOROLA GM 3...  --  ЕВГЕНИЙ
19.06.2010 12:32 udovliterno...  --  robertichinkadz...
19.06.2010 00:24 Я подключил р/ст motorola GM360 переходником МОТ 3 к программатор...  --  ЕВГЕНИЙ
18.06.2010 00:33 Любители и профессионалы! нужна ПОМОЩЬ... немогу зашить станцию ...  --
15.06.2010 07:49 Тёзка ! Переходник нужно использовать тот, который указан в табли...  --  Евгений Андропо...
14.06.2010 21:37 Подскажите пожалуйста какой переходник нужно использовать для под...  --  ЕВГЕНИЙ
14.06.2010 21:33 Подскажите пожалуйста какой переходник нужно использовать для под...  --  ЕВГЕНИЙ
13.06.2010 13:32 Sergeyye ! Программатор-то фирменный, а радиостанция ? Фирменные ...  --  Евгений Андропо...
12.06.2010 11:45 подскажите пожалуйста,как снять линейный выход прием передача с 2...  --  николай
11.06.2010 11:25 KENWOOD TK-3107 и её программирование. Пытаюсь читать через KPG-...  --  Sergeyye
08.06.2010 09:10 скинте прогу KPG 29 D...  --  cvmjl,
07.06.2010 21:57 нужна схема ic-F110...  --  US8IDO
07.06.2010 21:51 схемашс а110...  --  us8ido
07.06.2010 20:57 Коллеги, помогите найти программу для программирования YAESU FTH-...  --  rk3dim
07.06.2010 18:21 Коллеги, подскажите! После впаивания в тангенту (КМС-35) радиост...  --  delta777
04.06.2010 15:31 Спасибо за прогу. Но к сожалению у меня нет кабеля-програматера V...  --  Лехан
04.06.2010 10:09 ПОДСКАЖИТЕ ГДЕ МОЖНО СКАЧАТЬ ПРОГРАММНОЕ ОБЕСПЕЧЕНИЕ ДЛЯ MOTOROLL...  --  bakesha
28.05.2010 21:31 ПРОГРАМНОЕ ОБЕСПЕЧЕНИЕ ДЛЯ ALINCO DJ-344 MCP-318...  --  УА6ЁТЖН
27.05.2010 19:21 radar55719 Если на дисплее радиостанции “CLONE NG”, то возьмите С...  --  Виктория
27.05.2010 18:17 Icom IC-F210 зависла с надписью "СLONE NG" Помогите советом, зара...  --  radar55719
24.05.2010 21:32 Я молился, если кто-то программного обеспечения для Motorola cm34...  --  Ivan
24.05.2010 16:36 Здравствуйте все! Хочу поделиться как мне удалось исправить глючн...  --
24.05.2010 10:27 bonjour svp . je cherche le soft pour programmer les motorola ...  --  soltani
23.05.2010 17:59 Спасибо за прогу. Но к сожалению у меня нет кабеля-програматера V...  --  Алексей
22.05.2010 17:33 Уважаемые колеги помогите сраскрытием шумадава в ВОЛНЕ 101-П23 (G...  --  ru6fb
20.05.2010 18:36 gm160...  --  wesam
18.05.2010 22:48 спосибо...  --  lausov
18.05.2010 17:50 lausov это прошивка по частоте, она может работать только на...  --  USER
18.05.2010 00:38 люди поскажите если кто вкурсе друг подарил рацию vertex vx 417 н...  --  lausov
17.05.2010 20:45 tidak ada...  --  daeng gassing...
17.05.2010 18:18 У меня чслетела прошивка на VX-500. На дисплее одни прочерки "---...  --  Лехан
17.05.2010 08:33 люди поскажите если кто вкурсе друг подарил рацию vertex vx 417 н...  --  lausov
14.05.2010 09:14 софт на motorola p020 где скачать...  --  Andrei
12.05.2010 17:00 Подскажите пожалуйста, не могу ввести в прогу KPG-8OD частоту нап...  --  Виталий!
12.05.2010 15:12 Привет. У кого есть схема распайки разъёма Мotorola GM DATABOX...  --  Александр
12.05.2010 11:52 народ подскажите ID на софт KPG-101d...  --
12.05.2010 09:57 Новичок ! Пожалуй, на словах уже ничего подсказать нельзя, надо ж...  --  Евгений Андропо...
11.05.2010 16:03 Всем доброго дня! Евгений, все попробовали-результат тот же. Выбр...  --  Новичок
11.05.2010 15:58 Всем привет! Евгений, пробовали заменить аккумулятор-то же самое...  --  Новичок
11.05.2010 07:50 Новичок ! Для начала попробуйте почистить ластиком контакты аккум...  --  Евгений Андропо...
10.05.2010 15:47 Всех с праздником Победы! Евгений, поменяли аккумуятор, проверили...  --  Новичок
10.05.2010 15:07 Всех с праздником Победы! Евгений, поменяли аккумуятор, проверили...  --  Новичок
10.05.2010 15:03 Всех с праздником Победы! Евгений, поменяли аккумуятор, проверил...  --  Новичок
08.05.2010 21:13 ВСЕМ ЗДРАСТЯ! ПОМОГИТЕ РОЗОБРАЦА С ПРОГРАМАЦЕЕЙ KENWOOD TK-7100. ...  --  Виталий!
07.05.2010 17:07 Новичок ! В Вашей утопленнице GP340 скорее всего сдох аккумулятор...  --  Евгений Андропо...
07.05.2010 17:03 Александр RadioAmateur ! Меня, собственно, благодарить не за что,...  --  Евгений Андропо...
07.05.2010 14:43 Евгений, огромное спасибо за статью. С Майскими праздниками Всех,...  --  Александр Radio...
07.05.2010 09:28 Евгений, спасибо!...  --  Новичок
07.05.2010 09:25 Всем доброго дня и с наступающим праздником! Нужен совет специали...  --  Новичок
04.05.2010 22:06 Господа, Товарищи, Друзья.... Выручайте......Преобрел Я пару шту...  --  MgHerz
02.05.2010 19:25 Илья здравствуйте. Скорее всего ваши станции запрограммированы с...  --  Сергей RA0LHI...
24.04.2010 18:14 Друзья, блин срочный хелп, сижу на смене сутки. Помогите пожалуйс...  --  Илья, 3726
23.04.2010 23:46 Есть народ, кто в Питере сделает человека из GP680? Пишите в л/с ...  --  Александр, RA1A...
23.04.2010 21:24 очень нужен софт GP-340 R03.07.04...  --  Валера
23.04.2010 18:53 софт GP-340 R03.07.04 ...  --  vladimirovich60...
22.04.2010 21:44 dfhh...  --  fgjrj
21.04.2010 17:03 programas ...  --  anderson
21.04.2010 12:55 Hi Im from Poland I looking for software R03.02.07 to motorola ...  --  gomens
21.04.2010 07:49 МИША ! Полагаю, что такого описания просто не существует на русск...  --  Евгений Андропо...
21.04.2010 07:48 ra0lhi ! Для начала остановитесь всё-таки на какой-то версии прог...  --  Евгений Андропо...
20.04.2010 15:24 Привет Всем. Подскажите пожалуйста распиновку джеков гарнитуры на...  --  michail
19.04.2010 17:46 Доброго дня всем! А у меня вот какая проблемма,иногда приходитьс...  --  ra0lhi
18.04.2010 10:15 ДОБРЫЙ ДЕНЬ, УВАЖАЕМЫЕ РАДИОЛЮБИТЕЛИ И СОЧУВСТВУЮЩИЕ. КТО ПОМОЖЕ...  --  МИША
14.04.2010 16:46 Понятно. Спасибо. Я просто вообще не в курсе, как пики программит...  --  Алексей
12.04.2010 08:20 Алексей ! А разве в программаторе на PIC не требуется 12 В для вв...  --  Евгений Андропо...
12.04.2010 08:18 Новичок ! Как говорится, смотри пункт первый ;-))) А вообще с кон...  --  Евгений Андропо...
11.04.2010 09:25 Скажите, а можно используя этот программатор запрограммировать PI...  --  Алексей
11.04.2010 06:01 Доброго дня всем!!! Заработало!!! Причина банальная до тупмзма!!!...  --  Новичок
10.04.2010 07:42 Ни одна версия станцию не видит. Пишет"Проверьте, запитаны ли ус...  --  Новичок
09.04.2010 17:27 Новичок ! Приведите точное англоязычное сообщение программы, так ...  --  Евгений Андропо...
09.04.2010 10:23 Всем доброго дня! Евгений, спасибо за ответ. Все проверили: на ст...  --  Новичок
08.04.2010 13:52 Подскажите пожалуйста, кто нибудь программировал kenwood tk3206! ...  --  Kheruvim
07.04.2010 20:08 Новичок, смотрите почту....  --  Евгений Андропо...
07.04.2010 20:07 SergeyS, Вас понял, на досуге пополню списки....  --  Евгений Андропо...
07.04.2010 11:53 Нужна схема на Motorola CM140 и софт для прошивки R03.00.05...  --  roman1375
06.04.2010 22:30 Всем добрый день. Вопрос с поролем на GM 360 решон,Алексей провер...  --  ru6fb
06.04.2010 17:20 доброго дня всем!! Есть Моторола GP340 vR03.11.02. Привезли еще 1...  --  Новичок
05.04.2010 15:24 hi...  --  rw6hfx
04.04.2010 10:24 Сергей Сергеев . г.Ульяновск....  --  SergeyS
03.04.2010 20:25 SOTWARE yaesu fth_2010 vhf...  --  samer
02.04.2010 11:44 хотел прошить рацию моторолла с 350 на другую частоту т.к. чтобы ...  --  мелкий
02.04.2010 05:46 Привет всем. подскажите где взять или у кого есть софт на icom f-...  --  MONOLIT
01.04.2010 14:34 напишите как сделать рацию дома, на 2км ...  --  ребёнок
01.04.2010 07:47 SergeyS ! Спасибо за сообщение и поздравляю с успехом. Представьт...  --  Евгений Андропо...
01.04.2010 07:46 Otto ! Это известный подвох. Убедитесь, что в качестве десятичног...  --  Евгений Андропо...
30.03.2010 22:13 Здравствуйте. Евгениий, извините за несвоевременный ответ, да я д...  --  SergeyS
29.03.2010 23:55 Господа, помогите с програматором для ALAN HM-106 и ADI AR-147 Б...  --  Roliuks
29.03.2010 15:37 Господа, помогите, не могу прописать нужную частоту в проге KPG-8...  --  Otto
29.03.2010 14:09 Добрый день.подскажите плиз-при чтении GM360(R03.05.00)просит пар...  --  Алексей
29.03.2010 01:35 Скажите можно ли раскрыть (убрать пробелы) в скан. приемнике Radi...  --  Георгий
27.03.2010 20:55 i need software gp3188....urgent...  --  chiner
26.03.2010 14:35 КАК МОЖНО ВРУЧНУЮ (С КЛАВИАТУРЫ) ЗАПРОГРАММИРОВАТЬ КАНАЛЫ РАДИОСТ...  --  АРТЕМ
26.03.2010 07:52 SergeyS ! Поздравляю с успехом ! Действительно, мне стоило догада...  --  Евгений Андропо...
25.03.2010 22:13 Спасибо за ответ Евгений это действительно та же Vertex VX-410C ....  --  SergeyS
25.03.2010 07:56 SergeyS ! Похоже, радиостанция эта - клон кого-то из Вертексов, с...  --  Евгений Андропо...
24.03.2010 16:50 Здравствуйте. Подскажите пожалуйста как запрограммировать носимую...  --  SergeyS
19.03.2010 23:50 Добрый день. Подскажите пожалуйста при чтении и записи Motorola G...  --  ru6fb
19.03.2010 15:28 Константин ! Проблема скорее всего в контактах. Штеккеры, видимо,...  --  Евгений Андропо...
19.03.2010 14:38 Добрый день! нужен софт для носимой радиостанции Motorola CP140...  --  Radist
19.03.2010 13:45 Добрый день! Подскажите, пожалуйста. Собрал программатор по вашей...  --  Константин
18.03.2010 05:42 SLAVA! Софт для радиостанций старого типа motorola gm300 под Win ...  --
18.03.2010 03:59 tk 2302...  --  Swampfox
15.03.2010 19:16 vertex ...  --  doblek
15.03.2010 19:15 vertex vx2000u...  --  doblek
15.03.2010 17:40 Здраствуйте уважаемые специалисты ! У меня такая проблема:надо за...  --  SLAVA
14.03.2010 18:57 Serj ! Ваша станция, видно, сильно китайская. Тут заранее не угад...  --  Евгений Андропо...
14.03.2010 18:51 Игорь ! Очередное спасибо за содержательность. Да, интересно бы г...  --  Евгений Андропо...
14.03.2010 12:13 Здравствуйте Евгений!Такую схему я сделал давно около 1.5-2 лет н...  --  Игорь
13.03.2010 12:58 Здравствуйте уважаемые коллеги! Обращаюсь с просьбой, может кто ...  --  Serj
07.03.2010 20:49 Игорь ! Спасибо за содержательный отклик ! Совершенно точно, прог...  --  Евгений Андропо...
07.03.2010 17:46 Добрый день подскажите как связать 2 радиостанции Tevion PMR3000 ...  --  Сашок
07.03.2010 13:42 Статья отличная,все грамотно описано,осталось только разработать ...  --  Игорь
06.03.2010 12:39 Подскажите может кто знает как сделать АМ (110-130 Мгц) на радиос...  --
04.03.2010 20:16 Буду благодарен за помощь в приобретении проги KPG-118D Могу вз...  --  McAndy
01.03.2010 16:53 здравствуйте! ищу программатор или схему для ROGER KM1518...  --  Миха
28.02.2010 13:41 SLAVA софт отослал...  --  Иван
27.02.2010 22:01 приветик солнце...  --  salah
27.02.2010 05:37 ...  --  jojo laguisma...
26.02.2010 19:31 Здравствуйте уважаемые коллеги!Помогите с софтом на старую MOTORO...  --  SLAVA
26.02.2010 08:04 Помогите с софтом для Motorola CP-040 ver. r03.00.01 заранее бла...  --  UK8GSA
24.02.2010 16:23 радиостанций...  --  rada
24.02.2010 16:07 Уважаемые, ищу программатор для roger km 1518!...  --  Миха
24.02.2010 14:15 Санников Иван г. Нижнекамск, организация Дельта-кама, ремонт ради...  --  Иван
24.02.2010 00:55 Уважаемые радиолюбители подскажите где можно взять софт для IC- F...  --  vigrin
23.02.2010 16:25 разпиновка KPG-87D...  --  US7IHA
21.02.2010 11:05 Програмировал VX-2000V работает сутки и уплывает частота. С...  --  Валера
20.02.2010 22:43 can the icom program for ic-f320-6 be used with win xp pro...  --  ve2nwt
20.02.2010 21:02 bzxr...  --  koryagen
20.02.2010 08:18 Программатор класс! Помогите кто-нибудь! AR-146 Не входит в режим...  --  Владимир
19.02.2010 13:49 Иван ! Спасибо за добрые слова. Если представитесь как-нибудь пос...  --  Евгений Андропо...
19.02.2010 13:08 Господа хорошие, помогите найти инструкцию к KENWOOD ТК - 2260 - ...  --  nik13
18.02.2010 16:21 Понятно я просто посмотрел какая нумерация на простом сетевом каб...  --  Иван
18.02.2010 15:28 Иван ! Не за что. Мне попадались два варианта нумерации контактов...  --  Евгений Андропо...
17.02.2010 09:38 Восстановил как на схеме 4-5 контакт не заработало но потом перев...  --  Иван
16.02.2010 22:25 Евгений огромное спасибо за ответ попробую завтра ещё раз всё про...  --  Иван
16.02.2010 22:22 Виталий ! Против замечания не возражаю. ...  --  Евгений Андропо...
16.02.2010 22:11 Иван ! Менять выводы 4 и 5 порта никак нельзя. Земля именно на 5 ...  --  Евгений Андропо...
16.02.2010 20:58 nesecito el software para un vertex vx-2000u...  --  nathanael
16.02.2010 11:54 Евгений Андропов, по поводу вертексов - зато в них есть очень хор...  --  Виталий, rn4abg...
15.02.2010 19:55 Люди добрые помогите пожалуйста!!!! Собрал универсальный программ...  --  Иван
15.02.2010 07:57 Константин ! В самом конце статьи есть две ссылки. Зайдите туда, ...  --  Евгений Андропо...
13.02.2010 13:31 Здравствуйте! Помогите найти печатную плату и монтажную плату к ...  --  Константин, RA6...
05.02.2010 14:18 GM600 2шт не работают. Частоты на дисплее 1-ый 830, 2-ой 825, не ...  --  победа
05.02.2010 09:07 Есть ли где схема на Kenwood TK- 2107 c процессором HT46R23. Раци...  --  mikolasnn
03.02.2010 16:31 asheia ! Data read is protected by a password. You won-t read it ...  --  Yevgueny Androp...
03.02.2010 16:25 keen ! Достаточно в софте KPG-55D создать новый файл для станции ...  --  Евгений Андропо...
03.02.2010 14:53 Есть ли где схема на Kenwood TK- 2107 c процессором HT46R23. Рац...  --
03.02.2010 14:50 Спасибо за ответ 29 января 2010 г. в 16:54 Евгений Андропов П...  --  mikolasnn
03.02.2010 13:35 when reading the radio (motorola cp040) a message appeared "enter...  --  asheia
03.02.2010 10:18 Выписал с китая кабель, для программирования kenwood tk-2107, ест...  --  keen
02.02.2010 11:29 Люди добрые, подскажите плиз - Какие поломки могут быть у радиос...  --  Аленка
02.02.2010 08:07 Володя ! Первым делом я бы предположил отсутствие передачи на час...  --  Евгений Андропо...
02.02.2010 08:05 Алексей ! Не за что. Хотя я бы не вполне разделил Ваши положитель...  --  Евгений Андропо...
02.02.2010 00:32 Станция Моторола GM_640 Питание есть все подключено вклюочае...  --  Володя
01.02.2010 11:26 Ой, имя не вписал. Это я прошлый пост оставил....  --  Алексей
01.02.2010 11:25 Евгений Андропов! Эх... жалко! Так хотелось на радиолюбительский ...  --
01.02.2010 10:52 Алексей ! Мне как-то пару лет назад попадалась VX-2000U с транков...  --  Евгений Андропо...
31.01.2010 12:24 Евгений Андропов ! Радиостанция Yaesu VX-2000U, а транковый модул...  --  Алексей
29.01.2010 16:54 mikolasnn ! Внимательно проверьте переходник, чтобы никакие прово...  --  Евгений Андропо...
29.01.2010 12:09 Сижу день в тупике . Недели 2 назад нормально прошил 6штук FTL-...  --  mikolasnn
28.01.2010 20:19 Александр UN9FF ! Как я понимаю, Ваше сообщение продолжает наш ди...  --  Евгений Андропо...
28.01.2010 20:06 Алексей ! Было очевидно, что Вы догадаетесь о назначении диодов. ...  --  Евгений Андропо...
28.01.2010 11:03 Изминения схемы переходника KEN 1B. Для програмирования радиостан...  --  Александр UN9FF...
28.01.2010 04:20 срочно нужна схема на KENWOOD 2260 всех моделей.Пришлите на vonav...  --  Юрец
27.01.2010 19:14 А! Я понял, это через них питается схема от COM порта. Я просто п...  --  Алексей
26.01.2010 21:41 Скажите, а зачем нужны диоды VD3 и VD4, они же включены в обратно...  --  Алексей
26.01.2010 15:13 Кому нужны проги KPG для KENWOOD, могу помочь коллегам. Идём сюд...  --  McAndy
22.01.2010 12:51 Очень нужно перепрограммировать Alan 43 HM. Кто справится? Заране...  --  Алексей
22.01.2010 11:56 i want software for motorola gp280 16 channel full...  --  sami
19.01.2010 08:00 mikolasnn ! Прошу прощения, ALINCO DR-130 внесена в список ошибоч...  --  Евгений Андропо...
19.01.2010 07:06 Нужна инструкция по эксплуатации радиостанции Motorola CM160, жел...  --  vlad89
19.01.2010 07:01 Помогите прошить ALINCO DR-130 в софте ERW-2B файла на DR-130...  --  mikolasnn
18.01.2010 20:09 Подскажите действия для клонирования раций Motorola CP040...  --  pc01
18.01.2010 11:06 ПОМОГИТЕ НАЙТИ KPG 118D, а я могу отдать: 1. KPG48D TK-3101/...  --  nE sPROsTa
18.01.2010 01:26 Р.ст ICOM F-320S, выгорел стабилизатор 5в. После ремонта основной...  --  lirun
17.01.2010 14:27 Раньше у меня был транковый телефон ICOM IC-F3 теперь эта связь...  --  Сергей,RW4LAF...
17.01.2010 06:32 Подскажите ПЛИЗ!!! Купил Kenwood TK-2260-2 не знаю что с ней дел...  --  Серж
16.01.2010 10:30 chinese ham...  --  veidychen
15.01.2010 21:20 BOA TARDE PRECISO URGENTIMENTE DO PROGRAMA DO SOTWARE DO VERTEX S...  --  ARAGAO
15.01.2010 17:15 Помогите с софтом Motorola P020 и CM140...  --  Nikolay
14.01.2010 19:32 Спасибо,Евгений!Скорее всего,это клоны радиостанций "Roger"......  --  barhan070
14.01.2010 09:02 barhan070 ! В сети я видел аж два варианта Руты-Н. Очевидно, они...  --  Евгений Андропо...
14.01.2010 08:58 Levo ! Вся информация на данной странице есть. Схема программатор...  --  Евгений Андропо...
13.01.2010 20:22 Здравия всем! Подскажите,мужики,какой программой и каким програм...  --  barhan070
13.01.2010 10:43 Подскажите схему кабеля для прошивки ICOM F310...  --  Levo
30.12.2009 23:10 HOLA MUCHO GUSTA QUISIERA QUE ME AYUDARAN TENGO UN RADIO BASE TK ...  --  ALEX
29.12.2009 20:57 где взять программу для прошивки и схему кабеля для ICOM IC F111...  --  gleb
29.12.2009 16:39 otkudo mojno dostat programmu dlya programirovanie icom ic f 16?...  --  vigo
29.12.2009 14:45 Подскажите где скачать програматор для HYT-620...  --  Коля
29.12.2009 14:18 Привет всем! Подскажите где можно взять KPG-89D Заранее спасибо...  --  Раман
28.12.2009 22:58 Данным программатором перепрошил пару Моторол СР-040 диапазона 13...  --  Oleg P
28.12.2009 16:55 Народ, срочно нужна программа для Kenwood TK-3207(1). Пришлите на...  --
26.12.2009 12:08 Soft 3207, где взять ?...  --
26.12.2009 11:05 yebo gogo...  --  deskim
26.12.2009 09:21 где взять программу для прошивки ICOM IC F16 и ICOM IC F111 помог...  --  knr
23.12.2009 12:39 dvdfgerfcrfcrcvfgbdfgdfgd...  --  dfsdfsdfsd
22.12.2009 08:13 Александр ! Снять защиту от чтения не удастся. Просто запишите ст...  --  Евгений Андропо...
22.12.2009 00:43 Как снять защиту от чтения Icom F110S, или полный Reset Станции? ...  --  Александр
18.12.2009 21:33 terimakasih...  --  yohnny
17.12.2009 16:37 fffgf2rfg...  --  reggie
14.12.2009 14:15 KPG-55D software for programming TK-2102/2107/3102/3107. win xp -...  --
13.12.2009 16:39 KPG-55D software for programming TK-2102/2107/3102/3107. win xp...  --
13.12.2009 00:44 Народ, срочно нужна программа для Kenwood TK-2302-1. Пришлите на...  --  Igor
11.12.2009 15:24 Ребят, срочно нужна схемма на BRG FM-05-200 буду благодарен, у ...  --  [AMATRY]
10.12.2009 21:12 Подскажите где можно взять инструкцию на русском языке и как зака...  --  Сергей
10.12.2009 13:48 инструкция на русском для icom ic-F3gt...  --  roman
08.12.2009 16:20 NГѓO CONSSIGO PROGRAMAR IC-F320S ...  --  PY5MFI
06.12.2009 11:55 Евгений Андропов ! Я это понял, но везде где не был пишут одно, а...  --  александр ua3uc...
05.12.2009 19:45 Владимир RA3ICY ! В сети есть сообщения, что это клон радиостанци...  --  Евгений Андропо...
05.12.2009 19:31 Владимир RA3ICY ! Трудно сказать. Если бы удалось увидеть схему д...  --  Евгений Андропо...
05.12.2009 19:30 Александр ua3uca ! Нужен софт CSF100SADJ, если у Вас IC-F111S. Он...  --  Евгений Андропо...
05.12.2009 19:26 Подскажите пожалуйста можно ли вашим программатором запрограммиро...  --  Владимир RA3ICY...
05.12.2009 12:37 Привет всем! Помогите программно уменьшить мощность в icom f111s,...  --  александр ua3uc...
27.11.2009 10:54 Александр UN9FF! Ваша проблема решается путём уменьшения R1 с 12к...  --
27.11.2009 10:54 Александр UN9FF ! Не зная схемы хотя бы цепей программирования то...  --  Евгений Андропо...
26.11.2009 13:52 Я не правильно написал. Радиостанции не новые,просто другая парти...  --
26.11.2009 13:18 Александр UN9FF ! Очень странно, что новая партия радиостанций Т...  --  Евгений Андропо...
26.11.2009 06:13 i need download Professional GP300/GM300 Series CPS (R05.08.02_EN...  --  toan
25.11.2009 13:31 software za motorola cm340 i za motorola GM 950 koj ima da mi pus...  --  Kloster
25.11.2009 11:50 Люди добрые помогите, нужен полный комплект софта и всего другого...  --  maximilian1978...
25.11.2009 08:10 Програматор работает,приведённая схема работает с TKR 750 и с ТК ...  --
24.11.2009 14:15 Александр UN9FF ! Схема переходника подходит, я сам проверял неод...  --  Евгений Андропо...
24.11.2009 12:42 Помогите с переходником для Kenwwod TK8102H7102H.та схема переход...  --  Александр UN9FF...
24.11.2009 08:14 BeerLover ! Похоже, коллега прав: сбоят микросхемы EEPROM. Теорет...  --  Евгений Андропо...
23.11.2009 18:40 BeerLover! Похоже в сбойных станциях Kenwood TK-2260 бракованные...  --
23.11.2009 14:58 Подскажите плз. что за проблема с Kenwood TK-2260? А дело значит ...  --  BeerLover
22.11.2009 10:55 maloyy! Это невозможно поскольку KENWOOD TK 2206 работает на час...  --
20.11.2009 23:36 Подскажите возможно на KENWOOD TK 2206 настроить на волну которой...  --  maloyy
18.11.2009 11:20 Здравствуйте Всем! Помогите с софтом CSF14. Необходимо запрограмм...  --  Alex82uk
17.11.2009 13:10 senseu2008 ! Проверяли TK-890, так что и с TK-790 должно работат...  --  Евгений Андропо...
16.11.2009 18:31 Выдает ошибку ( Please check all connection and communication por...  --  senseu2008
16.11.2009 12:28 Хорошо бы привести конкретное сообщение об ошибке, которое выдаёт...  --  Евгений Андропо...
16.11.2009 11:25 Добрый день! Не могу программировать kenwood tk-790 появляется н...  --  senseu2008
15.11.2009 11:20 Ямалеев Игорь(jamigo) ! Переходник к Граниту 2Р-21М в статье пра...  --  Slava
15.11.2009 10:54 Здравствуйте mikolasnn ! Не поделитесь софтом которым прошилас...  --  Slava
13.11.2009 14:36 Странно GM-340 прошилась легко , а с GM-300 проблеммы. Я уже и на...  --  mikolasnn
13.11.2009 09:41 mikolasnn ! Программа для GM-300 под Виндами корректно работать н...  --  Евгений Андропо...
12.11.2009 13:58 А вот еще что завыл сказать . Под досом пробывал помучать GM-300...  --  mikolasnn
12.11.2009 13:52 Проблемма с Motorola GM-300, не могу запрограммировать. Под виндо...  --  mikolasnn
05.11.2009 21:55 Alex ! По правде сказать, так и не понял Ваш вопрос. По поводу не...  --  Евгений Андропо...
05.11.2009 21:53 jamigo ! Вас понял, спасибо, в списки добавлю !...  --  Евгений Андропо...
05.11.2009 19:42 Подскажите какие неисправности на радиостанциях: Кенвуд ТК 278, ...  --  Alex
05.11.2009 15:10 Евгений Андропов. Меня зовут Ямалеев Игорь....  --  jamigo
05.11.2009 10:16 jamigo ! С Гранитами нет полной ясности, по моим сведениям могли ...  --  Евгений Андропо...
04.11.2009 19:53 Евгений Андропов, единственная рация которая не поддалась к насто...  --  jamigo
04.11.2009 19:48 Евгений Андропов. Список радиостанций удачно прошитых универсальн...  --  jamigo
04.11.2009 11:09 motorola cp040 software downlaod...  --  baxa
04.11.2009 10:48 gfffffffffffffffffffffffffhhhhhhhhhhhhhhhhh...  --  vfcvcxvfff
30.10.2009 19:13 i need download Professional GP300/GM300 Series CPS (R05.08.02_EN...  --  mersad
30.10.2009 15:27 Есть у кого инструкция по применению к радиостанции KENWOD TK 220...  --  maloyy
30.10.2009 13:57 podskazite kakaia versia CPS nuzna dlia Motorola cm140 ver R04.00...  --  Real
30.10.2009 13:55 подскажите какая версия cps нужна РґР»С...  --  Real
30.10.2009 07:24 maks ! По всей видимости, в Ваших станциях не запрограммирован ни...  --  Евгений Андропо...
30.10.2009 07:17 vladislav ! Тут какая-то путаница. CM-160 - как раз мобильно-базо...  --  Евгений Андропо...
30.10.2009 07:11 jamigo ! Собственно, не за что. Айкомовские программы обычно выда...  --  Евгений Андропо...
29.10.2009 18:54 у меня 2 станции kenwwod TK-2206. включаю их а они пищат и больше...  --  maks
28.10.2009 07:05 Подскажите пожалуйста как можно прошить радиостанцию Motorola CM1...  --  vladislav
27.10.2009 19:54 Евгений Андропов, mikoolasnn, Спасибо за предоставленную инфу!!!...  --  jamigo
27.10.2009 09:42 Есть распиновка и прога на радиостанцию Motorola CM160? Премного ...  --  vlad_89rus
21.10.2009 08:52 FREDERIC KOUADIO! upload.com.ua/get/900295618...  --  Виктория
21.10.2009 02:40 MOTOROLA CP040 SOFTWARE DOWNLOAD...  --  FREDERIC KOUADI...
19.10.2009 20:10 господа где можно раздобыть инструкцию по использованию радиостан...  --  lexx 1974
18.10.2009 18:18 C...  --  RU9HT
16.10.2009 20:18 СЕРГЕЙ ! По "никак" нужна конкретика, иначе невозможно что-то ска...  --  Евгений Андропо...
13.10.2009 18:43 НУЖНА ПОМОЩЬ! ПРОГРАМИРОВАЛ КЕНВУД ТК 3107 ВСЕ ПРОШЛО НОРМАЛЬНО С...  --  СЕРГЕЙ
13.10.2009 17:38 ЮРА! Почитайте этот форум radioscanner.ru/forum/topic16784.html...  --  Виктория
13.10.2009 17:34 SLAVA! Всё то что Вы спрашиваете есть на этом сайте вот здесь cqh...  --  Виктория
13.10.2009 01:39 не работает переключение частот в YEASU FT-60R подскажите что дел...  --  ЮРА
12.10.2009 19:14 Помогите с софтом на MOTOROLA GM300старого типа( ver.R03.02.00) ,...  --  SLAVA
12.10.2009 15:20 RD3ZE! Извините вот правильные ссылки: forum.cqham.ru/viewtopi...  --  Виктория
12.10.2009 10:03 Виктория! Что не открываются у меня эти ссылки - ОШИБКА 404! :-(...  --
11.10.2009 09:52 awdawdaw...  --  aaa
10.10.2009 21:45 RD3ZE! А ещё почитайте здесь cqham.ru/viewtopic.php?t=9945&highl...  --  Виктория
10.10.2009 21:17 RD3ZE! Программатор для р/с "ЭРИКА"- 211( она же MAXON) собран ...  --  Виктория
10.10.2009 20:38 охранник! Посмотрите здесь cqham.ru/viewtopic.php?t=19485&postda...  --  Виктория
10.10.2009 20:31 GATI! Посмотрите на сайте radioscanner.ru в разделе "Файлы" ,"Ico...  --  Виктория
09.10.2009 12:41 Помогите найти программу для программирования радиостанции ICOM I...  --  GATI
09.10.2009 11:38 помогите найти софт на р/с моторола см 140 версия 03.03.04...  --  охранник
09.10.2009 10:46 Нужна помощь в программировании р/с "ЭРИКА"- 211. По какой схем...  --  RD3ZE
07.10.2009 19:02 Владимир! Kenwood TK 2160 с какой буквой в конце у Вас. Возможно...  --  Виктория
07.10.2009 17:30 lui66! Сообщите для какой радиостанции Вам нужно программу R05.0...  --  Виктория
07.10.2009 17:25 Александр! Вот здесь hamradio.online.ru/ftp/ic_f3xx.zip...  --  Виктория
07.10.2009 13:46 КЕнвуд TK 2160 и прошивальщик KPG-82D нешет рацию! помогите вариа...  --  Владимир
07.10.2009 08:55 Здравствуйте.Где можно взять программу R05.04...  --  lui66
06.10.2009 15:08 Vertex VXR-7000 Програмируеться нормално на пен4 2Ггц из под win9...  --  Марат
05.10.2009 18:42 Помогите найти программу для программирования радиостанции ICOM I...  --  Александр
05.10.2009 18:25 Здравствуйте! Может кто поможет с софтом MOTOROLA GM300 ver.R03.0...  --  SLAVA
05.10.2009 06:41 buran! Проверьте почту....  --  Виктория
05.10.2009 04:12 Где скачать и как программировать радиостанции icom-F16, icom-F21...  --  buran
29.09.2009 23:37 Виктор! Ответ здесь radioscanner.ru/forum/topic34066.html...  --  Виктория
29.09.2009 21:55 Радиостанция MagOne MP-300.Читается нормально. При попытке записи...  --  Виктор
29.09.2009 17:53 PLEASE PLEASE PLEAS I need R02.02.00AA - hamradio.online.ru/ftp3...  --  Виктория
29.09.2009 17:52 ГДЕ СКАЧАТЬ ПРОГРАММУ ДЛЯ ПРОШИВКИ СЕ-5 СЕ-7 99CH...  --  UT1YR
29.09.2009 15:52 Ozerskiy! Волна похожа на Motorola GM360 forum.cqham.ru/viewto...  --  Виктория
29.09.2009 03:00 Hi, I really really really need R02.02.00AA PLEASE PLEASE PLEASE ...  --  PLEASE PLEASE P...
27.09.2009 23:01 Всем привет !!!!!!!! подарили рацию Волна 302 но инструкции не...  --  Ozerskiy
27.09.2009 14:59 Euquenis Quintero! radioscanner.ru/forum/topic31901.html#msg55...  --  Виктория
26.09.2009 22:34 Mi nombre es Euquenis Quintero y resido en Cuba, tengo el Softwar...  --
26.09.2009 22:27 Necesito el manual para programar Kenwood TK 270G...  --  Euquenis Quinte...
23.09.2009 14:49 Sobesednik ! Что Вы имеете в виду под выходом схемы из режима при...  --  Евгений Андропо...
23.09.2009 10:25 Большое спосибо, Виктория. Уже скачал и проверил. всё работает. И...  --  Sobesednik
22.09.2009 19:12 jamigo ! А что Вы конкретно делаете (пишете, читаете), и какое ко...  --  Евгений Андропо...
22.09.2009 16:35 jamigo . Недавно прошивал Icom IC-F11 . Подавал питание от А...  --  mikoolasnn
22.09.2009 11:13 Очень надо подмогните? Лежт 15 радиостанций !!! Кто подскажет где...  --  миколаснн
22.09.2009 11:11 Никак не могу запрограммировать Icom IC-F11 soft CSF11 v1.2. Друг...  --  jamigo
21.09.2009 00:11 Sobesednik! Возьмите здесь hamradio.online.ru/ftp3/dw.php?P_%20...  --  Виктория
20.09.2009 07:04 Добрый день. Нужна программа CPS R02.02.00 на P040. Пробовал R02...  --  Sobesednik
19.09.2009 02:06 Софт для радиостанции SIMOCO SRP8030/31лежит здесь .tmcradio.com/...  --
18.09.2009 12:41 Очень надо подмогните? Лежт 15 радиостанций !!! Кто подскажет гд...  --
17.09.2009 19:39 Антон, rz6aqt! А в чем проблема? Берите софт KPG49D, есть на этом...  --  Виктория
17.09.2009 14:23 только пробелы все , подчеркивание не трогай убери h t t p://w...  --  olegscorpion...
17.09.2009 14:08 Кто подскажет где найти софт под радиостанцию SIMOCO SRP8030/31?...  --  mikolasnn
17.09.2009 12:14 Подскажите пожалуйста как прошить kenwood tk-280 ver 2.0 на радио...  --  Антон, rz6aqt...
14.09.2009 15:01 Просьба ко всем кто сталкивался с программированием радиостанций ...  --  Игорь
14.09.2009 14:53 Собран программатор. Всё хорошо работает.Не могу прошить Vertex V...  --  Андрей,ew1ra...
12.09.2009 23:31 tnx. 73...  --  TA2DC MEHMET ...
12.09.2009 00:33 Виктория благодарю!Изучу инф.Попробую грамотно нужную цифирь...  --  Петрович
11.09.2009 16:42 Петрович! Да, для программирующих кабелей Моторола - RIB не треб...  --  Виктория
11.09.2009 00:29 Виктория!Благодарю за скорый ответ . Вопрос возник ,после т...  --  Петрович
10.09.2009 22:58 Петрович! Нет, через кабель с COM 9 напрямую с компа нельзя. Нуж...  --  Виктория
10.09.2009 20:29 KPG-89D...  --
10.09.2009 17:53 Приветствую всех.Подскажите по-возможности,нужен ли RIB(прогр...  --  Петрович
09.09.2009 01:14 gp3188...  --  rara
08.09.2009 17:46 C-est bon ...  --  Cyriaque
03.09.2009 08:11 dmiman! Проверьте почту....  --  Виктория
03.09.2009 07:30 Здравствуйте а у Вас случаем нет распиновки разъема для Motorola ...  --  dmiman
02.09.2009 11:03 Игорь ! И Вам большое спасибо, я внесу Вас в списки. Шляпу не сни...  --  Евгений Андропо...
02.09.2009 08:14 Евгений, очередной раз снимаю пред Вами шляпу.С помощью Вашего т...  --  ra0fmf/Игорь...
31.08.2009 19:08 Sea l05! Возьмите здесь upload.com.ua/get/900295618 ...  --  Виктория
31.08.2009 17:34 Памагите с софтом пра "СМ-140,СМ-360"......  --  Sea l05
31.08.2009 16:01 Серж ! В текст вкралась опечатка. При поверке передатчика програм...  --  Евгений Андропо...
31.08.2009 13:10 Спасибо ответившему, действительно KPG55D в самый дефке огурец дл...  --  Алексей 3А12095...
30.08.2009 23:32 Впрос по схеме покаскадной проверки программатора (цепь передатчи...  --  Серж
30.08.2009 17:09 RA9YON! Вот здесь для Motorola MC2100 есть программа и схема ка...  --  Виктория
28.08.2009 08:38 Как прошить Motorola MC2100.Имеються две станции Motorola MC2100 ...  --  RA9YON
26.08.2009 02:29 глостер! Посмотрите здесь forum.cqham.ru/viewtopic.php?t=19939...  --  Виктория
25.08.2009 16:10 motorola CP140 пикает как неисправность с софтом для программиров...  --  глостер
21.08.2009 03:09 ua0jii! Распайку аксессуарного разъема GM300 смотрите на batlabs...  --  Виктория
20.08.2009 09:20 распайка разъема gm 300 в зади р/станци....  --
20.08.2009 09:16 адреса разъема gm 300...  --  ua0jii
20.08.2009 08:36 Motorola GP-227это чудо китайской техники и к настоящей Motorol...  --
19.08.2009 18:30 Вопрос Знатокам ! На днях принесли Motorola GP-227. Матерится на ...  --  Алексей 3А12095...
19.08.2009 02:41 Николай RA1WJ Возьмите здесь upload.com.ua/get/900295618...  --  Виктория
19.08.2009 01:50 muy buen articulo...  --  maturino
18.08.2009 23:43 Народ !!! Помогите с прогой на CM-140 и CP-140. Премного буду бло...  --  Николай RA1WJ...
18.08.2009 13:17 В KPG-29D проверьте выбор порта. Возможно, программа пытается пис...  --  Евгений Андропо...
18.08.2009 13:10 Ну не идёт, сволочь, ТК 768 и всё тут! И комп вполне старенький и...  --  brom
17.08.2009 11:10 инструкция радиостанция титан тн-102...  --
15.08.2009 21:44 Уважаемые коллеги я покупал кенвудовский шнурок китайского происх...  --
15.08.2009 02:19 saludos a todos..!! necesito el diagrama del programador de la me...  --  gusy180662
14.08.2009 18:49 tnx...  --  james richard...
14.08.2009 16:30 Мечтал я просто избежать рукоделия (я за кабл отдал $35-китайчати...  --  brom
14.08.2009 12:28 Kenwood ТК 768 чистый. Я про G читал ниже, похоже это дейсвительн...  --  brom
13.08.2009 20:47 brom! Каким софтом пытаетесь програмировать Kenwood ТК 768? Он у...  --  Виктория
13.08.2009 18:21 Люди! Выручайте! Пытаюсь програмнуть Kenwood ТК 768. Поимел кабел...  --  brom
12.08.2009 15:05 mikolasnn! Возьмите здесь upload.com.ua/get/900295618...  --  Виктория
12.08.2009 10:40 День добрый . Подскажите где софт найти под Motorola CP-140,...  --  mikolasnn
12.08.2009 05:00 марат! Проверьте почту....  --  Виктория
11.08.2009 20:09 TK-868G программировал в W98 без проблем ничего не переделывал пе...  --  ru6fb
11.08.2009 19:52 Всем добрый день, уважаемые коллеги подскажите по радиостанции ВО...  --  ru6fb
11.08.2009 14:47 56 запускал в хр а остальные из под win 98. Спасибо Виктория но э...  --  марат
11.08.2009 12:40 Марат ! По моим сведениям TK-868G производились Кенвудом специаль...  --  Евгений Андропо...
11.08.2009 12:36 Подскажите пожалуйста где можно взять схему на ELECTRA RU 210 ...  --  виталий
11.08.2009 08:42 Марат! Попробуйте этот софт radioscanner.ru/files/download/fi...  --  Виктория
11.08.2009 08:07 Схема от 768G. С програматором проблем нет им запрограмировано не...  --  Марат
10.08.2009 14:44 Марат ! Вам нужна схема именно TK-768G, а не TK-768 - это две сов...  --  Евгений Андропо...
10.08.2009 14:08 Со схемой Тк-768 я сверялся она не много не сходиться да проц раз...  --  марат
06.08.2009 18:49 hi...  --  hs2qfw
05.08.2009 13:14 Марат ! Сверяйтесь со схемой на TK-768G, она есть на этом сервере...  --  Евгений Андропо...
04.08.2009 13:27 Пишет please check all connection and communication port setting....  --
04.08.2009 12:29 Марат ! Перепроверьте нумерацию контактов в переходнике для Кенву...  --  Евгений Андропо...
04.08.2009 08:13 Всем добрый день. Есть не большая проблема как раньше здесь писал...  --  Марат
02.08.2009 21:21 soltani ! Cherchez sur le Web. Par exemple, on peut le trouver ic...  --  Yevgueny Androp...
02.08.2009 17:58 soft pour programmer le tk2160 KPG 82D...  --  soltani
02.08.2009 17:57 soft pour programmer le tk2160...  --  soltani
01.08.2009 01:08 Ra3vie Для GM360 нужен софт R03.01.02 Проверенно...  --  Alex
30.07.2009 15:20 ПЕТР ! Вряд ли Вы найдёте описание программы, справку к ней читай...  --  Евгений Андропо...
30.07.2009 13:04 Подскажите тех/хар alan 42 Зарание спасибо!...  --  Taksist Ed
30.07.2009 13:00 Подскажите техничиские характеристики alan 42 зарание спасибо!...  --  Taksist Ed
29.07.2009 15:40 Евгений Андропов! Спасибо за ответ! Схема правильна собрана 4раза...  --  ПЕТР
29.07.2009 12:46 подскажите где можно найти схему распайки кабеля программирования...  --  ievfr
28.07.2009 20:39 ПЕТР ! Чего делать по пунктам прописано в конце статьи после слов...  --  Евгений Андропо...
28.07.2009 18:45 Vertex VX-160U. Собрал программатор, есть се44 не могу законектиц...  --  ПЕТР
28.07.2009 11:04 Салам!!! У тебя есть программа TK-7060 (она же TK-760G), если ест...  --  Еркин
24.07.2009 12:04 Ищу софт на моторола GP680.Если у кого есть скиньте на почту пожа...  --  mif
22.07.2009 18:50 Как в vertex vx-3000 изменить девиацию?Можно ли это сделать прогр...  --  Игорь
21.07.2009 15:55 Ra3vie ! По всей видимости, русская версия не поддерживает данный...  --  Евгений Андропо...
21.07.2009 12:53 Русская (R03.09.03) пишет что то вроде "Невозможно считать - неве...  --  Ra3vie
21.07.2009 12:36 Ra3vie ! Конец статьи читайте, там по пунктам написано. У моторол...  --  Евгений Андропо...
21.07.2009 12:06 Спасибо! Вечером попробую, хотя вчера пробовал оба варианта - ни ...  --  Ra3vie
21.07.2009 11:51 Ra3vie ! Верно. Относительно Вашей ссылки - в обратном порядке. М...  --  Евгений Андропо...
21.07.2009 11:30 Спасибо за быстрый ответ! Т.е. если я правильно понял, если смотр...  --  Ra3vie
21.07.2009 11:15 Ra3vie ! Цитирую "для мобильных приведен вид на гнездо снаружи ст...  --  Евгений Андропо...
21.07.2009 10:35 Верна ли нумерация контактов разъёма RJ-45 для переходника МОТ-3 ...  --  Ra3vie
19.07.2009 13:55 Здравствуйте!!! Подарили рацию немогу настроиться на нужную часта...  --  ПЁТР
16.07.2009 10:58 все получилось, оказалось софт старый) Еще одну рацейку можно до...  --  Дмитрий
15.07.2009 17:25 Еще сюда напишу, подскажите как прошить Icom -f30gt, софтом польз...  --  Дмитрий
12.07.2009 13:11 андрик ! Инстр. на англ. из комплекта р/ст не помож., она для кон...  --  Евгений Андропо...
11.07.2009 00:24 люди! приобрёл кенвуд тк-2207,а инстр. на англ. помогите настроит...  --  андрик
06.07.2009 22:19 Александр ! Так и не понял, какую перемычку Вы впаяли, и станция ...  --  Евгений Андропо...
06.07.2009 15:45 Здравствуйте! Вопрос к знатокам электроники и программных дебрий....  --  Александр
04.07.2009 16:02 froes radioscanner.ru/files/download/file8179/tc700.rar...  --  Виктория
04.07.2009 01:45 I need of the software for programing frequency of the HYT TC-700...  --  froes
03.07.2009 17:15 Rus ! Действительно, чертёж платы потерялся. Напишу администратор...  --  Евгений Андропо...
03.07.2009 12:23 Подскажите ктонибудь где можно скинуть схему печатной платы на пр...  --  Rus
03.07.2009 01:37 Нет все решилось проще- при детальной проверке программатора OPC-...  --  Genn
02.07.2009 07:40 Genn! Для ICOM F-310 ( станция без S ?) возьмите Софт IC-F310 ...  --
02.07.2009 03:46 Здравствуйте.Вопрос к Виктории .Попала р/ст. ICOM F-310 с надпис...  --  Genn
01.07.2009 20:04 Радиостанция vertex vx-2000 программируется хорошо , а vx-3000 не...  --  Игорь
01.07.2009 11:33 Возможно ли запрограммировать радиостанцию носимую Motorola GP-14...  --  Алексей
01.07.2009 01:34 NESECITO EL PROGRAMA KPG-55D...  --  TEOTONIO BRANCO...
29.06.2009 22:02 we...  --  mei
29.06.2009 22:01 ok...  --  Wojtek
26.06.2009 22:13 mastak1972 ! Для начала давайте проверим, как Вы собрали ремонтны...  --  Евгений Андропо...
25.06.2009 20:23 test...  --  rob
25.06.2009 18:14 mastak1972! Невнимательно читали "...Идея проста: записывать ин...  --  Виктория
25.06.2009 11:24 всем привет дайте подробную схему на программатор ERW-4 Alinco...  --  ильяс
25.06.2009 07:26 Ещё вопрос:что за сигнал ARXD,на схеме программатора его нет....  --  mastak1972
25.06.2009 06:55 Виктория,эту статью я читал,программатор собрал.Каковы дальнейшие...  --  mastak1972
24.06.2009 14:35 mastak1972! Извините для Motorolla GM160 нужна другая "Фирменная...  --  Виктория
24.06.2009 14:29 mastak1972! forum.cqham.ru/viewtopic.php?t=16906...  --  Виктория
24.06.2009 10:31 Здравствуйте.Не могу прошить Motorolla GM-160.На дисплее самой ст...  --  mastak1972
23.06.2009 18:19 test...  --  bob
23.06.2009 04:46 Gracias...  --  Edgarin
22.06.2009 22:45 Hi! ПОМОГИТЕ НАЙТИ ПРОГРАММУ ДЛЯ ПРОГРАММИРОВАННИЯ Yaesu FT5100....  --  RA3ZOM
19.06.2009 14:41 Есть радиостанция kenwood ТК-270G. Не могу перевести на ручное п...  --  Max78
18.06.2009 22:59 download software motorola gp3188...  --  odhing
18.06.2009 03:32 filo! upload.com.ua/get/900295618...  --  Виктория
17.06.2009 11:29 softwere for motorola cm160...  --  filo
16.06.2009 06:20 rv3sfq! Посмотрите почту....  --  Виктория
14.06.2009 21:51 Виктория, модель номер M44GMC20D3AA версия программы R01.01.01 по...  --  rv3sfq
14.06.2009 17:55 rv3sfq! Сообщите номер модели GM300....  --  Виктория
14.06.2009 00:45 Неудачное програмирование GM-300. При прошивке пропало питание ст...  --  rv3sfq
11.06.2009 07:46 kaitipi! Ссофт для MOTOROLA GP344 здесь .forum.cqham.ru/viewtopi...  --  Виктория
11.06.2009 06:07 kaitipi! Посмотрите почту....  --  Виктория
10.06.2009 22:18 ищу софт для -MOTOROLA- P-020 и GP-344....  --  kaitipi
08.06.2009 19:42 qwqwwqwq...  --  wsw
08.06.2009 07:45 Andrei LZ1ATM Bulgaria ! Если есть вопросы пишите на e-mail...  --  Виктория
07.06.2009 22:59 Виктория разъяснение хачу плис помоги...  --  Andrei LZ1ATM B...
03.06.2009 21:48 Radio KENWOOD TK-2260 soft KPG-87D. Sobral programmator i s pervo...  --  Viktor UR5MTM...
03.06.2009 10:03 Aviator, в самой программе есть файлы с заводскими установками. Е...  --  RD3AN
31.05.2009 23:43 Aviator! Посмотрите почту....  --  Виктория
31.05.2009 23:35 tigru vaitan! radioscanner.ru/files/download/file8421/kpg-99de.z...  --  Виктория
31.05.2009 21:11 Виктория Пришел ...  --  Andrei LZ1ATM B...
31.05.2009 10:59 Доброго времени суток! Подскажите как снять пароль с GP-340, пол...  --  Aviator
30.05.2009 13:50 kpg99...  --  tigru vaitan...
29.05.2009 23:21 Andrei LZ1ATM Bulgaria! Пришлите мне файл codeplug.cps вашей Mot...  --  Виктория
29.05.2009 22:55 Виктория. Такое фаил нет "A4A5A6BBA5A5A5A5A5A5". и Такое нет"A...  --  Andrei LZ1ATM B...
24.05.2009 19:21 Виктория .большое спасибо ...  --  Andrei LZ1ATM B...
24.05.2009 03:58 Andrei LZ1ATM Bulgaria! Сделайте аналогично как здесь forum.cqh...  --  Виктория
23.05.2009 19:34 Motorola CM140 можно программируется нa 144-146 ? помогите ...  --  Andrei LZ1ATM B...
23.05.2009 16:41 Евгений Андропов, большое спасибо за разъяснение. Причина оказала...  --  Андрей Шунько...
23.05.2009 11:31 Андрей ! В кенвудовских станциях цепь передачи данных из процессо...  --  Евгений Андропо...
23.05.2009 11:10 Алексей ! Вы, видимо, ошиблись в нумерации контактов. Посмотрите ...  --  Евгений Андропо...
22.05.2009 22:43 А вот всё и запрограммировалось на GM-160 ! Виктория Гранд мерси....  --  libcnext
21.05.2009 16:14 При попытке прочитать TK-8080(на передней панели), она же TK-7060...  --  Андрей Шунько...
21.05.2009 11:10 Не программируется Kenwood TK-7108H. Пробовал с резистром 9,1 кО...  --  Алексей, Усть-К...
20.05.2009 10:57 Ищу софт на Motorola GM3688...  --  KEST
19.05.2009 05:04 Dikson! Посмотрите почту. ...  --  Виктория
18.05.2009 10:53 Народ, хелп!!! Есть 45 штук Motorola CM140, на всех стоит пароль ...  --  Dikson
17.05.2009 06:42 juan perez! forum.cqham.ru/viewtopic.php?t=12901&start=315...  --  Виктория
17.05.2009 06:40 radiovia! forum.cqham.ru/viewtopic.php?t=12901&start=315...  --  Виктория
16.05.2009 08:14 Hi, I need the soft for programing the portable P1225 pleace!!! ...  --  radiovia
16.05.2009 08:11 hola, si pudera ayudarme con el software para el LCS2000.para mov...  --  juan perez
15.05.2009 06:16 libcnext! Вот здесь софт для GM160 radioscanner.ru/files/downl...  --  Виктория
14.05.2009 22:24 Всё ещё ищу софт для GM-160 на двойку......  --  libcnext
13.05.2009 22:29 респект...  --
11.05.2009 21:12 Спасибо Виктории за победу....  --  libcnext
11.05.2009 21:09 Ищу софт для GM-160, MDM25KKF9AA5AE.Заранее Большое спасибо. ...  --  libcnext
10.05.2009 21:07 RA4PTA ! А Вы случаем не используете DOS-программу из Windows ? Н...  --  Евгений Андропо...
10.05.2009 14:19 помогите перепрошить FTL 2011 Собрал прграматог подключл установи...  --  RA4PTA
10.05.2009 00:04 Мужики, ищу инфу по программированию авиационки Vertex VXA-710. И...  --  Alone Stranger...
09.05.2009 23:34 Виктория,uu4jom! Можно попробовать так: В "Панель управления">>"Я...  --  Андрей Шунько...
08.05.2009 03:13 uu4jom ! Попробуй так: "ПУСК" - "НАСТРОЙКИ" - "ПАНЕЛЬ УПРАВЛЕНИ...  --  Виктория
07.05.2009 19:52 Евгений Андропов, не получается ни как точка вводится и 145.500 в...  --  uu4jom
06.05.2009 04:31 михаил UT1YR! Посмотрите на этом сайте forum.cqham.ru/viewtopic....  --  Виктория
05.05.2009 13:48 подскажите пожалуйста как сделать из 2х р/ст МОТОРОЛА СМ-340 рев...  --  михаил UT1YR...
04.05.2009 18:42 Виктория! Спасибо!...  --  dmittry
04.05.2009 11:08 Stanson ! В конце статьи "О неудачном программировании радиостанц...  --  Евгений Андропо...
03.05.2009 21:56 Доброго времени суток!!! подскажите новичку как запрограммировать...  --  Stanson
30.04.2009 18:58 libcnext! Посмотрите почту. ...  --  Виктория
30.04.2009 17:00 sam ! Дайте схему на "старый модем" или хотя бы на переходник со ...  --  Евгений Андропо...
30.04.2009 13:15 GM600 мод номер м08rhf4ck3bn программируется другая просисит дру...  --  libcnext
30.04.2009 06:07 Sem! Запустите софт, зайдите в "Program","Test Mode" и изменяйт...  --  Виктория
30.04.2009 00:49 Автор про модем...  --  sam
30.04.2009 00:46 Знаю что ключи подъездные прграмируют на обычном старом модеме,та...  --
29.04.2009 16:58 Как изменять мощность р/ст Kenwood 7760-5? В описании сказано мак...  --  Sem
29.04.2009 10:34 Виктория! ОГРОМНОЕ спасибо!!!...  --  Vasilisk
29.04.2009 04:18 dmittry! Здесь можно скачать программу на радиостанцию Альтавия...  --  Виктория
29.04.2009 04:10 Vasilisk! Посмотрите на этом сайте в разделе "Схемы радиостанций...  --  Виктория
27.04.2009 18:50 Подскажите пожалуйста, где можно скачать программу на радиостанци...  --  dmittry
27.04.2009 10:36 Виктория, спасибо большое за помощь! Уважаемые специалисты подска...  --  Vasilisk
26.04.2009 18:48 Спасите пожалуйсто YAESY System ft600, из 4х сеток зашита одна и ...  --  RX9UR
23.04.2009 22:09 Vasilisk! Посмотрите на этом сайте в разделе "Схемы радиостанций...  --  Виктория
23.04.2009 17:31 UU4JOM ! Вы вместо десятичной точки вводите запятую. Проверьте ра...  --  Евгений Андропо...
23.04.2009 12:17 Срочно нужна помощь программа и схема программатора для станций I...  --  Vasilisk
22.04.2009 11:20 Подскажите пожалуйста, не могу ввести в прогу KPG-8OD частоту нап...  --  UU4JOM
20.04.2009 16:49 может кто-нибудь пробовал ADI AR-147 ?...  --  Михаил. LY3BLB...
20.04.2009 06:39 libcnext! Посмотрите на этом сайте forum.cqham.ru/viewtopic.p...  --  Виктория
20.04.2009 06:32 serg! Посмотрите на сайте radioscanner.ru в разделе "Файлы","Ke...  --  Виктория
18.04.2009 20:17 Огромная просьба ко всем помогите разобраться ка программировать...  --  serg
18.04.2009 00:00 Попались две gm-600. не могу запрограммировать.кто чем поможет,за...  --  libcnext
17.04.2009 23:04 Подскажите, как перепрошить MAXON SL70? Программа SMP4004 (SMP600...  --  UU4JVK
09.04.2009 16:37 Максим! Посмотрите на этом сайте в разделе "Схемы радиостанций","...  --  Виктория
09.04.2009 15:31 УВАЖАЕМЫЕ РАДИОЛЮБИТЕЛИ ПОДСКАЖИТЕ, ГДЕ НАЙТИ ПРОГРАММУ ДЛЯ ПРОШИ...  --  Максим
09.04.2009 13:34 Помогите, пожалуйста, разобраться Слышал краем уха, что можно с ...  --  Максим
09.04.2009 13:13 Подскажите, пожалуйста, как перешить Титан ТН-102-1...  --  Максим
07.04.2009 18:21 Геннадий RA3TSX! Cпасти станцию от состояния “EEPROM CKSUM” можн...  --  Виктория
07.04.2009 17:40 Неудачное програмирование GP-680.Дисплей пишет EEPROM CKSUM. ...  --  Геннадий RA3T...
07.04.2009 14:24 Пробовал програнировать Kenwood TK-2207 программой KPG-87Dv1 -не ...  --  Влад
04.04.2009 12:11 нужна программа для прошивки радиостанции KENWOOD TK2107...  --
03.04.2009 21:49 Посоветуйте где можно найти инструкцию и схему по ICOM F4GS на ру...  --  Тарас
03.04.2009 21:40 nesecito todos los programas de motorola viejo ...  --  nathanael pined...
03.04.2009 20:31 после подачи 9-ти вольт на 5-й контакт разьема тангенты р/ст gm-3...  --  виталий
03.04.2009 19:34 Добрый вечер, есть вопрос по Граниу Р33П-1, немного не в тему кон...  --  Павел
03.04.2009 13:26 Здравствуйте уважаемые.Подскажите можно ли и как переделать прогр...  --  Андрей
03.04.2009 03:01 виталий! Напишите подробнее какой программой и программатором пол...  --  Виктория
03.04.2009 02:44 Игорь! ...А программируются китайские ТК2260 и аркомовские и неа...  --  Виктория
02.04.2009 23:48 Мужики, ищу инфу по программированию авиационки Vertex VXA-710. И...  --  Alone Stranger...
02.04.2009 21:20 gm-350 не становится в режим програмирования что делать...  --  виталий
02.04.2009 12:24 Игорь ! Возможно, Ваша TK-2260 киевского производства. Если станц...  --  Евгений Андропо...
02.04.2009 12:20 Александр ! На разъеме СМ160 контакты программирования должны быт...  --  Евгений Андропо...
01.04.2009 22:22 lubell1 Смотритте на этом сайте в разделе "Схемы радиостанций"....  --  Виктория
01.04.2009 20:02 где найти программу ( драйвер ) для прошивки раций ICOM...  --  lubell1
01.04.2009 17:21 Игорь! Если программа читает станцию и опредляет ее как TK-3207...  --  Виктория
31.03.2009 15:40 Помогите с подключением к Мотороле СМ160,не могу победить.На разь...  --  Александр
31.03.2009 06:49 спаял программатор, Kenwood TK-2260-5 читает- опознает как TK-320...  --  Игорь
24.03.2009 16:21 kase18! Посмотрите на сайте radioscanner.ru в разделе файлы....  --  Виктория
24.03.2009 14:47 Помогите найти софт и прошивки для Моторола GP380(390)...  --  kase18
24.03.2009 06:41 paaskalalex! Посмотрите почту. ...  --  Виктория
23.03.2009 12:22 может кто сталкивался с такой проблемой. GM 360 при считывании пр...  --  paaskalalex...
16.03.2009 11:38 как програмировать тк 2107...  --  12345678
12.03.2009 18:39 Максим snyper! Посмотрите почту. Возможно пароль TK-7120 или любо...  --  Виктория
10.03.2009 14:03 Помогите, пожалуйста! Нужно для Kenwood-а ПО KPG-99D. И может еще...  --  Максим snyper...
09.03.2009 20:58 Нувот,снова:)Забыл обозваться....  --  Андрей Шунько...
09.03.2009 20:55 Спасибо за консультацию.Как обычно невнимателен(писал по памяти)В...  --
09.03.2009 14:09 Подскажите как пользоваться прибором для настройки антены для рад...  --  Владимир
09.03.2009 12:09 Андрей ! То, что я нашёл в сети по Вашему Максону, говорит о необ...  --  Евгений Андропо...
08.03.2009 23:06 Спасибо Евгений!Действительно неправильно указал проверенные типы...  --  Андрей Шунько...
08.03.2009 17:34 Андрей, вопрос вдогонку. Вы имели в виду TK-2106Z, TH-3106Z или T...  --  Евгений Андропо...
08.03.2009 17:27 Уважаемый Андрей ! Вы у нас старый боец, Ваше сообщение о проверк...  --  Евгений Андропо...
08.03.2009 01:52 Подскажите,пожалуйста,можно ли подключить и каким образом Ваш про...  --  Андрей Шунько...
05.03.2009 22:26 Виктория, спасибо за информацию. А жалко, что нельзя обойти перез...  --  Евгений Андропо...
05.03.2009 22:18 Сергей ! Unlock на дисплее означает, что нет захвата ФАПЧ задающе...  --  Евгений Андропо...
05.03.2009 18:58 Евгений Андропов! Cпасти станцию от состояния “CLONE NG” с помощ...  --  Виктория
05.03.2009 17:11 Виктория большое Вам спасибо :)...  --  Антон
05.03.2009 12:32 Подскажите, ТК-270G не работает на передачу, при нажатии PTT- на...  --  Сергей
05.03.2009 10:27 Виктория ! Вопрос как к специалисту по ICOM. Не пытались ли Вы сп...  --  Евгений Андропо...
05.03.2009 10:19 Данияр ! Тут всё банально. Берите данный программатор, переходник...  --  Евгений Андропо...
05.03.2009 10:12 Владислав и RA1AGA ! Спасибо за сообщения, я внесу проверенные ва...  --  Евгений Андропо...
05.03.2009 07:15 Как сменить рабочую частоту на радиостанции TK-762G? за ранее вам...  --  Данияр
05.03.2009 06:28 Антон! Посмотрите почту....  --  Виктория
03.03.2009 23:56 Помогите плиз надо срочно схему по ICOM F4GS. Посоветуйте где мож...  --  Антон
03.03.2009 20:36 Прошу внести в список "проверенных" радиостанций Yaesu FT-8500 со...  --  RA1AGA
03.03.2009 09:20 Евгений Андропов. Прошу внести в список "проверенных" радиостанци...  --  Владислав Башае...
03.03.2009 08:58 Виктория, спасибо большое! Всё прошло именно так как вы посоветов...  --  Vladon79
03.03.2009 04:59 adawt Раскрытие китайского TK-K4AT или как поиметь двухдиапазон...  --  Виктория
02.03.2009 07:58 Vladon79 Извините вот так правильно. Если на дисплее радиостанци...  --  Виктория
02.03.2009 07:38 Vladon79 Если на дисплее радиостанции “CLONE NG”, то возьмите Со...  --  Виктория
01.03.2009 19:24 RA9C ! Микросхемы прошивать нельзя, тут уж извиняйте. Посмотрите ...  --  Евгений Андропо...
01.03.2009 11:24 Прошу если не жалко сбрости программу к радиостанцииСР140...  --  КОЛЬЧУРИН
28.02.2009 18:08 У меня Kenwood TK-K4AT 400-470МГц. Может кто подсказать как раскр...  --  adawt
26.02.2009 20:26 Программатор хорош ,заработал сразу . Питание взял с USB порта. ...  --  RA9C
23.02.2009 13:37 радиостанция IC-F41GT. на дисплее CLONE NG. программирование не п...  --  Vladon79
20.02.2009 13:50 soft Cp040 ver .R03.01.00...  --  slawo79
16.02.2009 22:37 Подскажите, как в рацию ICOM-F4GT перпрограмироватьна другой кна...  --  Виктор
16.02.2009 22:32 подскжите как увеличить сигнал(качество) приема рации ICOM-F4GT...  --  Витор
16.02.2009 02:38 Не могу прошить KENWOOD TK-280.при запуске программы KPG-49D на Ж...  --  николай
15.02.2009 00:33 не прошивается через com1 gm-300...  --
15.02.2009 00:30 не прошивается через com1...  --
12.02.2009 22:51 всем привет! скиньте пожалуйста если есть инстрекцию для радиоста...  --  дмитрий
12.02.2009 22:29 Motorola gm300 for 40> channel modifikasyon? Icom F-2020 rx tx 4...  --  TA2JU
11.02.2009 00:42 Подскажите где найти описание на IC-F110S. По програмированию нап...  --  sofrin
08.02.2009 00:35 народ, всем привет ! кто знает, чем и как программить Yaesu FTL 2...  --  Neptun
04.02.2009 21:59 отбой.спасибо,нашел на Вашем сайте.еще раз спасибо!...  --  николай
04.02.2009 21:44 доброго времени суток!подскажите распиновку разъема kenwood tk-28...  --  николай
03.02.2009 10:01 Подскажите, где взять прогу Alpha Series Radios CPS R01.07, для п...  --  Андрианов Андре...
31.01.2009 20:15 В схеме тестового переходника допущена ОШИБКА. Движок потенциомет...  --  Евгений Андропо...
31.01.2009 08:49 Egor ! Никак. Удовольствуйтесь первой......  --  Евгений Андропо...
30.01.2009 23:36 как найти мне вторую рацию моторола если я не знаю куда я ее дел?...  --  Egor
30.01.2009 15:06 Вы когда-либо получали программное обеспечение V3.10 или лучше дл...  --  Shaun
30.01.2009 15:00 Где скачать софт для Motorola CP-180...  --  ama
29.01.2009 18:43 Hola.Necesito el software KPG 101D con ID europea.Yo podria faci...  --  Jose
27.01.2009 17:55 Дмитрий ! Цепь R4, VD1, C1 формирует небольшое отрицательное напр...  --  Евгений Андропо...
25.01.2009 18:49 Здравствуйте! я собрал программатор, у меня вопрос по схеме: для ...  --  Сергеев Дмитрий...
24.01.2009 22:37 У меня 2 Моторолы P020, подскажите пожалуйста как пользоватся не ...  --  Dimon70
24.01.2009 18:58 Где взять программу для MOTOROLA CP040(R03.01.02) и GP 680(R02.00...  --
24.01.2009 01:05 Доброго времени суток вам! Попались 2 станции Motorola P080 R02....  --  Alex145
22.01.2009 04:46 ребята подскажите где взять програму для прошивки MOTOROLA GM-1...  --  taxi
21.01.2009 07:14 hi my name is batbyar Icom cs-2200H adj software help send me?...  --  batbayar
20.01.2009 09:18 TIALIV, EW7AT ! Ага, значит придется рулить станцией с клавиатуры...  --  Евгений Андропо...
19.01.2009 22:08 Спасибо, Евгений! На сайте "РАДИОСКАНЕР" мне убедительно подсказа...  --  TIALIV, EW7AT...
19.01.2009 09:33 TIALIV, EW7AT ! По-моему остается только одно - поспрашивать прог...  --  Евгений Андропо...
17.01.2009 06:43 Спасибо, Евгений! В дистрибутиве софта на IC-F1010(ЕХ 1764) нет ф...  --  TIALIV, EW7AT...
15.01.2009 10:45 TIALIV, EW7AT ! А в дистрибутиве софта на IC-F1010 точно не было ...  --  Евгений Андропо...
13.01.2009 20:21 Извиняюсь за невнимптельность. Программа Adjust ....  --  TIALIV, EW7AT...
13.01.2009 17:00 Спасибо Е. Андропову. Вывел IC-F1010 из коматозного состояния, но...  --  TIALIV, EW7AT...
13.01.2009 11:14 КТОНИБУТЬ СКИНТЕ СТАРИКУ ИНСТРУКЦИЮ ПО ПОЛЬЗОВАНИЮ НА РУССКОМ ЯЗЫ...  --  АЛЕКСАНДР
12.01.2009 15:52 нужен soft для CP160...  --  Станица
10.01.2009 21:26 Помогите найти программу TK-2306 Спасибо...  --  sasha001
10.01.2009 19:37 ras...  --  ANDREW
10.01.2009 19:22 Помогите найти програму KPG-87D или другую для рации kenwood 2260...  --  vital
09.01.2009 19:39 VXR-9000 REPEATER VHF VERTEX Service Manual Download...  --  sv2jpk
04.01.2009 10:48 где я могу скачать программу для прошивки радиостанции Ico...  --  Абдурафик ...
03.01.2009 13:33 VERTEX STANDRATD VX 2500 V...  --  BASKORO
01.01.2009 19:44 kenwood vhf radio tk-7100 progaraming software...  --  ibrahim
29.12.2008 15:12 Помогите пожалуйста!!! Очень нужна программа KPG-80d. у кого ест...  --
28.12.2008 20:46 Помогите пожалуйста, найти программу для программирования радиост...  --  Dex
25.12.2008 18:35 где скачать Kpg 55d...  --  валерий
24.12.2008 21:40 прошу вас скажите где мне можно найти прогу для прошива YAESU FTH...  --  wowan
24.12.2008 09:18 TIALIV, EW7AT ! В Айкомовских станциях есть специфический режим п...  --  Евгений Андропо...
24.12.2008 00:44 Программатор очень грамотно разработан. У меня заработал сразу.Пр...  --  TIALIV, EW7AT...
20.12.2008 12:17 YAESU 2000-vx. Помогите найти чертеж платы, без него в ремонт не ...  --  Bogdan
19.12.2008 12:08 ПРОГРАММЕР очень удачный, шьёт станции которые с обычным на MAX23...  --  KRONOS
16.12.2008 16:43 помогите найти программу для прошивки vertex 500...  --  box
16.12.2008 16:23 Мотрола М-208.Есть вероятность прошивать с бука(установлена ХР) ч...  --  vilius
16.12.2008 14:23 Может у кого имеется схема Урал РМ-206СА...  --  p petr
15.12.2008 15:47 manager...  --  gigi becali...
15.12.2008 15:34 как поднять мощность на кенвуд tk-2107 ватт до 10...  --  runx
15.12.2008 09:16 Странник ! Так в форуме ж обсуждалось совсем недавно. К примеру: ...  --  Евгений Андропо...
12.12.2008 16:20 Пож помогите с программой прошивки частот на радиостанцию Icom IC...  --  strannik
12.12.2008 11:28 Кто нибудь пробовал шить радиотелефоны, вчастности SENAO 258+. Ес...  --  Jeks175
11.12.2008 03:37 помогите с прошивкой тк-7760...  --  андрей 56
10.12.2008 16:32 HDHJZJZJ...  --
05.12.2008 05:44 люди добрые !!! ПОМОГИТЕ найти софт для Kenwood TK-3140 KPG-74D....  --  Василий
04.12.2008 09:57 koka62 ! Программирование Вертексов - задача творческая. Софты дл...  --  Евгений Андропо...
04.12.2008 09:35 Константин ! Странная какая-то у Вас станция. 868-е станции изгот...  --  Евгений Андропо...
04.12.2008 08:31 Всем доброго времени суток!!!Помогите с программированием Vertex ...  --  koka62
03.12.2008 13:54 Здраствуйте! Если кто знает подскажите пожалуйста как заблокирова...  --  Андрей
03.12.2008 00:15 Евгений спасибо за ответ. Диапазон действительно 400-470MHz напи...  --  Константин
02.12.2008 16:03 СОФТ не найдется ли у кого к китайской Kenwood TK-3206S?...  --  mikolasnn
02.12.2008 09:08 Константин ra4lz! Все Кенвуды с буквой G программируются KPG-56D....  --  Евгений Андропо...
29.11.2008 04:45 Здравствуйте все! Подскажите, какой софт использовать для TK-86...  --  Константин ra4l...
25.11.2008 13:36 ...  --
19.11.2008 09:14 ИЩУ ПРОГРАММУ ПРОШИВКИ РАДИОСТАНЦИИ IC-F3S...  --  АЛЕКСАНДР RK9A...
17.11.2008 11:53 Спасибо Евгений....  --  panoo
17.11.2008 10:08 panoo ! Я спросил у Гугеля: KPG-80D download... А Гугель отвечает...  --  Евгений Андропо...
16.11.2008 18:16 KPG-55D...  --  rezash
15.11.2008 04:15 necesito programar mi vertex vx2000u gracias...  --  juan ferrer...
14.11.2008 11:44 Спасибо Евгений. А подсажите где взять софт KPG-80D....  --  panoo
14.11.2008 09:13 panoo ! Это старый подвох от украинских Кенвудов. Вот: kom-inform...  --  Евгений Андропо...
13.11.2008 11:00 Добрый день. Братья помогите. Нужна прошивка для KENWOOD, но ес...  --  panoo
02.11.2008 07:26 как настроить волу на рации alinco dr-130 какими кнопками ...  --  Максим
31.10.2008 09:49 Борису. Набор проверенных станций ясен, доложите, как Вас предста...  --  Евгений Андропо...
30.10.2008 11:57 програмное обеспечение ...  --  коє
30.10.2008 11:44 Огромное СПАСИБО!!!!!!! Поменял LP -ВСЕ ПОШЛО!!! ОТЛИЧНЫЙ ПРОГРАМ...  --  Борис
30.10.2008 10:39 Борису. Для LP2950 маловато 4,92 В на выходе. Это весьма точный с...  --  Евгений Андропо...
29.10.2008 19:48 Евгений! Доброго времени суток. С питанием разобрался, был пробит...  --  Борис
29.10.2008 10:57 Борису. И Вам спасибо за отклик. По TK-7160HM. Станция действител...  --  Евгений Андропо...
29.10.2008 10:01 Вячеславу. Программатору как устройству все равно, какая операцио...  --  Евгений Андропо...
27.10.2008 15:44 Евгений СПАСИБО за программатор. Собрал, проверил поблочно, проши...  --  Борис
27.10.2008 10:42 УВАЖАЕМЫЕ РАДИОЛЮБИТЕЛИ ПОДСКАЖИТЕ ГДЕ НАЙТИ ПРОГРАММУ ДЛЯ ПРОШИВ...  --  ДИМА
27.10.2008 10:39 УВАЖАЕМЫЕ РАДИОЛЮБИТЕЛИ ПОДСКАЖИТЕ ГДЕ НАЙТИ ПРОГРАММУ ДЛЯ ПРОШИВ...  --  ДИМА
24.10.2008 14:50 Евгению Андропову. Добрый день.DOS я запускаю с жесткого диска. ...  --  Вячеслав
20.10.2008 22:52 SOFTW. MOTOROLA CP040...  --  FERRY
17.10.2008 23:23 Интересно...  --
17.10.2008 19:37 fdghd...  --  fdgh
15.10.2008 14:43 Вячеславу. Тогда давайте подробности, каким образом и на какой ма...  --  Евгений Андропо...
15.10.2008 14:27 Евгению Андропову.К сожалению,ничего из Вами предложенного не под...  --  Вячеслав
15.10.2008 04:17 soft motorola gp68 , vertex fth 7009...  --  turiano
14.10.2008 10:04 UT4UFS ! В первой схеме, по-моему, ошибка в подключении приема и ...  --  Евгений Андропо...
14.10.2008 09:56 Вячеславу. Попробуйте перенести в другую папку файл конфигурации ...  --  Евгений Андропо...
12.10.2008 13:51 Уважаемые радиолюбители!!! подскажите у меня есть станция kenwoo...  --  UT4UFS
10.10.2008 21:26 Кто-нибудь скиньте на мыло РАБОЧУЮ прогамму KPG-76D....  --  Freeman
10.10.2008 17:02 Добрый вечер!Прошу помощи!Радиостанция Icom IC-F320-6.Пробую любо...  --  Вячеслав
09.10.2008 04:42 Нужна схема MOTOROLA M208.Подскажите если не трудно где взять. За...  --  Саня
08.10.2008 19:35 Программа KPG-76D выдает ошибку an ansupported operation was att...  --  Freeman
26.09.2008 08:58 slon70! Насколько я знаю, искомая Вами схема совпадает с этой (TK...  --  Евгений Андропо...
25.09.2008 14:22 подскажите, есть ли у кого схема на kenwood tk-760g. меня очень и...  --  slon70
25.09.2008 01:23 prciso softwa para yaeso FTH7010...  --  traquino
24.09.2008 12:34 Подскажите пож Motorola tk 2107 как перепрошить шаг сетки для ...  --  rv3ld
23.09.2008 09:11 Владимиру. Эк Вы загнули - программа для прошивки на русском. Ник...  --  Евгений Андропо...
22.09.2008 19:54 Здравствуйте. Есть вопрос. На руках имеется MOTOROLA DATABOX VHF ...  --  UA4PKJ RUSTEM...
21.09.2008 19:42 Всем здравствуйте! У кого есть программа для прошивки ТК-3206 на ...  --  Владимир
20.09.2008 06:54 i want tait2000ii trasmitter schematic circuit...  --  sakhonnakonpoli...
19.09.2008 14:42 Очень нужен тип регулятора громкости радиостанции Motorola GM-340...  --
19.09.2008 09:24 Валентину UR3LGA. Похоже, что KENWOOD TK-7760 - это украинский кл...  --  Евгений Андропо...
19.09.2008 09:18 Free-man, и жить торопитесь, и чувствовать спешите, как писал АСП...  --  Евгений Андропо...
11.09.2008 22:44 Люди добрые помогите найти программу KPG-99D что бы перепрограмми...  --  Zavod
11.09.2008 20:25 Спасибо, кончно. НО... Здесь бывает куча радиоинженеров... неуже...  --  Free-man
11.09.2008 19:49 Доброго времени суток ВСЕМ! Подскажите пожалуйста где можно найти...  --  Александр
10.09.2008 21:42 подключил программатор к vertex VX-2200 и случайно выгрузил в рад...  --  igor
10.09.2008 18:45 Доброго времени суток ВСЕМ! Подскажите как за програмировать KEN...  --  Валентин UR3LGA...
03.09.2008 12:21 Надо програмировать ALAN HP-135k / то самое MIDLAND 80-125. Нуже...  --  Иван , LZ3IH...
02.09.2008 17:52 SOFTWARE FOR CP 040 4CHANEL DOWNLOAD...  --  FERRY
31.08.2008 18:21 Евгений спасибо за ответ,попробую найти какую-нибудь "старушку" т...  --  Олег, UN8GDZ...
30.08.2008 11:03 PROGRAMMER FOR: TK-2102/2107/3102/3107 WIN XP...  --  TONE
27.08.2008 10:32 Олегу UN8GDZ. Когда писали софт для P040, XP еще не было, да и ко...  --  Евгений Андропо...
26.08.2008 13:13 Ну оччень давно программировал Моторолу Р 040 проблем не было, т....  --  Олег,UN8GDZ...
25.08.2008 16:28 CE-63...  --  thank
25.08.2008 12:29 По поводу "У меня никак не получается прописать частоты..." Если ...  --  Евгений Андропо...
25.08.2008 12:25 Viktor ! Насколько я понял, Ваш программатор имеет двадцатипятико...  --  Евгений Андропо...
24.08.2008 10:15 can anyone mail me the software for motorolla cm 140 please...  --  gene kelly
23.08.2008 13:47 У меня никак не получается прописать частоты на Kenwood tk-2107 с...  --  р
22.08.2008 08:30 Подскажите кто знает распайку шнура для программирования tk 7108,...  --  Viktor
20.08.2008 02:14 diagrama rib hyt tm600u...  --  domingo
15.08.2008 00:06 Встретился с довольно интересным моментом KPG-55D. Требует, подле...  --  Kenjima
13.08.2008 22:02 HALO..i need kenwood tk-7108h software...help me please..i am fro...  --  boedy
13.08.2008 20:47 you have help , i dont have software R03.06.00 from GP340 ... yo...  --  Hello
07.08.2008 10:31 Ищу soft для программирования Motorola P020 I-m looking for the ...  --  Sergey5589
06.08.2008 08:39 sofwear de programacion de kenwood tm-v7 dual banda la que tiene ...  --  victor
05.08.2008 16:32 fhdh...  --
31.07.2008 23:19 i need a GP-328 software, you need a other sofware for radios of ...  --  MANUEL PEREZ...
30.07.2008 11:18 Владимиру US5LVS. Да, на двойке такая станция работать физически ...  --  Евгений Андропо...
29.07.2008 11:49 Евгению Анндропову.понял,попала случайно cm340 прошивается на 430...  --  Владимир us5lvs...
29.07.2008 09:32 Владимиру US5LVS. Конечно она не такая широкополосная. Есть ряд м...  --  Евгений Андропо...
28.07.2008 23:06 Добрый вечер,кто скажет motorola cm340 такая широкополосная 68-88...  --  ВЛАДИМИР US5LVS...
27.07.2008 21:07 всем здрасти!подскажите на рю ICOM F-16 как сканировать частоты ...  --  VAJAN1
27.07.2008 20:54 S.O.S в руках ICOM F-16 где можно найти инструкцию на русском и о...  --  VAJAN1
27.07.2008 19:11 Собрал програматор,вродебы работает,пытаюсь перепрограмировать с ...  --  Владимир us5lvs...
27.07.2008 18:52 Собрал програматор,вродебы работает,пытаюсь перепрограмировать с ...  --  Володя us5lvs...
25.07.2008 03:25 Доброго времени суток ВАМ! Подскажите пожалуйста где я могу на...  --  Каин
24.07.2008 21:15 Помогите пожалуста с програмным обеспечением к Motorola CP140 и C...  --  Сергей_555
24.07.2008 17:38 Евгений Андропов Евгений спасибо за инфо !...  --  Александр RA3NY...
24.07.2008 16:00 Александру RA3NY. На этом сайте есть рабочая программа KPG-29D. И...  --  Евгений Андропо...
24.07.2008 12:28 Здравствуйте всем ! Подкинте пожалуйста рабочий софтик,у кого ест...  --  Александр RA3NY...
24.07.2008 12:22 Здравствуйте всем ! Подкинте пожалуйста софтик ,у кого есть ,на K...  --  Александр RA3NY...
16.07.2008 09:55 Ник ! Ответ на Ваш вопрос см. в форуме forum.cqham.ru/viewtopic.p...  --  Евгений Андропо...
15.07.2008 12:16 Добрый день! Прошу совета. Принесли новую р/станцию «Kenwood TK-...  --  Ник
09.07.2008 12:43 kidiud...  --  panoo
09.07.2008 11:49 I have this software do you buy this software? price?...  --  john
08.07.2008 09:58 Tank ! Поищите в сети другие версии этого же программного обеспеч...  --  Евгений Андропо...
08.07.2008 01:36 Уважаемые коллеги прогомматор собрал, работает отлично. но попа...  --  Tank
04.07.2008 03:14 VX 160 SCHEMATICS...  --  PEIBBO
03.07.2008 17:07 кому нужна прога для китайской станции kenwood -3206 обращайтесь...  --  olim
03.07.2008 02:25 ola gostaria de receber o solft do vx25000...  --  VX2500
02.07.2008 21:29 Спасибо ответившим будем искать...  --  Гена
02.07.2008 10:43 Гене. Мотороловская программа на 300-ю серию не рассчитана на ста...  --  Евгений Андропо...
01.07.2008 18:34 Привет радиолюбителям советом помогите плиз Программатор собра...  --  Гена
30.06.2008 15:26 Павлу. Программатор должен быть тот же самый, переходник Y/V-2, п...  --
30.06.2008 13:16 Подскажите каким програматором и какой програмкой шьется Репитр V...  --  Павел
30.06.2008 11:49 About the programming software KPG29D. Take it from this server, ...  --  Yevgueny Androp...
30.06.2008 11:00 Владимиру Баландину. Рад что все получилось. В программировании р...  --  Евгений Андропо...
30.06.2008 01:52 Моя благодарность Евгений за ответ - спасибо я все получил. Преды...  --  Владимир Баланд...
29.06.2008 18:21 Евгений, здравствуйте ! В разделе "ГЛАС НАРОДА" вижу что Вы напис...  --  Владимир Баланд...
27.06.2008 23:05 x...  --  ector
27.06.2008 17:38 I have the programming software KPG 29D but i can´t open the...  --  programming sof...
27.06.2008 09:46 Владимиру Баландину. Для сканирования кнопку назначить мало. Нужн...  --  Евгений Андропо...
27.06.2008 01:37 Здравствуйте, программирую р/станцию VX-2500V, запрограммировал н...  --  Владимир Баланд...
26.06.2008 21:49 necesito por favor el programa del radio cp200...  --  Jorge oliva...
26.06.2008 11:41 Здравствуйте, программирую VX-2500V прога CE-52E станция програми...  --  Владимир
23.06.2008 16:49 software para vertex ...  --  electro compu....
23.06.2008 16:47 busco un software,par el radio vertex vx-2500u....  --  nathanael pined...
23.06.2008 15:16 Владимир ! "Не сливает" бывают разные. Укажите конкретно, какую п...  --  Евгений Андропо...
22.06.2008 12:28 Впервые возникла необходимость "слить" частоты с kenwood -3206 ( ...  --  Владимир
20.06.2008 01:42 hi ...  --  sdpv
19.06.2008 04:41 nececito este software...  --  ruben
16.06.2008 11:10 Alex82UK ! В некоторых партиях радиостанций TK-7108 на входе стои...  --  Евгений Андропо...
16.06.2008 06:27 xx...  --  Raymond Chia...
14.06.2008 04:31 tk3107 software for programming under winxp...  --  tk3107 software...
14.06.2008 02:17 KPG-55D software for programming for winxp...  --  kenwood tk3107...
13.06.2008 10:40 Собрал программатор уже давно. Попробовал на Icom F11, Kenwood TK...  --  Alex82UK
12.06.2008 03:04 plz i need a chemetic for programming cable for hyt tc 700...  --  fadel kanj
10.06.2008 14:56 Мне нужно описание на русском языке программы "CS F100S"...  --  БАУРЖАН
09.06.2008 18:14 cp200...  --  Seanmundus
09.06.2008 08:39 Привет всем нужна инструкция по программированию и подключение пу...  --  Мишель
07.06.2008 17:00 Need Programming software for Motorola GP340 Using code plug 6, S...  --  MarkT
06.06.2008 14:36 l...  --  fernando
04.06.2008 01:44 Ребята нужна инфа по програмированию Yaezu FTL-2001! Помогите!...  --  Виталий EV6C...
02.06.2008 18:06 Доброго времени суток Всем!!!ребята подскажите какой прогой шьеть...  --  koka62
01.06.2008 10:52 Как мне сделать сброс настроек на рациях Р-080 моторола,потомучто...  --
29.05.2008 12:32 Im interest in radio programming...  --  restu
27.05.2008 21:56 Получилось запрограмировать VXR 7000, VXR 5000. Пришлось соединит...  --  Владимир
23.05.2008 21:37 Спасибо за подсказку!!! попробую обязательно. Я понял, Что необхо...  --  Владимир
23.05.2008 14:00 Благодарю за подсказку по поводу программирования мобильной радио...  --  Калашников Серг...
23.05.2008 08:42 При программировании Волна 302 выдает "ошибка #2436, поврежден бл...  --  Алексей
19.05.2008 17:15 dd...  --  mawia
19.05.2008 17:12 ss...  --  mawia
19.05.2008 11:14 Владимир ! А ! Теперь ясно, что имелось в виду. Ретрансляторы, ра...  --  Евгений Андропо...
18.05.2008 08:43 Уважаемые кто скажет что за зверь "Рута" ...  --  олег ильин
17.05.2008 02:09 look for Information about piouts...  --  maboeh
17.05.2008 01:58 I nead sowtware...  --  Simard, Rihcard...
16.05.2008 21:34 Я пробовал на 486, который програмит 7010, 2010, TK 270, VX 160, ...  --  Владимир
16.05.2008 10:39 Владимир ! Программа для VXR-7000 критична к компьютеру - он долж...  --  Евгений Андропо...
14.05.2008 22:24 Программатор классныйю. Работает с FT 51R, VX 7R, VX 210, VX 160 ...  --  Владимир
13.05.2008 17:09 PROGRAMMING SOFTWARE CS-F3G FREE...  --  TA7MS
13.05.2008 06:41 Если нужен софт на kenwood 2260 пишите на мыло - вышлю...  --  ЕГОР
13.05.2008 06:39 Если нужен софт на kenwood 2206 пишите на мыло - вышлю...  --  ЕГОР
11.05.2008 17:56 hgfhfjj...  --
08.05.2008 18:32 SOFTWARE MOTOROLA R03.07.06 TKS...  --  charlie
08.05.2008 13:26 as...  --  as
07.05.2008 14:54 Павлу ut7gh. Полагаю, считать станцию в этом случае не удастся. О...  --  Евгений Андропо...
06.05.2008 13:11 Евгению Андропову.А если IC F110 вроде бы закрыт от считывания,ре...  --  Павел ut7gh...
06.05.2008 12:25 i need programing capl for gp328 R04.00.00-LA...  --  bg2rov
02.05.2008 00:51 NECESITO SOFTWARE GP-328 ...  --  jhonn
30.04.2008 00:15 SOFTWARE VERTEX VX 2200 TKS...  --  JRCOMUNICACIONE...
23.04.2008 15:52 При програмировании Icom Ic-F111,отключилось питание радиостанции...  --  Андрей
22.04.2008 09:57 Помогите пожалуйста, при прогромировании GM300 c помощью RADIO DO...  --  CEN
18.04.2008 11:25 Сергей Потапов ! А Вертекс вообще не ищет легких путей. Там две п...  --  Евгений Андропо...
17.04.2008 18:15 Кстати ,ктонибудь пробовал использовать программу DOSBox при прог...  --  Сергей Потапов...
17.04.2008 18:12 Программированиe VXR-7000 на P-III c WinXP ,проблема! Как решить...  --  Сергей Потапов...
17.04.2008 07:24 HOLA, NECESITI EL SOFTWARE PARA PROGRAMAR LOS RADIOS TH860H Y EL ...  --  CARLOS DAMIAN O...
14.04.2008 21:30 Please: Write to english...  --  Guillermo Suare...
14.04.2008 03:18 software programacion vertex standar vx 414...  --  vertex standar ...
09.04.2008 10:23 Кто нибудь пробавал шить "Альтавия-201", помогите хоть с распинов...  --  RA6FBT
09.04.2008 08:10 Альбина, а чем вам R03.03.00 не нравится? Просто посмотрел на на...  --  Oleg RA9JM
08.04.2008 05:48 Добрый день, коллеги.Очень мне нужна версия R03.09.05 для Motorol...  --  Альбина
04.04.2008 14:09 как прошить кенвуд тк2260...  --  александр
04.04.2008 03:09 где можно купить штекер на антену радиостанции motorola вход и вы...  --  Серега329
03.04.2008 21:39 Пжалуйста киньте Мне на мыло olegscorpion@yandex.ru софт для GM-1...  --  olegscorpion...
02.04.2008 06:17 ERGBVERAVGDFVSD...  --  ISIDRO GARCIA...
01.04.2008 10:44 Кому не ответил ? А, Alex-у вдогонку. Если преобразователь USB-CO...  --  Евгений Андропо...
01.04.2008 10:40 Slava ! Для программирования IC-F111 нужна CS-F100, а не CS-F100A...  --  Евгений Андропо...
01.04.2008 10:29 salehsamawe ! Use the published cable schematics with the MOT-4 c...  --  Yevgueny Androp...
01.04.2008 10:20 alex ! Обращаю Ваше внимание, что этот "прг" на MAX232 в принципе...  --  Евгений Андропо...
01.04.2008 10:13 Виктор UR9QV ! Вы уже сами и разобрались. Общая рекомендация по з...  --  Евгений Андропо...
01.04.2008 10:09 :DiMA ! TK-2160L - Linton ? Ну может быть... Тогда это явная подд...  --  Евгений Андропо...
31.03.2008 21:33 i need programing capl for gp328...  --  salehsamawe...
30.03.2008 23:50 Буду делать этот прг на MAX232. Очень хотелось-бы блок-схему, ...  --  alex
29.03.2008 23:58 Da li imate software KPG55D ? Pozdrav Lajos...  --  Lajos
28.03.2008 13:30 Стабилизатор LP2950-5 можно заменить на LP2951(8н.-планарка).1-2в...  --  Виктор ur9qv...
27.03.2008 02:32 I need programming software for Motorola CP200 and Motorola M1225...  --  Harrison Taylor...
26.03.2008 17:05 Как заменитьстабилизаторLP2950 на LM2951.Есть микросхема под SMD...  --  Виктор UR9Q...
26.03.2008 03:22 cp 040...  --  leman kurtdogan...
25.03.2008 21:08 cp040...  --  pisy74
25.03.2008 17:01 I need software for CP040...  --  kasum kadri...
25.03.2008 07:54 Доброго времени суток всем. Может кто поможет советом, проблема с...  --  Slava
24.03.2008 17:52 Изготовил програматор,програмирует все с чем пришлось столкнуться...  --  ur9qv виктор...
24.03.2008 17:42 Евгений Андропов ! Точно не помню уже.. но что то типа Check con...  --  :DiMA
24.03.2008 17:26 solicito software vx-2200...  --  comtodo
19.03.2008 17:00 Товарищи кто пробовал программировать радиостанци Philips FM 1000...  --  ru6fb
18.03.2008 09:50 Александр RA3NY ! Спасибо, я внесу Вас в списки. Интересно, как В...  --  Евгений Андропо...
17.03.2008 19:28 Отлично работает ,программировал GP-340,P-040 а GP-300 програмиру...  --  Александр RA3NY...
17.03.2008 11:23 :DiMA ! "Не видит совсем" бывают разные. Может появляться сообщен...  --  Евгений Андропо...
16.03.2008 16:45 cp200 PROGRAMMING SOFTWARE...  --  TOM
13.03.2008 17:24 Приобрел программатор KPG для программирования kenwood 3160L. зап...  --  :DiMA
13.03.2008 13:02 i want sofware gp328...  --  benni
12.03.2008 11:09 jlsgcjhc kjashckjsah jk kjsah kjsa...  --  fouad
06.03.2008 02:39 software for Icom F3s...  --  daryl
29.02.2008 22:59 Looking for software for a motorola cp200 has to be newer, please...  --  shawn
28.02.2008 10:29 Александру по KPG-91D. Вот, посмотрите сюда: (ВВВ).30et-054.es/pa...  --  Евгений Андропо...
22.02.2008 09:30 Сергей ! Схему именно штатного программатора VPL-1 найти не помог...  --  Евгений Андропо...
22.02.2008 08:06 Please help me find CPS R05.06.00 for my CP200 radio....  --  Patty Love
21.02.2008 13:43 Помогите пожалуста программой для прошивки MOTOROLA CM-140 Зар...  --  Владимир UA1ON...
21.02.2008 09:35 помогите найти схему программатора VPL-1...  --  сергей
20.02.2008 21:47 Witam. Poszukuje softu do radiotelefonu Kenwood TK-809E UKF....  --  m_a_r_e_k1
20.02.2008 14:00 если есть у кого нибудь софт kpg-74d на kenwood 3140,поделитесь п...  --  алексей rv3dgs...
19.02.2008 17:17 i need the squematic wire programation sorry my english is bad ...  --  gabo
18.02.2008 16:18 Уважаемая радиолюбительская общественность!!!Если не жалко, подел...  --  Александр
18.02.2008 15:01 Большое спасибо, Евгений. Воспользуюсь вашим советом...  --  Сергей Калашник...
18.02.2008 08:22 Всем привет! Помогите, нужен soft на СМ140, сбросте ссылку на r.a...  --  Александр
17.02.2008 14:24 Can anybody help with interface for Bantam MX/PX? Email bel1@webm...  --  QD Bantam MX...
17.02.2008 14:11 подскажите кто знает распайку разъема подключения внешних устроцй...  --  Валера
15.02.2008 12:17 Сергей Калашников ! А схема переходника "KENWOOD мобильные" Вас н...  --  Евгений Андропо...
15.02.2008 12:01 Пожалуйста скиньте схему радиостанции Icom ic-f110....  --  Сергей Люлюков...
14.02.2008 20:29 Hi, i need the software for cm140. tanks petre...  --  romania
14.02.2008 12:51 Пожалуйста скинте распиновку разъема от программатора KPG-22. И б...  --  Сергей Калашник...
11.02.2008 14:31 Привет всем, кинте софт для MOTOROLA CP-180 (R03.01.00), GM-340 (...  --  Gevor
11.02.2008 08:16 Пожалуйста пришлите распиновку разъема от программатора KPG-22 на...  --  Сергей Калашник...
07.02.2008 16:58 xxxxx...  --
07.02.2008 16:01 Уважаемая радиолюбительская общественность!!!Если не жалко, подел...  --  АЛЕКСАНДР
07.02.2008 15:43 Уважаемый Анатолий большое спасибо за ответ по KENWOOD TKR-750VFM...  --  АЛЕКСАНДР
07.02.2008 13:39 Александру по KENWOOD TKR-750VFM. По всей видимости ретранслятор ...  --  Евгений Андропо...
06.02.2008 16:03 need gp 328 service manual urgently...  --  rio
06.02.2008 11:23 need gp 328 service manual urgently.please help.e-mail ahamadbokh...  --  Ahamad bokhari...
05.02.2008 19:57 need gp328 service manual urgently...  --  Ahamad bokhari...
05.02.2008 19:03 very need for KPG 99 D(E) for TK 8162 e .please help .zoheir-pion...  --  zoheir
31.01.2008 12:56 I am looking for gp328 service manual.please send me to the above...  --  AHAMAD BOKHARI...
31.01.2008 10:43 rw0jc ! 1. Поименуйте все проверенные станции и представьтесь как...  --  Евгений Андропо...
30.01.2008 22:43 software for vertex vx 2200...  --
30.01.2008 17:22 software for vertex vx 2200...  --  ariel casteglio...
30.01.2008 14:38 Здравствуйте Евгений, большущее спасибо за ответ. Мой программат...  --  rw0jc
30.01.2008 09:38 rw0jc ! 1. 2,5 мм моно. 2. Для DR-130 требуется программатор на L...  --  Евгений Андропо...
29.01.2008 15:29 Доброго времени суток всем. Надеюсь кто подскажет как запрограмм...  --  rw0jc
29.01.2008 15:27 rw0jc...  --  rw0jc
29.01.2008 14:56 iojj;...  --
29.01.2008 07:29 Доброго времени суток всем. Надеюсь кто подскажет как запрограмм...  --  rw0jc
26.01.2008 17:19 sh...  --  ddg
25.01.2008 14:39 i have the kenwood tk 7160 does anyone know where to find the sof...  --  please help...
24.01.2008 19:16 need kpg 99d(e)(zoheir-pionner@hotmail.fr)...  --  zoheir
24.01.2008 17:31 Уважаемый Евгений!Помогите пожалуйстам с программированием ретран...  --
24.01.2008 17:28 Уважаемый Евгений!Помогите пожалуйстам с программированием ретран...  --
22.01.2008 19:53 i am hari from india i need icom m502 diagram programmingcable ...  --  hari
22.01.2008 17:14 Помогите, будьте любезны, с программированием МOTOROLA CM140...  --  Vova
22.01.2008 14:44 por favor...  --  josema122
20.01.2008 22:22 Hello, I am Henry and I need Motorola RSS software for the GM300 ...  --  Henry
17.01.2008 22:38 Парни подскажите чем шить р/с SoonTone. Пожалуйста....  --  Slash
16.01.2008 00:45 Помогите пожалуйста с программным обеспечением для Motorola GP360...  --  Bass
16.01.2008 00:22 nowy...  --  kalemo
15.01.2008 17:10 Может кто поможет мне с распиновкой разъема радиостанций SARACOM,...  --  sprut
14.01.2008 11:56 SeregaDV Вам уже дали прогу для Моторола СР140? если нет, то пиши...  --  Александр
10.01.2008 18:06 как можно настроить Motorola P 020 на другую частоту...  --
04.01.2008 05:20 Помогите пожадуста с программным обеспечением для Motorola CP140...  --  SeregaDV
20.12.2007 20:24 DIAGRAM CABLE PROGRA MMING CM 140 PLEASE SEND ME!...  --
17.12.2007 00:11 вместо с1969 .который стоит около 60 грн отлино идет кт909б.это т...  --  макс
16.12.2007 23:22 нужен софт для драгон су5430...  --  макс
13.12.2007 15:55 Вдогонку. Возможен подвох в программировании некоторых радиостанц...  --  Евгений Андропо...
13.12.2007 15:37 Andrey ! Возьмите программу F3/F4 New с СКП, запускайте файл CSF3...  --  Евгений Андропо...
12.12.2007 19:46 Евгений! Радиостанция IC-F3S это точно, прогу запускал из DOSа и ...  --
12.12.2007 07:02 Здравствуйте! Помогите с софтом для программирования HYT TC700 в...  --  Дима
06.12.2007 09:52 Andrey ! Пропустили-пропустили. Адрес приведен в нижней части пер...  --  Евгений Андропо...
05.12.2007 22:43 Здравствуйте Евгений! Может я что и пропустил, но у меня нет Ваш...  --  Andrey
05.12.2007 09:35 Александр RX6HT ! Вижу две проблемы. Первая: для GM300 Вы примени...  --  Евгений Андропо...
04.12.2007 16:52 Пробовал ли кто шить motorola mp-300, подскажите пожалуйсто чем ш...  --  Пролан
04.12.2007 15:16 Собрал программатор по схеме и программировал P-080 (R.02.02), CM...  --  Александр RX6HT...
04.12.2007 09:35 Andrey ! Как уже неоднократно отмечалось, DOS-программы, работающ...  --  Евгений Андропо...
30.11.2007 15:30 Спасибо Евгений! Всё заработало! но из под Windows XP программа...  --  Andrey
30.11.2007 09:29 Andrey ! Большое количество программ имеется на этом же сервере: ...  --  Евгений Андропо...
30.11.2007 09:25 Евгений UR5LIS ! Большое спасибо за проверку и душевные слова. Я ...  --  Евгений Андропо...
30.11.2007 09:22 hey does anybody have the motorola software for maratrac saber ...  --  troy
29.11.2007 12:18 Здравствуйте! Собрал программатор, собирался забить новые частот...  --  Andrey
29.11.2007 09:38 Помогите с Альтавией 201...  --  RA6FBT
28.11.2007 12:23 Собрал программатор. Работает отлично. Проверил с радиостанциями ...  --  Евгений UR5LIS...
28.11.2007 11:44 всем привет нужна распайка задней панели моторолы gm1200e databox...  --
27.11.2007 21:19 program ce 20 vertex vx 2000...  --  steve britos...
21.11.2007 23:43 Hello I can send you the software R05.05.00 Motorola pepino...  --  pepino81fr
20.11.2007 15:32 Всем доброго здоровья! алинка 180 ,пробил блок питания, вместо пи...  --  vitaly UR4UBQ...
17.11.2007 08:50 Доброе время суток всем. Помогите советом как включить шумодав в ...  --  rw0jc
14.11.2007 10:23 Hi! Looking for R05.05.00 Motorola software for programming my CP...  --  Martin
09.11.2007 16:52 Hi everbody.I-m Ozgur from Turkey.I-m looking for MOTOROLA CP 140...  --  Ozgur
08.11.2007 09:02 Hi, anybody have RSS KPG 101D...  --  knight
07.11.2007 14:17 Пробовал ли кто шить "Альтавия 201", подскажите пожалуйсто чем ши...  --  RA6FBT
04.11.2007 14:30 Hello i need The KPG-28D Kenwood software for my tk 859 .if anyon...  --  Hugo
30.10.2007 17:22 ПРОГРАММАТОР МОТОРОЛЬСКИЙ GP GM 300 ICOM KENWOOD ПРОДАМ 890377...  --  уч3эюя
30.10.2007 09:10 kako se programira motorola gp 1200 radius,koji kablovi interface...  --  yt1kbc
29.10.2007 12:00 Привет всем, кинте софт для motorola cp180, cp140 (R05.00, R05.0...  --  Alexandr
26.10.2007 11:30 HELLO, I AM FRANCISCO, I´M RESCUE FOR PROTECCION CIVIL, FROM...  --  francisco espin...
26.10.2007 11:22 PLIZ hola, agradeceria si me pasaran el software de programaci...  --  FRANCISCO
26.10.2007 02:02 I-m looking for the software for the Motorola P020 if any one can...  --  motorola p 020...
23.10.2007 16:04 ребята, подскажите где схемы для радиостанция HYT !!!!!!...  --  igor
18.10.2007 15:12 ребята подскажите как запрограмировать gp-68? Какой програмкой? ...  --  ut5emu
10.10.2007 09:54 Константин ! Экая у Вас душа шумная... Сюда заглядывали: radiosca...  --  Евгений Андропо...
10.10.2007 04:20 Нужен программатор на радиостанцию Радий-301, GP340 (схему и про...  --
09.10.2007 15:35 Мужики! Крик души! Помогите, где можно скачать софт для программи...  --  Константин
04.10.2007 14:58 Hello i m mario... i m radio amator my name it (yo3hma) from euro...  --  Mario
04.10.2007 14:57 Hello i m mario... i m radio amator my name it (yo3hma) from euro...  --  Mario
04.10.2007 11:46 Народ нет ли у кого программы adj для Icom IC-F3...  --
03.10.2007 23:31 Plyyzzzz Send me email the soft kit Motorola R03.07.06 :-((((...  --  Mario
02.10.2007 17:54 vertex ftl 2011...  --  Jaime Vilches R...
02.10.2007 13:56 Ни как не могу найти принципиальную схему на Icom IC-F320S, кто з...  --  Oleg_D
29.09.2007 19:05 Hello plyzzz give me the Kit Motorola Gm360 Version R03.07.06 in ...  --  Mario
27.09.2007 05:17 Софт для WERTEX 2000 есть,могу поделиться. Проверял, работает. А...  --  Johnson, UR5FFM...
25.09.2007 01:08 где можно скачать программу для программирования р./ст. VERTEX 20...  --  Александр
18.09.2007 07:03 ROBINZON24 Спасибо!...  --  Александр-Уфа...
17.09.2007 15:44 Александр-Уфа не неиспортить я ней уже штук 30 прошил с разными ...  --  ROBINZON24
17.09.2007 11:53 ROBINZON24 Пошла прошивка, но не через хр, а через 98. А есть про...  --  Александр-Уфа...
15.09.2007 23:41 necesito el programador de las radios ´´kenwood thk2at`...  --  polo
15.09.2007 16:42 programming software kenwood thk2at...  --  polo
14.09.2007 19:38 Александр-Уфа Шей ее kpg56d я тоже мучился в свое время немог про...  --  ROBINZON24
12.09.2007 14:52 Да, забыл написать... На др. компьютере ошибки нет, происходит по...  --  Александр-Уфа...
12.09.2007 14:47 Здравствуйте! Скачал (по-моему, с этого сайта) программу для прош...  --  Александр-Уфа...
11.09.2007 09:23 romich ! Вы штурмуете открытую дверь. Подключение программатора (...  --  Евгений Андропо...
11.09.2007 09:20 ROBINZON24 ! Мною был прошит не один десяток TK-7102 именно в так...  --  Евгений Андропо...
10.09.2007 09:55 у кого нибудь есть софт для Р-040, и расшивка кабеля, .если есть...  --  romich
08.09.2007 19:27 Не мог прошить KENWOOD TK-7020 KENWOOD TK-7102 иKENWOOD TK-7108 ...  --  ROBINZON24
03.09.2007 11:17 ICOM 420 F, при наборе номера выдает короткие гудки... как сброси...  --
01.09.2007 16:03 Please i need schematic Motorola p040...  --  winston
31.08.2007 23:35 Приветствую. У кого нибудь есть софт для перепрошивки "Волны 30...  --  Veritas
30.08.2007 06:23 I, HAVE CALLME...  --  EDGAR MARTIN...
29.08.2007 09:39 Федор ! Действительно, в последние годы стали появляться странные...  --  Евгений Андропо...
29.08.2007 06:15 Ну, значит партия транзисторов такая попалась... Софт от GM-300/G...  --  Федор
28.08.2007 16:58 Федор ! Коэффициент передачи тока критичен только для транзисторо...  --  Евгений Андропо...
28.08.2007 06:30 Собрал программатор. Работать он захотел только с транзисторами с...  --  Федор
27.08.2007 10:36 Нужен софт на Motorola GM-360 ver.03.07.06 старая версия не подхо...  --  Руслан!
26.08.2007 18:30 кто подскажет аналог транзистора m25c22 к радиостоанции моторола ...  --  Чунин Геннадий...
25.08.2007 14:20 как настроить радиостанцию motorola M120?...  --  Андрей
22.08.2007 03:51 ...  --
21.08.2007 10:15 Олег ! С Вашим замечанием по поводу нумерации в разъемах RJ-45 я ...  --  Евгений Андропо...
20.08.2007 17:29 Здравствуте Всем! Нужен софт CE63 для VX2500. Заранее спасибо!7...  --  Сергей,rv3na...
20.08.2007 10:48 И сам стандарт - ввв.pccitizen.com/RJ45.htm...  --  Олег
20.08.2007 10:32 Вот здесь правильно - ввв.cqham.ru/images/motprogram.gif...  --  Олег
20.08.2007 10:23 Евгений ! Исправьте, пожалуйста, нумерацию в разъемах RJ-45, в сх...  --  Олег
17.08.2007 10:23 Alex ! Основные направления копания изложены в конце статьи. В Ва...  --  Евгений Андропо...
16.08.2007 18:54 Имеются новенькие TKR-2206, при включении пищат и красный светоди...  --  Alex
16.08.2007 05:08 Помогите пожалуйста найти софт для программирования VERTEX VX-220...  --  Капитан
09.08.2007 14:07 Олег ! ТК-868Н программируется KPG-29D. На сайте выложен рабочий ...  --  Евгений Андропо...
09.08.2007 13:50 Подскажите плз, кто-нибудь перепрограмировал FTL-2001. Спасибо з...  --  Виталий
09.08.2007 02:33 Уважаемые коллеги подскажите по программированию ТК868Н,выдает вс...  --  Олег ru6fb
08.08.2007 09:39 Кто нить скиньте r05.05 для cp040, горит, очень надо.Заранее благ...  --  Олег
08.08.2007 04:43 programar 3212 por fa...  --  rucho
03.08.2007 12:08 Валерий ! 1. С предложением дополнить схему программатора ключом ...  --  Евгений Андропо...
02.08.2007 03:15 icom sc-f100...  --  dewara
01.08.2007 16:59 Дополнение к сообщению 22 июня 2007г. Евгений! Есть предложение н...  --
30.07.2007 16:50 Саша ! Аж два моих адреса приведены в статье. Воспользуйтесь тем,...  --  Евгений Андропо...
30.07.2007 16:30 Евгений Андропов Дайте сылочьку на вашу почьту...  --  саша
30.07.2007 10:22 Евгений ! У старых радиостанций разъемы типа RJ часто окисляются ...  --  Евгений Андропо...
30.07.2007 10:10 Есть софт для моторол ср-180(волна-201) и gm-340(волна-302) верси...  --  Andrey_k
30.07.2007 04:28 Евгений, все к счастью разрешилось. Оказалось у р/ст был неисправ...  --  Евгений
27.07.2007 18:40 Здравствуйте Евгений. Собрал Ваш программатор и попробовал испыта...  --  Евгений
26.07.2007 20:55 нужен софт для motorola GM-360,версия R03.07.06 Мыло ua3ieo@yande...  --  vladimir
26.07.2007 08:59 Интересно , Эрика 201 как запрограммировать ?? можно ли ......  --  Gen RX6LDB
25.07.2007 12:19 нужна инструкция по пользованию рацией motorola radius gp300.Помо...  --  олег
23.07.2007 11:54 I need soft CPS R05.05.00. for motorola cm340 station. Sand me on...  --  Vesko, YU1IV...
23.07.2007 11:49 I need soft CPS R05.05.05.00 for motorola cm340 station. Send me ...  --  Vesko, YU1IV...
23.07.2007 09:29 Валерий ! Да, странная штука получилась у Вас с проводами. У меня...  --  Евгений Андропо...
22.07.2007 21:17 KENWOOD TH-F2AT После полного сброса(при нажатой F+ вкл. питания)...  --  Виктор
22.07.2007 00:18 Как и предполагалась, проблема была в кабеле. Сейчас он переделан...  --
21.07.2007 19:37 pasworrd please...  --  mustafa
21.07.2007 18:48 Валерий.А в чем была проблемка мож раскажете всем интересно ...  --  саша
20.07.2007 22:26 Евгений! Проблема решена, все программаторы работают. Спасибо за...  --
20.07.2007 12:02 Евгений! Напряжение я указал, оно с допуском 5% составляет +5В. Н...  --
20.07.2007 11:27 Валерий ! По сообщению от 20 июля. Как я понял, программаторы пос...  --  Евгений Андропо...
20.07.2007 00:57 Евгений! Все программаторы запитаны от сети, стоит трансформатор,...  --
19.07.2007 23:54 Помогите пожалуйста... Срочно нужна программа для работы с радио...  --  Аретем
19.07.2007 09:55 Валерий ! По сообщениям от 17 и 18 июля. Современные носимые стан...  --  Евгений Андропо...
18.07.2007 10:31 Дополнительно к сообщению от 17 июля. Целый вечер проверялись 3 п...  --
17.07.2007 14:09 Вопрос. Плохо программируется носимые KENWOOD, через раз. С други...  --
15.07.2007 09:24 NECESITO EL KPG87D PARA EL MODELO 2202L...  --  LUIS SILVA RIVE...
09.07.2007 18:39 Евгений Андропов ПРОГРАММАТОР РАБОТАЕТ ХОРОШО ПРОШИЛ-IC-F310s I...  --  саша
07.07.2007 17:42 нехочет програмится x-160 софт с сайта под досом подскажите что м...  --  владимир
07.07.2007 15:44 RU-210 ELECTRA программирование.Кто встречял такое чюдо- юдо подс...  --  саша
07.07.2007 10:58 CLAVE DE INTALACION DEL PROGRAMA KPG100D...  --  LUIS DUARTE...
07.07.2007 10:02 boa скинь на мыло R05.05.00. мыло UN7IAX@RAMBLER.RU...  --  un7iax
05.07.2007 19:14 boa скинь на мыло софт R05.05.00 для Motorola CР и СМ пардон мыло...  --  николай(кока62...
05.07.2007 19:12 boa скинь на мыло софт R05.05.00 для Motorola CР и СМ 73...  --  николай(кока62)...
05.07.2007 11:42 Сейчас с ТК-2107 проблемы: с родным и с унипрог не доходит до кон...  --  Akuts
04.07.2007 16:10 Akuts я 320 тоже немог долго прошить были глюки она очень каприз...  --  саша
04.07.2007 16:07 MOTOROLA Radius GM1200 программирование.Попала радейка Radius GM1...  --  саша
04.07.2007 15:38 Помогите, пожалуйста... Кто знает откуда можно скачать программу ...  --  Aleksandr
04.07.2007 14:36 Спасибо! Помогли Ваши переписки, проблема решилась. Скачал новый ...  --
04.07.2007 13:54 Помогите, пожалуйста... Р/ст IC-F310s стала откликаться на запрос...  --  Akuts
02.07.2007 13:19 Есть софт для GM-140 ver R04.00.00 R06.01.00 Мыло ua3ieo@yandex....  --  Владимир
02.07.2007 13:08 Помогите ,нужен софт для motorola GM-640,версия R02.03.00 Мыло ...  --  Владимир
29.06.2007 13:36 программатор супер !!!шьет хорошо, ребята скиньте ссылочку на соф...  --  николай(кока62)...
29.06.2007 11:40 Полезный пример... Я закачал на рапиду программу для GP-340 ver.R...  --  alex286
29.06.2007 11:05 boa весит слишком много - 8,22 Мб...ограничение до 2 Мб. Смогу то...  --  alex286
28.06.2007 23:57 motorola cp 040...  --  yo7
28.06.2007 18:59 Евгений Андропов я на нем шил и читал IC-F310S и ТК-760G-1 врод...  --  саша
28.06.2007 15:14 Саша ! Если у Вас читалась IC-F310S, то должна и FTL-2011 читатьс...  --  Евгений Андропо...
28.06.2007 11:37 un7iax и alex286 !!! Софт R05.05.00 для Motorola CР и СМ Выложит...  --  boa
27.06.2007 17:53 Евгений Андропов я разобрался детально и переходник вроде спаял ...  --  саша
27.06.2007 10:17 Саша ! В справке на софт для FTL-2011, насколько я помню, детальн...  --  Евгений Андропо...
27.06.2007 10:15 Alex82 ! Поздравляю с успехом. Представьтесь как-нибудь мне на по...  --  Евгений Андропо...
26.06.2007 16:36 un7iax и alex286 Попробую выложить на форуме......  --  boa
26.06.2007 16:20 alex286 Если было бы куда выложить... Могу ток на мыло... :(...  --  boa
26.06.2007 10:57 Большое спасибо за схему. Это была моя первая собственноручно соб...  --  Alex82
25.06.2007 16:15 ru6fb ДА я понял я нажимаю F5 пробел (клавишу) А на рации загор...  --  саша
24.06.2007 00:11 Саша обрати внемание F5 пробел (клавишу) А и опять пробел вот так...  --  ru6fb
23.06.2007 15:56 boa зайди на Радиолюбительские форумы на сервер кубанских радиол...  --  САША
23.06.2007 15:36 boa Слушай, если не трудно положи куда-нибудь версию R05.05.00, ...  --  alex286
23.06.2007 14:05 ru6fb Я набиваю данные в программе какие нада мне чястоты и за...  --  САША
22.06.2007 10:11 un7iax У меня есть прога версии R05.05.00 " the Motorola Comme...  --  boa
22.06.2007 07:32 Извеняюсь за повтор Уважаемые коллеги и люди добрые помогите с ...  --  igi
22.06.2007 07:30 Уважаемые коллеги и люди добрые помогите с софтом на GM360 она же...  --  igi
21.06.2007 20:06 Саша после подключения FTL запускаете программу зате жмёте F5 про...  --  ru6fb
21.06.2007 19:48 Саша нажми кнопку и попробуй её немного удержать. Я найду записи...  --  ru6fb
21.06.2007 19:38 Саша FTL-2011 шётся отлично пишет значит жмите кнопку А на FTL ....  --  ru6fb
21.06.2007 19:34 Александр большое спасибо за оказанную помощ. Всё запрограммиро...  --  ru6fb
21.06.2007 11:14 VERTEX FTL-2011Программатор универсальный шнурок YAESUVERTEX моби...  --  САША
20.06.2007 22:48 Уважаемые колеги и люди добрые помогите с софтом на GM660 онаже р...  --  ru6fb
20.06.2007 22:46 Уважаемые колеги и люди добрые помогите с софтом на GM660 онаже р...  --  ru6fb
20.06.2007 16:56 Подскажите, кто знает, как запрограмировать и вообще переключить ...  --  Артур
20.06.2007 05:47 hello. I need kpg-87d v2.xx please send to as01283@tiscali.co.u...  --  radiomad
19.06.2007 14:28 САША ! Поздравляю с очередным успехом ! Давайте мне список провер...  --  Евгений Андропо...
19.06.2007 11:50 Евгений Андропов Все заработало просто ненада было распаковывать...  --  САША
19.06.2007 11:05 САША ! По ICOM IC-F310S посмотрите сообщения на этой же странице ...  --  Евгений Андропо...
18.06.2007 21:38 Евгений Андропов ICOM IC-F310S а с етим зверем что делать мож п...  --  САША
18.06.2007 20:48 Евгений Андропов да так и было через режим Program / Test mode ...  --  САША
18.06.2007 19:53 ICOM IC-F310S программатор универсальный спаял шнур по верхнему...  --  САША
18.06.2007 09:48 mikola ! Поздравляю с успехом. Как говорится, если что-то никак н...  --  Евгений Андропо...
18.06.2007 09:39 САША ! Поздравляю с успехом ! Действительно, в последнее годы ста...  --  Евгений Андропо...
16.06.2007 17:56 Всем спасибо заработал программатор попался транзистор кт 3107 с ...  --  САША
16.06.2007 17:54 Собрал программатор универсальный подключил ТК-760G-1 Кенвуд Софт...  --  САША
16.06.2007 12:56 Точно все заработало, вмимательно не прочитал про емкость по пита...  --  mikola
15.06.2007 16:23 Собрал программатор универсальный подключил ТК-760G-1 Кенвуд С...  --  САША
14.06.2007 10:08 alex286 ! Проверьте для начала напряжение питания на выходе стаби...  --  Евгений Андропо...
14.06.2007 00:50 Hi, can somebody please email CP040 software to me. bel1@webmai...  --  bell
13.06.2007 20:23 Все собрано правильно,проверено и перепроверено неоднократно, пит...  --  alex286
13.06.2007 12:30 mikolasnn ! Прямо чудеса: FTH-2008 читается, а DJ-191 - нет. Цепи...  --  Евгений Андропо...
13.06.2007 12:06 Собрал программатор.Работаю из под дос.Помню месяц назад прошивал...  --  mikolasnn
13.06.2007 11:25 Ивлев Андрей ! Насколько я понимаю, ТК-7760 - это Кенвуд киевско...  --  Евгений Андропо...
13.06.2007 11:20 Alex286 ! Скорость порта тут, очевидно, ни при чем. Посмотрите сп...  --  Евгений Андропо...
13.06.2007 10:24 Нужен софт CE59 для программирования Vertex VX4204, либо другие...  --  Александр
12.06.2007 20:35 Кто поможет найти прогу для ТК-7760-1? Буду очень признателен....  --  Ивлев Андрей...
11.06.2007 18:07 Извините не представился...Александр. Дополнительно: Версия станц...  --  Alex286
11.06.2007 17:54 Скажите, а скорость порта влияет на работу универсального програм...  --
10.06.2007 21:48 чтобы KPG тебе посылает 87D этот, он я тот говорю наперебой{говор...  --  software kpg...
10.06.2007 21:36 as I make to send you the software CP040 my I chant it is ieren...  --  ok cp040
10.06.2007 18:15 Hi, has anybody got software for CP040?...  --  bell
10.06.2007 09:49 ok I send you the software GM1200 escriveme ami I chant ierendero...  --  software GM120...
10.06.2007 09:44 nesecito the software CT250 verssion AA and the XTS3000 my I ...  --  software CT250 ...
10.06.2007 09:38 I have the software cm100R02_04 that is for the cm140 and I can s...  --  Enrique Rendero...
10.06.2007 09:22 software...  --  Enrique Rendero...
05.06.2007 12:25 i need softwaer and programming for TK-2160 kenwood...  --  abdool ganee...
05.06.2007 05:52 i need software kpg87d v 2.?? for radius tk2202L ...  --  cb1sqp
04.06.2007 12:48 Максим ! Проверьте целостность проводов и правильность монтажа, в...  --  Евгений Андропо...
03.06.2007 17:59 Уважаемые знатоки, ответьте, пожалуйста, на вопрос: почему не зап...  --  Зоркальцев Макс...
01.06.2007 09:44 sergeiwm ! Далеко не надо ходить, на СКР все есть на странице "Сх...  --  Евгений Андропо...
01.06.2007 09:22 Neko ! Если есть вторая в точности такая же исправная станция, то...  --  Евгений Андропо...
31.05.2007 15:27 Добрый день! Есть ICOM IC-F3GT на 40 каналов, в который по кос...  --  Neko
30.05.2007 11:48 Помогите, кто программировал ROGER KM-1518? Нужна схема программа...  --  sergeiwm
29.05.2007 10:13 Титан ТН-102, - видимо, не то же самое, что РН-102. Чей это клон ...  --  Евгений Андропо...
27.05.2007 10:17 Добрый день! Помогите разобраться. Есть станция Титан тн-102, соб...  --
24.05.2007 09:06 Есть станция версия 146-174,есть софт и програматор НО программа ...  --  Андрей
24.05.2007 07:23 Здраствуйте!! ))) Если вы нашли схему Motorola CM140, поделитесь...  --  Metel
21.05.2007 14:53 Looking for programming software for MOTOROLA CM140 . ver. R05...  --  SGK
20.05.2007 20:24 VX500...  --  VX500
18.05.2007 16:38 Помогите! Нужно скачать софт KPG-99D...  --  Cергей
08.05.2007 11:53 motorola gp688 program software ...  --  bytaki
05.05.2007 21:15 need software to program Moto GM1200 ex-trunking mobile radio ......  --  steff
30.04.2007 20:09 ua1onw софт се20 рабочий но действительно глючит. Нужно после рас...  --  rv3sbq
30.04.2007 19:19 Мирослав если проблема ещё актуальна пиши на мыло дам софтину А в...  --  rv3sbq
29.04.2007 21:30 KPG-99D E ...  --
29.04.2007 13:18 asdsfdfd...  --  fdfdgds
28.04.2007 06:33 KPG-99D E...  --
24.04.2007 18:39 Помогите ,нужен софт для motorola GM140 Мыло ua3ieo@yandex.ru...  --  владимир ua3ieo...
24.04.2007 08:26 Подскажите,плз,где найти простую и надёжную схему интерфейса для ...  --  АлексейП
21.04.2007 11:50 Bладимир нaпиши мыло помогу ...  --  PAMAH
21.04.2007 08:27 Помогите ,нужен софт для motorola GM140...  --  владимир UA3IEO...
21.04.2007 06:17 Помогите запрограмировать ICOM F-110S. Где достать софт? Надо оч...  --  Михаил
19.04.2007 09:45 petrovich069 ! Вы как-то мрачно шутите... COM-порт сам по себе пр...  --  Евгений Андропо...
19.04.2007 09:43 Phantomas ! Поспрашивайте софт в форуме, у народа вроде бы был......  --  Евгений Андропо...
18.04.2007 19:48 Срочно нужна электрическая схема шнура COM -порт----RS232.Уже бит...  --  petrovich069...
18.04.2007 14:35 Привет! Собрал программатор не могу найти софт для прошивки P020...  --  Phantomas
17.04.2007 13:17 Евгений, большое спасибо за оказанное внимание и помощь! Попробую...  --  nik
17.04.2007 09:28 nik ! Надпись, видимо, CLONE NG или CL NG. По поводу IC-F310 см. ...  --  Евгений Андропо...
16.04.2007 12:09 hi as anyone got cm140 software mine as been lost due to house mo...  --  ste
16.04.2007 10:00 Появилась проблема! На радиостанциях марки Icom F310, F111 на инд...  --  nik
16.04.2007 03:17 АлексейП - моё мыло alexpr69@rambler.ru...  --  АлексейП
14.04.2007 21:26 Извеняюсь за повтор. Кому не жаль подсобите софтом на CM-160. (R0...  --  UN7QAT
14.04.2007 18:04 kpg-60d...  --  Raul Ortega...
14.04.2007 01:22 Где найти программатор для радиостанции Гранит Р-33П ...  --  Техник09
13.04.2007 13:31 То АлексейП В мыло пиши...  --  un7qat
13.04.2007 10:29 Рс Soontone ST-3208 136-174MHz -кто знает,чей клон?(возможно TK-2...  --  АлексейП
13.04.2007 10:23 Помогите,плз,новичку! Где скачать программу KPG-55D ?????...  --  АлексейП
13.04.2007 10:05 Что-то тишина, попробуй на rovers###mail.kz...  --  UN7QAT
13.04.2007 00:15 UN7QAT@mail.ru...  --  UN7QAT
13.04.2007 00:04 Пожалуиста. Куда?...  --  РАМАН ly4mr...
12.04.2007 23:02 Hi All. Нужно перешить рст. Motor CM-160, кому не жаль подсобите ...  --  UN7QAT
11.04.2007 13:00 Кто программировал ROGER KM-1518. Подходит ли программатор? Какой...  --  Сергей
10.04.2007 22:30 PROGRAMMING SOFTWARE CS-F3G FREE...  --
08.04.2007 23:33 HOLA, PLS PROGRAMMING SOFTWARE AND SERVICE MANUAL FOR IC-F121S, ...  --  MARCO WATANABE...
08.04.2007 20:09 Может кто подскажет где взять csf100 ver 1.7 ???...  --  Мирослав
08.04.2007 20:08 Спасибо за отклик rv3sbg. Ходил на www.icom.co.jp - там csf100 ve...  --  Мирослав
07.04.2007 22:56 IC-111 разобрался просто нужен софт csf100 ver 1.7. Только провер...  --  rv3sbq
07.04.2007 22:09 IC-111 та же проблемма в конце пишет типа Please update tu the la...  --  rv3sbq
07.04.2007 09:22 Помогите найти нормальный рабочий Soft для YAESU VX-2000V( soft C...  --  ua1onw
07.04.2007 02:43 Купил программатор для IC-110 и IC-111. IC-110 пишет и читает без...  --  Мирослав
06.04.2007 21:36 Какой программой программируется MOTOROLA CP-140 ver.no:r03.00.0...  --  un7iax
03.04.2007 19:20 Dobrogo vremenji sutok! Vertex standart VXA 300 (aviacionnij di...  --  oktava
03.04.2007 00:27 кенвуд tk-250 и 250(e) должен работать на 2м. работает как tk-35...  --
01.04.2007 23:44 Подскажите пожалуйста как мне снять запрет на программирование в ...  --  Антон
31.03.2007 17:42 Sergey. Cхема кабеля для программирования icom-f50,который OPC...  --  doncamp
31.03.2007 17:29 У RA9MHL получилось прошить Моторолу Р020 шнурком от Р040.Каким с...  --  doncamp
31.03.2007 12:37 Есть ли у кого опыт и соответствующее программное обеспечение по ...  --  Дмитрий
26.03.2007 13:00 Динь спасибо! Вот это она и просит при попытке считать, но реакц...  --  пролан
26.03.2007 11:57 Подключаешь шнурок к радиостанции в софте говоришь, считать. (Ста...  --  Динь
23.03.2007 15:52 Как перевести в режим прграммирования VX-3200?...  --  пролан
23.03.2007 09:54 Я приветствую всех! Друзья что можно услышать о моторе LCS2000 а...  --  UA1AAM Владим...
21.03.2007 01:44 Помогите схемой кабеля для программирования icom-f50 и т.д. Назы...  --  Sergey
20.03.2007 16:14 помогите найти программу для радиостанции KENWOOD TK-7108...  --  Тима
17.03.2007 04:37 KPG ...  --
16.03.2007 21:51 помогите настроить моторолу GP340 на рацию DRAGON или ALAN возмож...  --  анатолий
15.03.2007 17:06 KPG-90D...  --
14.03.2007 09:26 Сергей RA9AMJ ! Давайте список проверенных станций, я опубликую....  --  Евгений Андропо...
13.03.2007 11:29 Спасибо, Евгений!!! Теперь нет ни каких сомнений! Программатр со...  --  Сергей, RA9AMJ...
12.03.2007 09:55 Сергей RA9AMJ ! Номиналы емкостей указаны с помощью стандартных о...  --  Евгений Андропо...
12.03.2007 09:41 Евгений!!! В схеме универсального программатора какого номинала е...  --  Сергей, RA9AMJ...
05.03.2007 09:59 помогите найти программу для прогромирования авто рации....  --  игорян
03.03.2007 16:50 Помогите ПЛИZZZZ нужен софт motorola GM1200E jn gm1200 не подход...  --  UN7ECY Vlad...
28.02.2007 10:19 Сергей К. RA9AMJ ! Приспособить RIB к Kenwood не удастся: в RIB т...  --  Евгений Андропо...
27.02.2007 12:46 Уважаемые коллеги!!! Кто-нибудь пробовал приспособить для програм...  --  Сергей К. RA9AM...
20.02.2007 02:28 где найти схему на алинку др 130 лш ?...  --  алекс
20.02.2007 02:27 где найти схему на алинку др 130 лш ?...  --  алекс
20.02.2007 02:21 где найти схему на алинку др 130 лш ?...  --  алекс
20.02.2007 02:19 где найти схему на алинку др 130 лш ?...  --  алекс
18.02.2007 17:42 Söker efter hur man programerar en Shinwa SC425YB...  --  Dan
15.02.2007 08:24 Помогите найти мануал на GM-340.Если у кого то есть пришлите PLIZ...  --  Владимир
30.01.2007 15:57 Программатор работает - супер! програмировал моторолы серии GM, к...  --  prepod
25.01.2007 11:14 kpg87d...  --  siamak
25.01.2007 05:08 РАМАН буду примного благодарен если поможете возможно буду чем ни...  --  Андрей
24.01.2007 19:08 Андрей читаите форум- "19 декабря 2006 г. в 18:27 наверх а...  --  РАМАН
24.01.2007 05:56 Помогите нужен софт моторола см-140 см-160...  --  Андрей
22.01.2007 01:01 РАМАН, а можно поподробнее пожалуйста! Что получится в результате...  --  Серг. с бывшей ...
21.01.2007 18:26 copy of :kPG-60D and kpg-49d ver4.for win tk280/380radios?mail me...  --  chinon
19.01.2007 22:02 Ewgene вам нужна прогр.KPG-87D ...  --  РАМАН
19.01.2007 21:32 ДЛЯ Серг. с бывшей коллективки RZ6LWP " есть ли у кого мануал на...  --  РАМАН
19.01.2007 20:56 TK-2260 попробуйте- KPG-87D...  --
19.01.2007 10:39 Кто подскажет как и какой программой програмировать TK-2260. За...  --  Ewgene
16.01.2007 02:18 vx-2r - станция читается без проблем, а вот писатся в нее категор...  --
15.01.2007 11:20 schemu motorola p040 p080 У кого есть проблемы с MOTOROLAми пи...  --  Нет
14.01.2007 21:25 UA1QDJ! ПИШИ НА loonga@rambler.ru , Я в свою очередь поделюсь, хо...  --  Серг. с бывшей ...
14.01.2007 12:17 schemu motorola p040 p080...  --  jaskolka
14.01.2007 05:28 короче могу поменяться информацией пиши andrew@port-aprel.ru...  --  ex UA1QDJ
14.01.2007 05:26 2 Серг.,  --  ex UA1QDJ
14.01.2007 05:25
2 Серг. с бывшей коллективки RZ6LWP ,  --  ex UA1QDJ
14.01.2007 05:22
2 Серг. с бывшей коллективки RZ6LWP Есть service manual с печат...  --  ex UA!QDJ
09.01.2007 19:55 Кто привык работать с LAY, пишите на мыло, есть ПЕЧАТКА, сделанна...  --  Дмитрий
09.01.2007 07:25 yo tambien! necesito el kpg80d...  --  Compumam
07.01.2007 21:32 А есть ли у кого фото внутренностей МОТОРОЛКИ GP68 - со снятой ме...  --  Серг. с бывшей ...
03.01.2007 01:35 Люди добрые, есть ли у кого мануал на YAESU FTH 2010? МОЖЕТ ЛИ О...  --  Серг. с бывшей ...
26.12.2006 13:47 Looking for software for the Kenwood TK-3200 (KPG-88D) please re...  --  Kenwood TK-3200...
19.12.2006 18:27 а почему такая проблема с motorola см серии (140 160) от жаднос...  --
15.12.2006 11:02 У кого-нибуть есть рабочая программа для VX-2000? СЕ20 та что ест...  --  Сергей,ur5xez...
14.12.2006 17:32 Люди добрые, честные, любители и просто любопытные. Помоготие най...  --  Геннадий
13.12.2006 16:37 Disculpame pero no entiendo tu idioma... Pero agradezco la info ...  --  Marcelo Valenzu...
12.12.2006 10:35 Сорри, предыдущая ссылка для GM140 http://www.cnham.com/software...  --  US8IKC, Алексан...
12.12.2006 10:26 i-m looking for the software for both the Motorola P020 and CP040...  --  Jaco Le Roux P0...
12.12.2006 10:21 Уважаемая Альбина! вот ссылка для скачивания. к сожалению не пров...  --  US8IKC, Алексан...
12.12.2006 06:13 Коллеги! Необходима верси для СМ серии R03.00.05 . У кого есть?От...  --  Альбина
11.12.2006 23:07 Еще один вариант восстановления станций. Применялся при восстано...  --  Us8Ikc? Алексан...
11.12.2006 20:24 Как настроить Мотороллу GP 340. Или где это можно сделать. Или к...  --  Полковник
11.12.2006 11:57 Товарищи, коллеги и просто добрые люди... Помогите, ПЛИZZZZZZ......  --  Svyazist
10.12.2006 00:34 Проверено при программировании DRAGON SY5430(трехканальный вариа...  --  US5IVZ
09.12.2006 10:00 I need soft for programing motorola cm-140, ...  --  I need soft for...
07.12.2006 19:39 necesito el program KPG80D, GRACIAS. I need program KPG80D, THANK...  --  Kris
05.12.2006 11:46 Коллеги! Помогите с софтом для CM 140 R03.00.05. Можно на адрес ...  --  Альбина
01.12.2006 10:08 ur5vtp ! См. ответ на http://forum.cqham.ru/viewtopic.php?t=9558&...  --  ur5vtp
30.11.2006 05:52 Уважаемый EW8CR! Очень-очень необходим софт на СМ-140. У Вас верс...  --  Альбина
29.11.2006 16:26 есть прога Kpg99D но, что не делаю запрограмировать kenwood tk 70...  --  ur5vtp
29.11.2006 11:49 У меня есть софт для программирования CM-140 / CM-160 и CP-140 ...  --  EW8CR
27.11.2006 20:03 ищу софт для программирования ICOM F110...  --  ua1onw-arx
24.11.2006 09:04 СМ-140 и СР-140 Друзья помогите софтом или ссылку . Спасибо !!!...  --  UA3ZC
14.11.2006 18:00 software icom f121s software icom f111s atenciozamente tia...  --  tiao garrucha p...
14.11.2006 11:15 looking for cm140 motorola programming software please....  --
13.11.2006 13:57 Подскажите пожалуйста как настроить портативную радиостанцию мото...  --  полковник
13.11.2006 10:07 tk2107 3107 5118 3118 ...  --  siamak
12.11.2006 09:48 Андрей ! Ответ на Ваш вопрос в форуме: http://forum.cqham.ru/vie...  --  Евгений Андропо...
11.11.2006 02:26 Собрал схему универсального программатора почемуто неработает. Чи...  --  андрей
09.11.2006 13:29 пожалуйсто помогите найти схемы на радиостанции motorola GM 360 и...  --  иван
07.11.2006 13:26 I NEED TO KPG 87D...  --  M CHIANOV
05.11.2006 11:42 Здравствуйте Евгений. Привет всем. А как насчёт радиостанции Альт...  --  Александр
31.10.2006 09:42 Игорь, и Вам большое спасибо за проверку станции ! Пошел добавлят...  --  Евгений Андропо...
30.10.2006 09:48 Сегодня появилась возможность проверить программатор на ПВ/КВ тра...  --  Игорь,RA0FMF...
30.10.2006 06:06 schematic kenwood tk-862g-1...  --  pablo
29.10.2006 08:50 TK790 Programming ?...  --  bg6iaq
29.10.2006 08:43 TK790 Programming ...  --  bg6iaq
26.10.2006 09:52 RW6MGO ! О радиостанциях "Гранит" ничего сказать не могу - никогд...  --  Евгений Андропо...
24.10.2006 23:34 Уважаемый Евгений подскажите,можно ли использовать программатор д...  --  RW6MGO
23.10.2006 10:46 Возможно ли вести приём вещательных станций, а при вызове автомат...  --  Владимир RA9FUE...
18.10.2006 13:03 ВОПРОСЫ ЗАДАВАЙТЕ В ФОРУМЕ: http://forum.cqham.ru/viewtopic.php?t...  --  Евгений Андропо...
18.10.2006 13:01 По TK-862G-1. Если читается "check sum", это уже неплохо - програ...  --  Евгений Андропо...
18.10.2006 12:59 ЕВГЕНИЙ ! Спасибо за сообщение о проверке ! Не попадался мне тип ...  --  Евгений Андропо...
17.10.2006 20:52 Уважаемые коллеги,помогите,может кому небут было такая проблема. ...  --
17.10.2006 14:00 Здравствуйте! Программатор - супер! Успешно перепрограммированы: ...  --  Евгений
16.10.2006 15:19 Уважаемый Роман! Мой адрес rw9rn@mail.ru...  --  RW9RN
12.10.2006 22:43 Уважаемый коллега! Вам нужна програма D 03.02.01. Сам роботал с G...  --  РОМАН
10.10.2006 14:36 Уважаемый Роман! При переходе по указанным Вами ссылкам, ERROR T...  --  RW9RN
09.10.2006 13:58 Нужно перешить ТИТАН ТМ-101-4.(4Р22В).Где взять софт и схему пере...  --  UT5VF
09.10.2006 04:36 necesito el program KPG80D, GRACIAS. I need program KPG80D, THAN...  --  Marcelo Melogno...
05.10.2006 17:27 я сначала тоже подумал на аккулятор а потом подкинул радио на отд...  --  US5MUW Alexey...
05.10.2006 09:56 US5MUW Alexey ! HELP для KPG-87D входит в комплект поставки прогр...  --  Евгений Андропо...
04.10.2006 13:33 Да и еще хотел спросить HELP для KPG - 87D,или кто подскажет как ...  --  US5MUW Alexey...
04.10.2006 12:43 Евгений большое спасибо.!!!у меня в 2260 не работает на передачу ...  --
03.10.2006 16:56 US5MUW Alexey ! Вам, очевидно, нужна программа KPG-87D. В форуме ...  --  Евгений Андропо...
01.10.2006 12:32 ПОДСКАЖИТЕ ПОЖАЙЛУСТА КАКОЙ ПРОГРАММОЙ ПОЛЬЗОВАТЬСЯ ДЛЯ KENWOOD 2...  --  US5MUW Alexe...
26.09.2006 22:07 УВАЖАЕМЫЙ RW9RN ДЛЯ GP-340 -http://www.ham.dmz.ro/motorola/gp340...  --  POMAH
26.09.2006 09:27 Уважаемые коллеги! Помогите найти софт для GM360 и GP340!!! С у...  --  RW9RN
24.09.2006 16:23 помогите найти софт csf14 ,с уважением .....  --  квас
18.09.2006 23:32 Доброго времени суток. Подскажите пожалуйста, какой софт лучше ис...  --  Евгений UR5LIS...
18.09.2006 09:15 Нестерову Александру и Игорю RA0FMF. Уважаемые коллеги, большое с...  --  Евгений Андропо...
18.09.2006 09:04 Вчера программировал данным программатором FT8800 (soft FTB8800) ...  --  Игорь, RA0FMF...
15.09.2006 21:21 На прошлой неделе программировал YAESU VX-2000U soft CE20....  --  Нестеров Алекса...
14.09.2006 20:17 icom ic-f320...  --
12.09.2006 20:48 data de tk862g ...  --  pablo
11.09.2006 09:39 Андрей ! Для Motorola CP040 попробуйте использовать другой софт, ...  --  Евгений Андропо...
10.09.2006 04:41 Всё отлично, собрано два программатора, оба трудятся исправно. Ли...  --  Андрей, UA3USQ...
05.09.2006 01:24 никто не подскажет схему кабеля к радиостанции maxon sp-120, обис...  --  Юрий
03.09.2006 10:42 Большое спасибо Вам,Евгений, за программатор.Собранный без ошибок...  --  Николай-UT5VF...
01.09.2006 09:32 Александр ! Поздравляю с успешной прошивкой. Представьтесь мне на...  --  Евгений Андропо...
31.08.2006 12:00 Программатор хорош. Испробован на VX-200, DJ-191, FT-11R. Но оди...  --  Александр
31.08.2006 09:25 RN3DD ! И все же штеккер для VX-210A четырехконтактный. Трехконта...  --  Евгений Андропо...
29.08.2006 10:19 Огромное спасибо за подсказку, все заработало, но штекер для VX-2...  --  RN3DD
28.08.2006 09:20 Slaver ! Трудно комментировать работу чужих программаторов, не зн...  --  Евгений Андропо...
28.08.2006 09:16 RN3DD ! Убедиться в работоспособности можно. Подключите программа...  --  Евгений Андропо...
25.08.2006 07:06 Можно как-то убедить в работоспособности программатора без подклю...  --  RN3DD
24.08.2006 14:51 Здравствуйте! Есть софт и программатор на STANDARD HX290. Все дел...  --  Slaver
16.08.2006 07:02 Здравствуйте! Подскажите пожалуйста, где можно взять прогу KPG99D...  --  Дмитрий
14.08.2006 02:28 rtyrtytyuytutyuytuy...  --  marcos
14.08.2006 02:27 ggdfgdfgfghfdg...  --  marcos
03.08.2006 09:24 Антон ! Вам нужна программа cs-f100s, она есть на этом сайте....  --  Евгений Андропо...
01.08.2006 14:57 icom ic-f111s не конектится. Программа его не видет, монтаж прове...  --  Антон
28.07.2006 16:44 Zdrastvuite, Izvinite moi ruskii t to chto ya na latinitsu pishu...  --  dedMoroz
26.07.2006 14:41 Доброго времени суток! Ребята помогите с прогой на GP640. Пойде...  --  ra4aja
24.07.2006 22:29 RADIO ...  --  HECTOR
24.07.2006 10:25 Hi i am desperat to get the programmingsoftware and cable to my r...  --  Datateknikk Nor...
24.06.2006 18:19 hello i am looking KPG80D for KENWOOD mobile radio programming so...  --  ARIFFIN MS
31.05.2006 09:53 Уважаемый Игорь ! Поздравляю с очередным удачным программирование...  --  Евгений Андропо...
30.05.2006 23:26 Хочу поделиться еще одной приятной новостью. С помощью данного пр...  --  Игорь, UU8JA...
30.05.2006 22:12 Уважаемый Евгений! Запрограммировал IC F-21 указанным Вами софтом...  --  Игорь, UU8JA...
30.05.2006 09:29 RA9MHL ! Спасибо за проверку P020, добавлю в список. Уважаемый те...  --  Евгений Андропо...
29.05.2006 16:32 Запрограмировал Мотор Р020 шнурком от переходника к Р040...  --  ra9mhl
29.05.2006 05:49 Здравствуйте, Альбина! Вот мой E-mail: osgroup@mail.ru Заранее...  --  Сергей
29.05.2006 05:29 Cергей!Дайте ваш почтовый ящик.Попробую скинуть файл....  --  Альбина
26.05.2006 12:54 Уважаемая Альбина! Подскажите, если знаете, ссылку, где можно взя...  --  Сергей
26.05.2006 10:33 Сергей! Попробуйте вслепую сделать то ,что я вам посоветовала.Заг...  --  Альбина
25.05.2006 16:13 Игорь ! Поздравляю, что программатор работает и что нашли нужную ...  --  Евгений Андропо...
25.05.2006 16:01 Cергей ! Для начала попробуйте сохранить пустой файл и убедитесь,...  --  Евгений Андропо...
25.05.2006 14:28 Спасибо ОГРОМНОЕ ! Действительно, есть ссылка. Я туда заходил. Вс...  --  Игорь, UU8JA...
25.05.2006 14:26 Спасибо, Евгений! Но эту программку я уже пробовал. Не работает....  --  Сергей
25.05.2006 13:29 Игорь ! Перейти по ссылке "Схемы и мануалы" вверху страницы пробо...  --  Евгений Андропо...
25.05.2006 13:12 Несмог найти на сайте софт для IC-F21/IC-F11 Укажите пожалуйста ...  --  Игорь, UU8JA...
25.05.2006 09:28 Cергей ! Вот, попробуйте эту программу: http://hamradio.online.ru...  --  Евгений Андропо...
25.05.2006 05:47 Уважаемый Евгений! Если несложно, дайте линк на CSF300. Не смог ...  --  Сергей
25.05.2006 04:36 Cергей! Софт действительно надо взять тот ,который советует вам Е...  --  Альбина
24.05.2006 15:51 Сергей ! В принципе программатор от станций Vertex должен работат...  --  Евгений Андропо...
24.05.2006 13:06 Уважаемая Альбина! При попытке программировать Icom IC-F320 прогр...  --  Сергей
23.05.2006 09:46 Максим ! Пожалуй, я действительно погорячился рекомендовать LM293...  --  Евгений Андропо...
22.05.2006 20:52 Евгений !, в качестве стабилизатора использовал LM2931T, а диоды ...  --  Максим
22.05.2006 10:47 Уважаемая Альбина ! В Motorola GP-340 отрегулировать мощность тем...  --  Евгений Андропо...
22.05.2006 10:01 Сергей ! В сбойную IC-F320 для начала попробуйте залить, не читая...  --  Евгений Андропо...
22.05.2006 09:55 Максим ! Поздравляю, что программатор заработал ! Представьтесь м...  --  Евгений Андропо...
22.05.2006 09:26 Уважаемый Евгений! Запоздало благодарю за ваш ответ. С программат...  --  Альбина
22.05.2006 09:11 Если в ICOM-320 появляется CLNG,то это либо неисправна EEPROM,ли...  --  Альбина
22.05.2006 07:55 Помогите!!! Что это может быть??? Icom IC-F320-6 при включении в...  --  Сергей
21.05.2006 21:26 Да, программатор работает с радиостанцией VERTEX VX-200 при запус...  --  Максим
19.05.2006 19:27 Господа! а где подробнее почитать о печати плат "утюжным" способо...  --  Максим
19.05.2006 12:16 Парни где качнуть kdg82D? Или пришлите на ra4lw@vinf.ru Заранее ...  --  Володя, ra4lw...
19.05.2006 11:25 Да, Евгений! Сообщение было мое. Но станции так и не читаются. Хо...  --  Сергей
19.05.2006 09:35 Сергей ! Обычно программно выйти за границы диапазона можно на 2-...  --  Евгений Андропо...
18.05.2006 14:16 Можно ли програмно расширить рабочий диапазон Yaesu FTH-2010 (опу...  --  Сергей
18.05.2006 09:34 Максим ! Программа при попытке считать станцию сама подскажет Вам...  --  Евгений Андропо...
17.05.2006 20:32 Бирка с типом станции утерена, предпологаемый пакет программ скач...  --  Максим
17.05.2006 09:41 Максим ! Начинайте поиск программ на этом сервере со страницы htt...  --  Евгений Андропо...
16.05.2006 19:55 Да и как узнать тип радиостанции на корпусе нет бирки, спецы гово...  --  Максим
15.05.2006 21:26 Привет всем! Програматор видел собиру но где взять программу для...  --  Максим
12.05.2006 12:36 Спасибо Евгений! Буду дальше пробовать! 73!...  --  Сергей
12.05.2006 10:14 Сергей ! Схема именно CT-29 мне не известна, тем не менее могу ск...  --  Евгений Андропо...
12.05.2006 10:05 Уважаемый Ильдар ! Универсальный программатор нашего производства...  --  Евгений Андропо...
12.05.2006 05:29 Программатор CT-29 (заводской) с другим типом радиостанций работ...  --  Сергей
12.05.2006 03:30 Так и случилось, колдун Вы Евгений :) в связи с чем пара вопросов...  --  Ильдар Салихов...
11.05.2006 15:05 Сергей ! Станция FTH-2010 может не читаться из-за неисправной при...  --  Евгений Андропо...
11.05.2006 14:56 Уважаемый Ильдар ! В переходнике к GP-340 стоит резистивный делит...  --  Евгений Андропо...
11.05.2006 13:46 Опять Yaesu FTH-2010!!! Достались от родной милиции. На прием не...  --  Сергей
11.05.2006 04:56 Еще раз спасибо Евгений! Программатор у меня Айкомовский, универс...  --  Ильдар Салихов...
10.05.2006 09:28 Ильдар ! Вовне диапазона станцию можно увести на несколько (3-4) ...  --  Евгений Андропо...
07.05.2006 21:29 Спасибо Евгений! С помощью софта IC-F300/400, все прекрасно прочи...  --  Ильдар Салихов...
04.05.2006 10:00 Ильдар ! IC-F420 может быть заблокирована от чтения, а может и тр...  --  Евгений Андропо...
03.05.2006 03:22 Есть программатор Icom, радиостанция IC-420, запрограммированная ...  --  Ильдар Салихов...
02.05.2006 09:20 По TK-760HG-1. Как и все прочие станции KENWOOD версии G, сей агр...  --  Евгений Андропо...
30.04.2006 17:38 como puedo progamar kenwood tk 350 gracias...  --  antonio
29.04.2006 10:56 господа! кто может помочь советом или делом? необходима программа...  --
29.04.2006 10:53 как запрограммировать радиостанцию kenwood tk760hg-1...  --
28.04.2006 08:37 hola , me pueden decir de donde bajo la interface de programacio ...  --  lecue
28.04.2006 07:16 como puedo programarun kenwood tk.860...  --
27.04.2006 11:45 Господа, где можно наити программку CE-63 для программирования VX...  --  Дмитрий
27.04.2006 11:43 Господа, где мажно наити программку CE-63 для программирования VX...  --  Дмитрий
24.04.2006 11:01 Уважаемая Альбина ! В схеме ошибки нет, она многократно проверена...  --  Евгений Андропо...
24.04.2006 10:15 Андрей,помогите пожалуйста советом.Собрала схему универсального п...  --  Альбина
24.04.2006 09:47 Андрей.Н. ! Есть такой дохлый момент у Мотороловцев - несовместим...  --  Евгений Андропо...
24.04.2006 09:43 Kot33 ! Не надо формализма и стеснительности. Просто перейдите по...  --  Евгений Андропо...
21.04.2006 15:51 программатор работает с GP340.но не могу запрограммировать прога ...  --  Андрей.Н.
21.04.2006 11:42 Подскажите кто знает где можно скачать софт для программирования ...  --  Kot33
21.04.2006 09:24 EU7EA ! В неправильное гнездо разъем и подключиться не должен. По...  --  Евгений Андропо...
20.04.2006 13:21 Подскажите пожалуйста в какое из гнезд SP или MIC нужно подключа...  --  EU7EA
13.04.2006 20:00 Добрый день! Нужна профессианальная помощь ! Р/с Vertex VX-2500U...  --  Алексей
13.04.2006 09:36 Максут ! Вы вряд ли найдете такую инструкцию, тем более на русско...  --  Евгений Андропо...
11.04.2006 15:33 Добрый день уважаемые радиолюбители! Помогите освоить новичку те...  --  Максут
09.04.2006 03:55 Nashla na saite KPG-23D. Spsibo dobrim people kto eto delo organi...  --  Irina
09.04.2006 02:14 Privet vsem! Kto imeet software KPG-23D i KPG-90D, pros-ba podel...  --  Irina
06.04.2006 09:30 РОМАН ! Поздравляю с успехом. Представьтесь посодержательнее мне ...  --  Евгений Андропо...
05.04.2006 19:33 Здравствуйте уважаемый Евгений,здравствуй Влад! Извините Евгений ...  --  РОМАН
05.04.2006 10:33 У меня тоже были проблемы с YEASU FTH-2010 при програмировании ну...  --  Влад
03.04.2006 09:24 РОМАН ! Попробуем лечить дистанционно и без фотографии. Вариант р...  --  Евгений Андропо...
02.04.2006 21:51 Здравствуйте Евгений и все дорогие радиолюбители! У меня проблемы...  --  РОМАН
23.03.2006 14:26 Здравствуйте уважаемый Евгений! Спасибо за подсказки! Наконец то...  --  UR8QM
21.03.2006 09:45 UR8QM ! Видимо, Вы не ввели станцию в режим программирования. По ...  --  Евгений Андропо...
21.03.2006 09:39 EW3BX ! Спасибо за перепроверку станции. Судя по софту для KENWOO...  --  Евгений Андропо...
21.03.2006 09:31 Paolo IW3SQM ! Thanks for testing VX-180 and VX-2500, I will publ...  --  Yevgueny Androp...
20.03.2006 12:31 Привет всем. У меня радиостанция YEASU FTH-2010 при попытке счита...  --  UR8QM
20.03.2006 12:27 Привет всем. У меня радиостанция YEASU FTH-2010 при попытке счита...  --  UR8QM
18.03.2006 23:55 Перепроверил с YAESY VX 10,ПРОГРАММАТОР изготовил в авторском вар...  --  EW3BX
17.03.2006 23:11 Checked the multipurpose cable, is very good from Vertex VX 180 s...  --  Paolo iw3sqm...
14.03.2006 09:52 RW6APW ! Касаемо ICOM M700TY ничего заранее не скажу, пробуйте. Н...  --  Евгений Андропо...
14.03.2006 09:51 Don999 ! Серьезно отвечаю. Для IC-F3 применяется трехконтактный ш...  --  Евгений Андропо...
13.03.2006 00:27 Подскажите пожалуйста ,можно ли перепрогромировать трансивер IC...  --  RW6APW
11.03.2006 11:22 Ну я серьезно спрашиваю , неужели так тяжело подсказать ? Просто ...  --  Don999
10.03.2006 09:36 Don999 ! Куда не надо разъем подключиться не должен... ...  --  Евгений Андропо...
09.03.2006 21:00 Подскажите пожалуйста куда именно подключать разьем к радиостанци...  --  Don999
09.03.2006 09:28 UA2FBB ! Воспользуйтесь для DR-605E тем же переходником, что и дл...  --  Евгений Андропо...
05.03.2006 00:14 Подскажите пожалуйста распиновку и тип разъема для программирован...  --  ua2fbb
02.03.2006 13:15 Может кто подскажет как раскрыть диапазон до 136-174 на Alinco 19...  --  Serg
01.03.2006 15:31 maxon...  --  ungureanu marin...
26.02.2006 09:35 For TK278 use the Fig.1 schematics and "KENWOOD portable" connect...  --  Yevgueny Androp...
24.02.2006 11:29 Please give me one interfaces for Kenwood TK278(schematics)! Tank...  --
20.02.2006 09:26 Александр ! Большое спасибо за сообщение !...  --  Евгений Андропо...
19.02.2006 21:47 При установке инверсии сигналов (561ла7 или 561ле5) программирует...  --  Нестеров Алекса...
19.02.2006 21:45 При установке инверсии сигналов (561ла7 или 561ле5) программирует...  --
16.02.2006 15:55 your site very good............:....thank you...........  --  kerrouche
15.02.2006 16:02 dweer hjjk...  --  raman
22.01.2006 10:46 hello i am looking for radio software....  --  mitch
19.01.2006 09:21 SERG ! Если речь идет о софте KPG-80D, то читая справку к нему....  --  Евгений Андропо...
17.01.2006 18:56 как работать с kpg 80...  --  serg
16.01.2006 09:36 Нестерову Александру ! Большое спасибо за проверку радиостанций и...  --  Евгений Андропо...
14.01.2006 20:27 Работает со сканером ICOM IC-R10 программа CSR10...  --  Нестеров Алекса...
14.01.2006 01:01 Работает с раритетом YAESU FTH-2010 программа CE2, а также с IC-...  --  Александр Несте...
13.01.2006 09:34 DIMAR ! К сожалению, статья полезна не только начинающим. Вы не п...  --  Евгений Андропо...
13.01.2006 02:55 Статья полезна начинающим, но во многих случаях лучше пользоватьс...  --  dimar
12.01.2006 09:56 ALEXEY ! Поздновато у Вас Новый год... Вряд ли дело в "пнях". Нуж...  --  Евгений Андропо...
12.01.2006 09:48 OLEG74. Расслабьтесь. Из IC-F4 (400-430 МГц) сделать (136-150 МГ...  --  Евгений Андропо...
11.01.2006 22:29 Всех С Новым годом!!! Возникла проблема с программированием kenw...  --  Alexey
11.01.2006 21:27 спасибо поищу ,но получится ли с IC-F4( 400-430 Мгц) сделать(136-...  --  oleg74
11.01.2006 09:34 OLEG74. Ответ: частоты IC-F4 перепрограммировать можно. Смотрите ...  --  Евгений Андропо...
10.01.2006 23:59 вопрос можно ли перепрограмировать рабочие чистоты на IC-F4...  --  oleg74
05.01.2006 10:05 Para la programación VX-210A fabriquen este cable. Él t...  --  Yevgueny Androp...
01.01.2006 19:38 Евгений спасибо за информацию но 390 совсем другой аппарат. Нужн...  --  олег ru6fb
01.01.2006 18:29 hola amigos.mi pregunta es como puedo programar un standar vx210a...  --  walter
21.12.2005 10:30 YASSIR ! Thanks for testing ! Спасибо за проверку !...  --  Евгений Андропо...
21.12.2005 07:13 MOTOROLA GP 340 16CH...  --  YASSIR
19.12.2005 10:13 UA0JII ! Тест успешный, ждем содержательной информации ! Кстати, ...  --  Евгений Андропо...
19.12.2005 02:55 тест ...  --  ua0jii
15.12.2005 21:27 Евгений еще раз спасибо! Все я решил эту проблему, запрограммирро...  --  Alexey
15.12.2005 09:31 Alexey ! Схемы ERW-4-подобных программаторов есть на СКР. Наприме...  --  Евгений Андропо...
14.12.2005 23:27 Евгений спасибо, я вас понял. Но у этой алинки штатный именно e...  --  Alexey
14.12.2005 14:29 ПОЖАЛУЙСТА, помогите найти софт KPG- 82D для программирования рад...  --  ДМИТРИЙ
14.12.2005 09:51 Alexey ! Не все Алинки (хотя многие) программируются через указан...  --  Евгений Андропо...
14.12.2005 09:48 МАРАТ ! Сервис-мануал и софт лучше всего прислать Юрию UA6AP для ...  --  Евгений Андропо...
13.12.2005 19:33 Большая просьба! Кто нибудь в курсе на alinco DJ-1000 какой прог...  --  Alexey
13.12.2005 13:25 спасибо Евгений нашел софт по указанному направлению. Програмирую...  --  МАРАТ
12.12.2005 20:13 Виноват, поторопился. TK-2206 программируется KPG-87D. Для TK-210...  --
12.12.2005 10:08 МАРАТ ! Попробуйте поискать информацию по tm271a/471a на www.ken...  --  Евгений Андропо...
10.12.2005 22:13 Как прошить ERICSSON GE PC208S на 145 и чем? ...  --  RU9TR
09.12.2005 12:35 нужна помощь есть kenwood tm271a/471a нечем програмировать кто зн...  --  Марат
17.11.2005 16:22 Plant ! Воспользуйтесь программой CSF300 с этого сайта (http://ha...  --  Евгений Андропо...
17.11.2005 11:56 Соратники,пожскажите пож какой прогой шить Icom 310 , а так-же ка...  --  Plant
17.11.2005 11:51 Соратники,пожскажите пож какой прогой шить Icom 310 , а так-же ка...  --  Plant
17.11.2005 09:47 Можно попробовать и с нашим программатором. Если взять за основу ...  --  Евгений Андропо...
16.11.2005 23:25 Господа хоршие подскажите пожалуйста как перпрограммировать р/ст ...  --  Всеволод, RA4YD...
14.11.2005 15:14 Виноват, поторопился. TK-2206 программируется KPG-87D. Для TK-210...  --  Евгений Андропо...
14.11.2005 09:23 Kenjima ! Все верно - TK-2106z программируется KPG-87D. Уверен, ч...  --  Евгений Андропо...
12.11.2005 01:00 Kenwood TK-2106z в программе отсутствует, и не опознаётся. То ес...  --  Kenjima
31.10.2005 09:37 По WINDOWS XP. Проблема запуска DOS-программ решается просто. Нео...  --  Евгений Андропо...
31.10.2005 09:33 FOBOSу. Программатор Вы уже нашли - используйте переходник "YAES...  --  Евгений Андропо...
29.10.2005 18:40 Программное обеспечение для программирования радиостанций кенвуд ...  --
29.10.2005 17:16 Помогите найти SOFT для программирования ретранслятора VXR-7000...  --  fobos
29.10.2005 17:14 Помогите найти программматор для VXR-7000...  --  fobos
28.10.2005 19:12 TK385/TK&...  --  BG...
17.10.2005 09:30 О ! Рекламку на португальском языке разместили - это свидетельств...  --  Евгений Андропо...
17.10.2005 05:53 o programa do vx 2000 que esta no site nao abre presciso saber c...  --  INFORMACAO
07.10.2005 09:21 RA9MHL. А в кабеле на MAX232 точно нет CTS/RTS ? Для каких-то апп...  --  Евгений Андропо...
05.10.2005 17:35 Да может,на мах232 работает на скорости 115000 без проблем,да лад...  --  ra9mhl
04.10.2005 09:22 RA9MHL. А сам телефон быстрее-то может ? Если может, то посмотрит...  --  Евгений Андропо...
03.10.2005 19:33 Сделал навеску для сот.телефонов, у меня Siemens ME45, но работае...  --  ra9mhl
29.09.2005 19:08 ПОМОГИТЕ найти софт для Kenwood TK-3140 KPG-74D. Очень нужно....  --  Андрей
05.09.2005 09:25 Александр, мне Аланы пока не попадались. Если есть какая-нибудь д...  --  Евгений Андропо...
04.09.2005 17:45 Может кто программировал Alan HM 43. Поделитесь пожалуйста опытом...  --  Александр
01.09.2005 09:53 ДИМА, для начала убедитесь, что DOS-овскую программу Вы запускает...  --  Евгений Андропо...
31.08.2005 16:29 При програмировании радиостанции VX2000 возникла проблема с прогр...  --  Дима
26.08.2005 10:19 Уважаемый Олег ! Вынужден Вас огорчить. Ретранслятор TKR720 пр...  --  Евгений Андропо...
25.08.2005 21:20 ru6fb Олег Карпов. Проверил программатор на радиостанциях motorol...  --  Oleg ru6fb
10.08.2005 17:42 ATTENTION ! On the GP-340 connector the RTxD contact should be di...  --  Yevgueny Androp...
10.08.2005 17:33 RU6FB: спасибо за проверку, представьтесь содержательнее, добавлю...  --  Евгений Андропо...
10.08.2005 17:03 Товарищи Все отлично работает. проблема была с программой. вмес...  --  ru6fb
10.08.2005 09:18 RU6FB: светодиод мигнул - уже хорошо. Надеюсь, что нужный софт дл...  --  Евгений Андропо...
09.08.2005 17:30 собрал программатор при запуске компа несколько раз мигнул светод...  --  ru6fb
09.08.2005 09:42 RA1AGG: По ссылочке заглянул, спасибо. Для телефонов такая схема ...  --  Евгений Андропо...
08.08.2005 14:57 Можно заглянуть по этой ссылочке http://bobjohnson.nm.ru/inf/c55_...  --  RA1AGG
08.08.2005 13:53 Внимание, на переходнике для GP-340 контакт RTxD подключен непоср...  --  Евгений Андропо...
28.07.2005 10:59 Распайку 9-контактного соединителя пока найти не удалось. Извиняй...  --  Евгений Андропо...
27.07.2005 14:05 Нет не подходит. Там у меня вдва ряда 4 и 5 пин как на ком порте ...  --  Олег
25.07.2005 09:35 Олегу: А рисунок http://hamradio.online.ru/ftp2/f30lt.jpg не подх...  --  Евгений Андропо...
25.07.2005 08:21 Подскажите через какую пину шьется IC-F30/31/40/41 там девять точ...  --  Олег
22.07.2005 20:33 Надо запрограммировать ICOM F-110-подойдет ли схема, кто пробовал...  --  Сергей
11.07.2005 09:33 Уважаемый(ая) тезка ! Боюсь, что мануал по программе на русском В...  --  Евгений Андропо...
05.07.2005 22:52 Интересует мануал по программе, которая через программатор залив...  --  Eugenie
05.07.2005 11:53 I am looking for Programming soft wear of MCS2000 VU3BIS Anupa...  --  programming sof...
05.07.2005 11:52 I am looking for Programming soft wear of MCS2000 VU3BIS Anupa...  --  programming sof...
14.06.2005 10:21 На схеме все правильно, у меня в таком виде работает. Опишите под...  --  Евгений Андропо...
10.06.2005 21:08 Кто собирал универсальный программатор http://www.cqham.ru/unipr...  --  alex
06.06.2005 09:41 bg6iaq, спасибо за на редкость содержательный отклик !...  --  Евгений Андропо...
03.06.2005 23:20 OK!...  --  bg6iaq
30.05.2005 09:38 Несколько версий софта для ICOM IC-F3 есть на этом сервере. Смотр...  --  Евгений Андропо...
28.05.2005 12:09 Пожалуйста помогите с софтом для ICOM F3...  --  ua9oai
23.05.2005 10:10 VLAD-у. По всей видимости с MCS2000 работать не будет, к ней треб...  --  Евгений Андропо...
20.05.2005 09:50 EU7SS ! Про MAXTRAC поройтесь на форуме, там этот вопрос обсуждал...  --  Евгений Андропо...
20.05.2005 04:50 1. Имею MAXTRAC мод.D34MWA2GF6AK 136-174мгц Программатор работает...  --  eu7ss
19.05.2005 16:19 Добрый денью.Подскажите MCS2000 програмить будет и где можно скач...  --  vlad
16.05.2005 13:39 Уважаемые, подскажите где скачать инфу про выходной транзистор m2...  --  Николай
15.05.2005 23:40 Добрый день коллеги.Подскажите где можно скачать софт для програм...  --  Виктор EW6OO...
14.05.2005 15:45 Видел софт для TK-2160 на qrz.ru и hackersrussia.ru...  --  Евгений Андропо...
14.05.2005 15:00 Добрый день коллеги.Если вас незатруднит,то вы несмоглиб подсказа...  --  VINNI
04.05.2005 09:29 Александр, спасибо за проверку. Сообщение о проверке Вами станций...  --  Евгений Андропо...
03.05.2005 16:37 Вопрос на засыпку. Может кто программировал ручную радиостанцию В...  --  Александр, UA4L...
03.05.2005 16:36 По работе приходится сталкиваться со многими станциями, и несмот...  --  Александр, UA4L...
11.04.2005 09:47 Спасибо, коллега ! А какой переходник использовали ?...  --  Евгений Андропо...
11.04.2005 01:16 Только что вот....LTS 2000...  --  Александр
15.01.2005 04:07 Только что вот.... TK-3101...  --  Александр
11.01.2005 10:35 Насколько я понял, KPG52D - софт для микромощных станций KENWOOD....  --  Евгений Андропо...
11.01.2005 10:35 Насколько я понял, KPG52D - софт для микромощных станци...  --  Евгений Андропо...
06.01.2005 17:16 Пришлите пожалуйста софт и схему KPG52...  --  Andrey UR5EVE...
06.01.2005 11:15 В качестве KPG-46 можно использовать данный программатор, переход...  --  Евгений Андропо...
03.01.2005 20:06 Где можно найти схему кабеля KPG-46 ...  --  Slava
15.12.2004 10:09 Юрий, большое спасибо за проверку !...  --  Евгений Андропо...
14.12.2004 11:03 Собрал и проверил Вашу разработку при программировании Кенвуда ТК...  --  Юрий US5IVZ...
30.11.2004 09:59 RA9MNL, на редкость содержательное сообщение ! С TK-278/378 пробл...  --  Евгений Андропо...
28.11.2004 13:58 TK-278...  --  RA9MNL
12.11.2004 16:53 Думаю, эта схема должна подойти, выберите соответствующий переход...  --  Евгений Андропо...
12.11.2004 15:20 срочно нужна схема программатора для ICOM IC F121S, плииииз!...  --  Алекс
11.11.2004 14:58 Всем привет, где найти схему на Yeasu FTL - 2007?...  --  UR3CRV, Алексан...
29.09.2004 10:48 Проверьте настройки COM-порта, может быть несоответствие между на...  --  Евгений Андропо...
28.09.2004 21:42 Прошились DJ-191 и TK-370 Кто пробовал шить VX-500 ?...  --  Александр
23.09.2004 10:22 Спасибо за сообщение о проверке ! DJ-191 может быть транковой и п...  --  Евгений Андропо...
20.09.2004 02:51 Работает на FT10,FT40.Не пошло с софтом DJ191,VX500...  --  Александр
16.09.2004 10:06 Александр, пришлите на почту (адрес на рисунке), какие радиостанц...  --  Евгений Андропо...
16.09.2004 01:32 Спасибо за подсказку.Другой пакет сработал через этот программато...  --  Александр
15.09.2004 11:24 Попробуйте разные EXE-файлы из пакета или другой пакет с данного ...  --  Евгений Андропо...
15.09.2004 03:09 Вопрос - ic-f320-6.Пакет ic_f3xx.zip при попытке подключения пише...  --  Александр
09.09.2004 11:39 Никакой информации на эти станции нет, если есть схема, пришлите,...  --  Евгений Андропо...
08.09.2004 01:07 8сентября 2004г.в 0:58 Сергей г.Усинск Какой переходник нужен дл...  --  Сергей
08.09.2004 01:06 8сентября 2004г.в 0:58 Сергей г.Усинск Какой переходник нужен дл...  --  Сергей
07.09.2004 09:38 Если ссылка на статью не работает, идите на kom-inform.euro.ru...  --  Евгений Андропо...
07.09.2004 09:36 Проверены р/ст ICOM IC-F3GS, VERTEX VX-5R, KENWOOD TK-370G. IC-F3...  --  Евгений Андропо...
02.09.2004 01:26 Серийный номер поменять можно, методика на batlabs, программа (чт...  --  Антон
30.08.2004 10:04 Коллеге Городнову спасибо за проверку программатора. Серийный ном...  --  Евгений Андропо...
26.08.2004 23:01 Можно ли поменять в радиостанции Motorola GP300 Серийный номер!!!...  --  Антон
19.08.2004 12:46 Спасибо большое за схему. Схема оказалась как раз вовремя. Прош...  --  Городнов
28.05.2004 09:43 +Е значит напряжение питания +5В. Стандартно точки с одинаковым о...  --  Евгений Андропо...
27.05.2004 10:14 А что значит на схема +E ? С уважением...  --  Макс
27.05.2004 09:36 А с этого сайта ничего не подходит ? Например софт IC-F11 ?...  --  Евгений Андропо...
27.05.2004 00:36 Hi, All. Кто-нибудь шил Icom IC-F21 ? Где можно софт капнуть ?...  --  Alexandr, UN7QA...
09.03.2004 10:02 Большое спасибо ra9mhl за отклик !...  --  Евгений Андропо...
08.03.2004 10:54 А также на Моторе GP 300...  --  ra9mhl
08.03.2004 10:51 А лучше вопросы на мыло ra9mhl@mail.ru...  --  ra9mhl
08.03.2004 10:50 Без вопросов работает на Kenwood 278,Yaesu VX1r,Vertex VX500,Moto...  --  ra9mhl
05.03.2004 10:30 Icom А110 не проверял, может гнездо и отличается. Проверьте прави...  --  Евгений Андропо...
03.03.2004 17:47 Я пробовал на А110, может у них гнезда разные ?...  --  Oleg(EX8MLT)...
19.02.2004 11:44 Урра-а-а !.. RA9MHL, а нельзя ли конкретные типы станций перечисл...  --  Евгений Андропо...
19.02.2004 08:36 Проверил,работает на некотрорых станциях фирм Моторола,Кенвуд,Ясу...  --  RA9MHL
10.02.2004 11:04 Контакты для Icom не перепутаны, что самое смешное, по крайней ме...  --  Евгений Андропо...
27.01.2004 20:06 Да, перепутанные контакты для Icom стоили лишних 15 мин чесания в...  --  Oleg(EX8MLT)...
26.11.2003 14:51 Отвечаю на предыдущую реплику. Готовые интегральные преобразовате...  --  Евгений Андропо...
25.11.2003 18:41 Наибольший интерес для меня в статье представляет рисунок озагл...  --  Ihor UR3LCM...
Âîçâðàò
